- To:
- Subject: Re: RE: Re: [cgal-discuss] Nef Polyhedron no simple to OFF
- Date: Thu, 11 Dec 2008 09:30:00 -0500 (EST)
- Importance: Normal
>>If you're actually interested in retaining the non-manifold features,
>> then
>>you need to process the Nef yourself. It provides visitor patterns that
>> you
>>can use to extract all of the faces, although you will need to
>> triangulate
>>them. I can provide some example code if you need.
> Yes, that's that I want. I will be grateful if you spend some example.
I've attached a converter that I built. Note that it depends on my own
BGT_Mesh interface - those bits you can replace with e.g. writing out to
an .OFF file. Essentially at some point it calls AddVertex() to add a
vertex to the mesh and AddPolygon() to add a triangle as an array of three
vertex indices. There is also code that adds texture attributes
(_MATERIAL_MARKING_) but you can ignore that.
The important thing is that it visits all shells and triangulates all facets.
Fred
Fred
// Inspired from Nef_polyhedron_3::Build_polyhedron
template<typename Kernel, typename Nef_3, typename Mark> class Nef2Mesh
// Ugh, how much of this stuff do we need
typedef typename Nef_3::SNC_structure
SNC_structure;
typedef typename SNC_structure::SNC_decorator
SNC_decorator;
typedef typename CGAL::SNC_const_decorator<SNC_structure>
SNC_const_decorator;
typedef typename SNC_structure::Sphere_point Sphere_point;
typedef typename SNC_structure::Sphere_segment
Sphere_segment;
typedef typename SNC_structure::Sphere_circle
Sphere_circle;
typedef typename SNC_structure::Vertex_base Vertex;
typedef typename SNC_structure::Halfedge_base Halfedge;
typedef typename SNC_structure::Halffacet_base Halffacet;
typedef typename SNC_structure::Volume_base Volume;
typedef typename SNC_structure::Vertex_const_handle
Vertex_const_handle;
typedef typename SNC_structure::Halfedge_const_handle
Halfedge_const_handle;
typedef typename SNC_structure::Halffacet_const_handle
Halffacet_const_handle;
typedef typename SNC_structure::Volume_const_handle
Volume_const_handle;
typedef typename SNC_structure::SHalfedge_around_svertex_circulator
SHalfedge_around_svertex_circulator;
typedef typename SNC_structure::SHalfedge_around_svertex_const_circulator
SHalfedge_around_svertex_const_circulator;
typedef typename SNC_structure::SHalfedge_around_facet_circulator
SHalfedge_around_facet_circulator;
typedef typename SNC_structure::SHalfedge_around_facet_const_circulator
SHalfedge_around_facet_const_circulator;
typedef typename SNC_structure::SHalfedge_around_sface_const_circulator
SHalfedge_around_sface_const_circulator;
typedef typename SNC_structure::Halffacet_cycle_const_iterator
Halffacet_cycle_const_iterator;
typedef typename SNC_structure::Halffacet_cycle_iterator
Halffacet_cycle_iterator;
typedef typename SNC_structure::Infi_box Infi_box;
typedef typename SNC_structure::Size_type Size_type;
typedef Size_type size_type;
typedef typename SNC_decorator::Vertex_iterator Vertex_iterator;
typedef typename SNC_decorator::Halfedge_iterator
Halfedge_iterator;
typedef typename SNC_decorator::Halffacet_iterator
Halffacet_iterator;
typedef typename SNC_structure::Shell_entry_iterator
Shell_entry_iterator;
typedef typename SNC_decorator::Volume_iterator Volume_iterator;
typedef typename SNC_structure::Vertex_const_iterator
Vertex_const_iterator;
typedef typename SNC_structure::Halfedge_const_iterator
Halfedge_const_iterator;
typedef typename SNC_structure::Halffacet_const_iterator
Halffacet_const_iterator;
typedef typename SNC_structure::Volume_const_iterator
Volume_const_iterator;
typedef typename SNC_structure::Shell_entry_const_iterator
Shell_entry_const_iterator;
typedef typename SNC_decorator::SFace_cycle_const_iterator
SFace_cycle_const_iterator;
typedef typename SNC_decorator::Association Association;
typedef typename SNC_structure::Sphere_map Sphere_map;
typedef CGAL::SM_decorator<Sphere_map> SM_decorator;
typedef CGAL::SM_const_decorator<Sphere_map> SM_const_decorator;
typedef CGAL::SM_point_locator<SNC_structure> SM_point_locator;
typedef typename SM_decorator::SVertex_const_handle
SVertex_const_handle;
typedef typename SM_decorator::SHalfedge_const_handle
SHalfedge_const_handle;
typedef typename SM_decorator::SHalfloop_const_handle
SHalfloop_const_handle;
typedef typename SM_decorator::SFace_const_handle
SFace_const_handle;
typedef typename Kernel::Point_3 Point_3;
typedef typename Kernel::Plane_3 Plane_3;
typedef typename Kernel::Vector_3 Vector_3;
typedef typename Kernel::Segment_3 Segment_3;
SNC_const_decorator& scd;
CGAL::Object_index<Vertex_const_iterator> VI;
public:
//Ctor
Nef2Mesh(SNC_const_decorator& s) :
scd(s), VI(s.vertices_begin(),s.vertices_end(),'V') {}
// Perform operation
void operator()(BGT_Mesh &out_mesh) {
out_mesh.Clear();
// Apparently, number of irrelevant volumes to skip. Depends on
kernel.
int skip_volumes = Infi_box::extended_kernel() ? 2 : 1;
CGAL_assertion_msg (skip_volumes == 1, "Doubt that we can handle
extended kernel");
// Would be nice if BGT_Mesh had Reserve() functionality for vert,
facet
// data structures.
BGT_Mesh::BatchMode bm(&out_mesh);
// Populate vertices
Vertex_const_iterator v;
CGAL_forall_vertices(v,scd) {
if(Infi_box::is_standard(v->point())) {
// Add to mesh
const Point_3 &point = v->point();
BGT_V4 vert =
BGT_V4_Construct((float)::CGAL::to_double(point.x()),
(float)::CGAL::to_double(point.y()),
(float)::CGAL::to_double(point.z()));
// Add to object index
VI[v] = out_mesh.AddVertex(vert);
#ifdef _MATERIAL_MARKING_
// Create blind data for userdata
int newIndex = out_mesh.CreateBlindData("texture", 32);
// Later code will assume index zero for this
CGAL_assertion_msg(newIndex == 0, "Must provide mesh with no blind
data");
// To prevent thrashing, initialize the blind data size to
something reasonable
// 2 * numvertices seems like a reasonable upper bound (can't find
literature on this!)
out_mesh.GetBlindData()[0]->SetElement(out_mesh.GetNumVertices() *
2, 0);
#endif
Visitor V(out_mesh,scd,VI);
Volume_const_handle c;
CGAL_forall_volumes(c,scd)
// if(skip_volumes-- <= 0)
for(Shell_entry_const_iterator shei = c->shells_begin();
shei != c->shells_end(); ++shei)
scd.visit_shell_objects(SFace_const_handle(shei),V);
class Visitor
typedef typename CGAL::Triangulation_euclidean_traits_xy_3<Kernel>
XY;
typedef typename CGAL::Triangulation_euclidean_traits_yz_3<Kernel>
YZ;
typedef typename CGAL::Triangulation_euclidean_traits_xz_3<Kernel>
XZ;
const CGAL::Object_index<Vertex_const_iterator>& VI;
SNC_const_decorator& D;
BGT_Mesh &m_mesh;
public:
Visitor(BGT_Mesh &out_mesh,
SNC_const_decorator& sd,
CGAL::Object_index<Vertex_const_iterator>& vi) : VI(vi),
m_mesh(out_mesh), D(sd){}
void visit(Halffacet_const_handle opposite_facet) {
CGAL_NEF_TRACEN("Build_polyhedron: visit facet " <<
opposite_facet->plane());
CGAL_assertion(Infi_box::is_standard(opposite_facet->plane()));
SHalfedge_const_handle se;
Halffacet_cycle_const_iterator fc;
Halffacet_const_handle f = opposite_facet->twin();
sfc1(f->facet_cycles_begin()), sfc2(sfc1);
const Mark &mark = sfc1->mark();
if(++f->facet_cycles_begin() != f->facet_cycles_end() ||
++(++(++sfc1)) != sfc2) {
Vector_3 orth = f->plane().orthogonal_vector();
int c = CGAL::abs(orth[0]) > CGAL::abs(orth[1]) ? 0 : 1;
c = CGAL::abs(orth[2]) > CGAL::abs(orth[c]) ? 2 : c;
if(c == 0) {
Triangulation_handler2<YZ> th(f, mark);
th.handle_triangles(m_mesh, VI);
} else if(c == 1) {
Triangulation_handler2<XZ> th(f, mark);
} else if(c == 2) {
Triangulation_handler2<XY> th(f, mark);
} else
CGAL_assertion_msg(false, "wrong value");
} else {
// We expect 3 verts
int vertIndices[3];
int currIndex = 0;
fc = f->facet_cycles_begin();
se = SHalfedge_const_handle(fc);
CGAL_assertion(se!=0);
SHalfedge_around_facet_const_circulator hc_start(se);
SHalfedge_around_facet_const_circulator hc_end(hc_start);
CGAL_For_all(hc_start,hc_end) {
CGAL_NEF_TRACEN(" add vertex " <<
hc_start->source()->center_vertex()->point());
CGAL_assertion_msg(currIndex < 3, "more than 3 verts in
facet!");
vertIndices[currIndex++] =
VI[hc_start->source()->center_vertex()];
CGAL_assertion_msg(currIndex == 3, "Facet not a triangle");
int newPoly = m_mesh.AddPolygon(&vertIndices[0], 3);
BGT_BlindData *bd = m_mesh.GetBlindData()[0];
CGAL_assertion_msg(bd != NULL, "Blind data hasn't been
created for input mesh!");
bd->SetElement(newPoly,
(BGT_BlindData::DataValueType)mark.m_userdata);
#endif
void visit(SFace_const_handle) {}
void visit(Halfedge_const_handle) {}
void visit(Vertex_const_handle) {}
void visit(SHalfedge_const_handle) {}
void visit(SHalfloop_const_handle) {}
template<typename Kernel>
class Triangulation_handler2 {
typedef typename CGAL::Triangulation_vertex_base_2<Kernel>
Vb;
typedef typename
CGAL::Constrained_triangulation_face_base_2<Kernel> Fb;
typedef typename CGAL::Triangulation_data_structure_2<Vb,Fb>
TDS;
typedef typename CGAL::Constrained_triangulation_2<Kernel,TDS>
CT;
typedef typename CT::Face_handle Face_handle;
typedef typename CT::Vertex_handle CTVertex_handle;
typedef typename CT::Finite_faces_iterator Finite_face_iterator;
typedef typename CT::Edge Edge;
CT ct;
CGAL::Unique_hash_map<Face_handle, bool> visited;
CGAL::Unique_hash_map<CTVertex_handle, Vertex_const_handle> ctv2v;
Finite_face_iterator fi;
const Mark &m_mark;
Plane_3 supporting_plane;
public:
Triangulation_handler2(Halffacet_const_handle f, const Mark &mark)
visited(false), supporting_plane(f->plane()), m_mark(mark) {
Halffacet_cycle_const_iterator fci;
for(fci=f->facet_cycles_begin(); fci!=f->facet_cycles_end();
++fci) {
if(fci.is_shalfedge()) {
SHalfedge_around_facet_const_circulator sfc(fci),
send(sfc);
CGAL_For_all(sfc,send) {
CGAL_NEF_TRACEN(" insert point" <<
sfc->source()->source()->point());
CTVertex_handle ctv =
ct.insert(sfc->source()->source()->point());
ctv2v[ctv] = sfc->source()->source();
++fci) {
send(sfc);
CGAL_NEF_TRACEN(" insert constraint" <<
sfc->source()->twin()->source()->point());
ct.insert_constraint(sfc->source()->source()->point(),
CGAL_assertion(ct.is_valid());
CGAL_NEF_TRACEN("number of finite triangles " <<
ct.number_of_faces());
typename CT::Face_handle infinite = ct.infinite_face();
typename CT::Vertex_handle ctv = infinite->vertex(1);
if(ct.is_infinite(ctv)) ctv = infinite->vertex(2);
CGAL_assertion(!ct.is_infinite(ctv));
typename CT::Face_handle opposite;
typename CT::Face_circulator vc(ctv,infinite);
do { opposite = vc++;
} while(!ct.is_constrained(typename
CT::Edge(vc,vc->index(opposite))));
typename CT::Face_handle first = vc;
CGAL_assertion(!ct.is_infinite(first));
traverse_triangulation(first, first->index(opposite));
fi = ct.finite_faces_begin();
void traverse_triangulation(Face_handle f, int parent) {
visited[f] = true;
if(!ct.is_constrained(Edge(f,ct.cw(parent))) &&
!visited[f->neighbor(ct.cw(parent))]) {
Face_handle child(f->neighbor(ct.cw(parent)));
traverse_triangulation(child, child->index(f));
if(!ct.is_constrained(Edge(f,ct.ccw(parent))) &&
!visited[f->neighbor(ct.ccw(parent))]) {
Face_handle child(f->neighbor(ct.ccw(parent)));
template<typename Triangle_3>
bool get_next_triangle(Triangle_3& tr) {
while(fi != ct.finite_faces_end() && visited[fi] == false)
++fi;
if(fi == ct.finite_faces_end()) return false;
tr = Triangle_3(fi->vertex(0)->point(),
fi->vertex(1)->point(), fi->vertex(2)->point());
++fi;
return true;
bool same_orientation(Plane_3 p1) const {
if(p1.a() != 0)
return CGAL::sign(p1.a()) ==
CGAL::sign(supporting_plane.a());
if(p1.b() != 0)
return CGAL::sign(p1.b()) ==
CGAL::sign(supporting_plane.b());
return CGAL::sign(p1.c()) == CGAL::sign(supporting_plane.c());
template<typename Index>
void handle_triangles(BGT_Mesh &out_mesh, Index& VI) {
++fi;
while(fi != ct.finite_faces_end()) {
Plane_3 plane(fi->vertex(0)->point(),
// Add a triangle
int vertIndices[3];
vertIndices[0] = VI[ctv2v[fi->vertex(0)]];
if(same_orientation(plane)) {
vertIndices[1] = VI[ctv2v[fi->vertex(1)]];
vertIndices[2] = VI[ctv2v[fi->vertex(2)]];
} else {
vertIndices[1] = VI[ctv2v[fi->vertex(2)]];
vertIndices[2] = VI[ctv2v[fi->vertex(1)]];
int newPoly = out_mesh.AddPolygon(&vertIndices[0], 3);
BGT_BlindData *bd = out_mesh.GetBlindData()[0];
(BGT_BlindData::DataValueType)m_mark.m_userdata);
#endif
do {
++fi;
} while(fi != ct.finite_faces_end() && visited[fi] ==
false);
- Re: [cgal-discuss] Nef Polyhedron no simple to OFF, (continued)
- Re: [cgal-discuss] Nef Polyhedron no simple to OFF, Pierre Alliez, 12/09/2008
- Re: [cgal-discuss] Nef Polyhedron no simple to OFF, Peter Hachenberger, 12/10/2008
- [cgal-discuss] A problem with iso oriented box intersection package, BBB HHH, 12/10/2008
- Re: [cgal-discuss] A problem with iso oriented box intersection package, Pierre Alliez, 12/10/2008
- Re : [cgal-discuss] A problem with iso oriented box intersection package, BBB HHH, 12/11/2008
- Re: [cgal-discuss] A problem with iso oriented box intersection package, Andreas Fabri, 12/10/2008
- Re : [cgal-discuss] A problem with iso oriented box intersection package, BBB HHH, 12/10/2008
- Re: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, jona_100, 12/10/2008
- RE: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, Fred Dorosh, 12/10/2008
- Re: RE: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, jona_100, 12/11/2008
- Re: RE: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, dekosser, 12/11/2008
- Re: Re: RE: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, jona_100, 12/17/2008
- Re: Re: Re: RE: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, jona_100, 12/18/2008
- Re: Re: Re: RE: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, dekosser, 12/18/2008
- Re: [cgal-discuss] Nef Polyhedron no simple to OFF, Laurent Rineau (GeometryFactory), 12/18/2008
- Re: [cgal-discuss] Nef Polyhedron no simple to OFF, Pierre Alliez, 12/18/2008
- Re: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, jona_100, 12/19/2008
- Re: [cgal-discuss] Nef Polyhedron no simple to OFF, Pierre Alliez, 12/19/2008
- Re: Re: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, jona_100, 12/19/2008
- Re: [cgal-discuss] Nef Polyhedron no simple to OFF, Laurent Rineau (GeometryFactory), 12/19/2008
- Re: Re: [cgal-discuss] Nef Polyhedron no simple to OFF, jona_100, 12/22/2008
