- To:
- Subject: Re: [cgal-discuss] Nef Polyhedron no simple to OFF
- Date: Tue, 09 Dec 2008 18:11:42 +0100
- Organization: INRIA
dear
is your Nef polyhedron unbounded? (infinite) or non manifold?
if it is unbounded, you have to bound it - this is feasible by intersecting it with eg a simple bounding box.
if it is non-manifold. I would recommend to apply closure, regularizations, etc (read definitions in the documentation) before trying to convert.
if this is not sufficient this means there is not much you can do beside saving it as a non-manifold polyhedron as Fred suggested.
Sent: December 9, 2008 8:25 AM
To:
Subject: [cgal-discuss] Nef Polyhedron no simple to OFF
Hello,
I'm working with .off files making boolean operations between 3D objects. When
the solution isn't a nef_polyhedron simple, I don't know how can I obtain a
.off file whith this polyhedron. Is this possible?
Thanks in advance,
Jonatan.
Pierre Alliez
INRIA Sophia Antipolis - Mediterranee Project-team GEOMETRICA http://www-sop.inria.fr/members/Pierre.Alliez/
Tel: +33 4 92 38 76 77
Fax: +33 4 97 15 53 95
- [cgal-discuss] Nef Polyhedron no simple to OFF, jona_100, 12/09/2008
- RE: [cgal-discuss] Nef Polyhedron no simple to OFF, Fred Dorosh, 12/09/2008
- Re: [cgal-discuss] Nef Polyhedron no simple to OFF, Pierre Alliez, 12/09/2008
- Re: [cgal-discuss] Nef Polyhedron no simple to OFF, Peter Hachenberger, 12/10/2008
- [cgal-discuss] A problem with iso oriented box intersection package, BBB HHH, 12/10/2008
- Re: [cgal-discuss] A problem with iso oriented box intersection package, Pierre Alliez, 12/10/2008
- Re : [cgal-discuss] A problem with iso oriented box intersection package, BBB HHH, 12/11/2008
- Re: [cgal-discuss] A problem with iso oriented box intersection package, Andreas Fabri, 12/10/2008
- Re : [cgal-discuss] A problem with iso oriented box intersection package, BBB HHH, 12/10/2008
- Re: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, jona_100, 12/10/2008
- RE: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, Fred Dorosh, 12/10/2008
- Re: RE: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, jona_100, 12/11/2008
- Re: RE: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, dekosser, 12/11/2008
