cgal-discuss - RE: Re: [cgal-discuss] Nef Polyhedron no simple to OFF
  • To: "" <>
  • Subject: RE: Re: [cgal-discuss] Nef Polyhedron no simple to OFF
  • Date: Wed, 10 Dec 2008 09:49:02 -0500
  • Accept-language: en-US
  • Acceptlanguage: en-US
> Must I do another conversor to .OFF directly from Nef_Polyhedron_3, or can I
> pass the Nef Polyedron (no simple) to a group of polyhedros (for example)?
> In
> this case I could obtain the .OFF easily.
I'm not sure I understand what you're suggesting, but a non-simple Nef
polyhedron won't break into simple polyhedral subsets.
You could attempt to eliminate the non-simple features via closure and
regularization operation as Pierre recommended.
If you're actually interested in retaining the non-manifold features, then
you need to process the Nef yourself. It provides visitor patterns that you
can use to extract all of the faces, although you will need to triangulate
them. I can provide some example code if you need.
Fred
Fred Dorosh
Software Architect | Presagis
T. +1 514 341.3874 X392 F. +1 514 341.8018
DISCLAIMER: This e-mail message is for the sole use of the intended
recipient(s) and may contain confidential and/or proprietary information. Do
not read, copy, or disseminate this message unless you are the addressee. Any
unauthorized review, use, disclosure or distribution is strictly prohibited.
If you have received this message in error, please contact the sender by
reply e-mail and delete the original and any copies from your system.
AVERTISSEMENT : Ce courriel s’adresse exclusivement au(x) destinataire(s)
mentionné(s) et peut contenir de l’information confidentielle et/ou de nature
exclusive. Ne pas lire, copier ou transmettre à quiconque ce courriel sauf si
vous en êtes le destinataire. Il est strictement interdit de réviser,
utiliser, transmettre ou distribuer ce courriel sans autorisation préalable.
Si vous avez reçu ce message par erreur, veuillez communiquer avec
l’expéditeur en répondant à ce courriel et en supprimant le courriel original
et toutes les copies enregistrées sur votre système.
