cgal-discuss - [cgal-discuss] about using qt3 to dislay a triangulation generated
  • To: <>
  • Subject: [cgal-discuss] about using qt3 to dislay a triangulation generated
  • Date: Sun, 21 Dec 2008 00:46:32 +0800
  • Importance: Normal
Excuse me, may I ask something about using Qt3.2.1 Non-commercial with CGAL?
I have installed Qt3.2.1 non-commercial and CGAL
then, when I tried to complie the code in Miscosoft Visual C++ 2005, I get the following error
error LNK2019: 無法解析的外部符號 "__declspec(dllimport) public: virtual __thiscall QApplication::~QApplication(void)" () 在函式 _main 中被參考 tr.obj
I am using the code below which is from the official web site of CGAL. May I ask what can I do to deal with the above error?
Thank you very much.
#include <CGAL/Cartesian.h>
#include <CGAL/Point_2.h>
#include <CGAL/Delaunay_triangulation_2.h>
#include <CGAL/IO/Qt_widget_Delaunay_triangulation_2.h>
#include <CGAL/IO/Qt_widget.h>
#include <CGAL/IO/Qt_widget_layer.h>
#include <qapplication.h>
typedef CGAL::Cartesian<double>             Rep;
typedef CGAL::Point_2<Rep>                  Point;
typedef CGAL::Delaunay_triangulation_2<Rep> Delaunay;
Delaunay dt;
class My_layer : public CGAL::Qt_widget_layer{
  void draw(){
    *widget << dt;
class My_window : public CGAL::Qt_widget {
public:
  My_window(int x, int y)
    resize(x,y);
    attach(&layer);
private:
  //this method is called when the user presses the mouse
  void mousePressEvent(QMouseEvent *e)
    Qt_widget::mousePressEvent(e);
    dt.insert(Point(x_real(e->x()), y_real(e->y())));
    redraw();
  My_layer layer;
int main( int argc, char **argv )
    QApplication app( argc, argv );
    My_window *W = new My_window(400,400);
    app.setMainWidget(W);
    W->show();
    W->set_window(0, 400, 0, 400);
    return app.exec();
想同MSN Buddy傾計了解佢多d? 參觀MSN Buddy部屋啦!
