- To:
- Subject: Re: [cgal-discuss] performance of Delaunay Triangulation of random
- Date: Sat, 20 Dec 2008 17:39:38 +0100
- Organization: INRIA
Hi,
Ding wrote:
There are some statements saying that CGAL can perform 3D DT of 1M random
points under 20 sec (13 or 16 sec). However, I tried the example provided in
the CGAL manual, 3D DT of only 0.125M points took 52.59 sec on a 2.13 GHz Core
2 Duo computer with 2G memory (Mac OSX 10.5). So I'm just wondering if any
options need to be set for better performance. Thank you!
You are not using random points.
Points on a grid may exhibit worse performance than random distributions.
Moreover, you do not mention the compiler optimization you use.
Best is something like -O2 -DNDEBUG.
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
smime.p7s
Description: S/MIME Cryptographic Signature
- [cgal-discuss] performance of Delaunay Triangulation of random 3D points, Ding, 12/20/2008
- Re: [cgal-discuss] performance of Delaunay Triangulation of random, Sylvain Pion, 12/20/2008
- [cgal-discuss] about using qt3 to dislay a triangulation generated, Kwok Jasper, 12/20/2008
- Re: [cgal-discuss] about using qt3 to dislay a triangulation generated, Laurent Rineau (GeometryFactory), 12/20/2008
- RE: [cgal-discuss] about using qt3 to dislay a triangulation, Kwok Jasper, 12/21/2008
- Re: [cgal-discuss] about using qt3 to dislay a triangulation, Andreas Fabri, 12/21/2008
- Re: [cgal-discuss] performance of Delaunay Triangulation of random, Ben Supnik, 12/20/2008
- Re: [cgal-discuss] performance of Delaunay Triangulation of random, Ding, 12/20/2008
