- To:
- Subject: Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges
- Date: Mon, 03 Nov 2008 13:29:58 +0100
Dennis Endt wrote:
Very Good joke. You made my day ;)
quite good indeed ;)
But if you had tried to understand
I am afraid we have spent more time reading your e-mails, trying to understand them, and answering them, that you have spent reading the manual, reading our answers and trying to understand them... after some threshold, mechanically, answers become less appropriate...
you would know, that I`m only
searching for a method which tells me, if the triangulations gone wrong
because of the same x_y coordinates and so on.
Bernd's suggestion about PCA sounds worth trying.
Of course you are welcome to keep on posting on this list, if you encounter real problems that are not solved by a simple look at the manual.
BTW, a complement about my answer below: in fact triangulations will never crash, but if you use a traits class that is not adapted to the data, your points may look collinear in projection, and you will again not like the results you get.
best,
Andreas Fabri schrieb:
Dennis Endt wrote:
Monique Teillaud schrieb:
If you are lucky (= your points really don't belong to a planeHi,
parallel to any xy,xz,yz plane), you will get the same triangulation
three times, which is not what you want (I guess so). Yhen using one
of these random traits should give you what you want.
If you are less lucky, one of the computationa will crash. Then, use
one of the other two.
I'm afraid that's the best you can do if you don't know anything about
your data, except the fact that they are almost coplanar.
best,
Monique Teillaud
thanks so far for your help.
My last question is:
How can I check if a computational will crash? What is the best method
for this?
You should
#include <CGAL/Cristall_ball.h>
It provides a constructor with an unsigned int specifying the number
of milliseconds you want to look into the future.
It's an undocumented feature, but that is what we recommend for
avoiding planes to fall from the sky.
I tried to use is_valid(), but this didn`t worked. Is it enough to check
for the number_of_vertices != 0 of a fassade?
Best,
Dennis
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, (continued)
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Dennis Endt, 11/02/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Nico Kruithof, 11/02/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Monique Teillaud, 11/03/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Nico Kruithof, 11/03/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Olivier Devillers, 11/03/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Dennis Endt, 11/03/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Andreas Fabri, 11/03/2008
- Re: [cgal-discuss] Re: Delaunay Triangulation - number of edges, Bernd Gaertner, 11/03/2008
