- To:
- Subject: Re: [cgal-discuss] Nef Polyhedron no simple to OFF
- Date: Wed, 10 Dec 2008 11:24:45 +0100
- Importance: Normal
- Sensitivity:
Hi Jona,
the Nef_polyhedron_3 package provides the functionality you are searching for. Unfortunately, there are
often some difficulties with the I/O that most beginners run into. Can you describe a bit more what you want
to do, or what problems occur.
Peter
To:
Date: 12/09/2008 02:25PM
Subject: [cgal-discuss] Nef Polyhedron no simple to OFF
Hello,
I'm working with .off files making boolean operations between 3D objects. When
the solution isn't a nef_polyhedron simple, I don't know how can I obtain a
.off file whith this polyhedron. Is this possible?
Thanks in advance,
Jonatan.
- [cgal-discuss] Nef Polyhedron no simple to OFF, jona_100, 12/09/2008
- RE: [cgal-discuss] Nef Polyhedron no simple to OFF, Fred Dorosh, 12/09/2008
- Re: [cgal-discuss] Nef Polyhedron no simple to OFF, Pierre Alliez, 12/09/2008
- Re: [cgal-discuss] Nef Polyhedron no simple to OFF, Peter Hachenberger, 12/10/2008
- [cgal-discuss] A problem with iso oriented box intersection package, BBB HHH, 12/10/2008
- Re: [cgal-discuss] A problem with iso oriented box intersection package, Pierre Alliez, 12/10/2008
- Re : [cgal-discuss] A problem with iso oriented box intersection package, BBB HHH, 12/11/2008
- Re: [cgal-discuss] A problem with iso oriented box intersection package, Andreas Fabri, 12/10/2008
- Re : [cgal-discuss] A problem with iso oriented box intersection package, BBB HHH, 12/10/2008
- Re: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, jona_100, 12/10/2008
- RE: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, Fred Dorosh, 12/10/2008
- Re: RE: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, jona_100, 12/11/2008
- Re: RE: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, dekosser, 12/11/2008
- Re: Re: RE: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, jona_100, 12/17/2008
