cgal-discuss - Re: [cgal-discuss] about using qt3 to dislay a triangulation
  • To:
  • Subject: Re: [cgal-discuss] about using qt3 to dislay a triangulation
  • Date: Sun, 21 Dec 2008 11:08:02 +0100
Kwok Jasper wrote:
> Thank you very much for your reply.
> May I ask for something about the istallation of the CGAL3.4 ?
> In the installation manual, it said that the configuration has to be
> done using cmake.
Please have a look at the installation manual
http://www.cgal.org/Manual/3.4/doc_html/installation_manual/Chapter_installation_manual.html#Subsection_2.2
where we write:
2.2 cmake
In order to configure, build and install the CGAL libraries, as well as the
examples and demos, you need CMake, a cross-platform ``makefile generator''.
If CMake is not
installed already you can obtain it from http://www.cmake.org/. We recommend
the usage of CMake release 2.6, and you need at least CMake release
2.4-patch-7.
Best regards,
andreas
> But I cannot find cmake-gui inside the package on the CGAL3.4.
> And when I typed cmake-gui in the cmd of the window XP, nothing happen.
> May I ask if the cmake-gui is something that I should download somewhere
> in the Internet?
> Thank you very much
> From:
> To:
> Date: Sat, 20 Dec 2008 18:58:50 +0100
> generated
> On Saturday 20 December 2008 17:46:32 Kwok Jasper wrote:
> > Excuse me, may I ask something about using Qt3.2.1 Non-commercial with
> > CGAL?
> > I have installed Qt3.2.1 non-commercial and CGAL
> > then, when I tried to complie the code in Miscosoft Visual C++ 2005,
> I get
> > the following errorerror LNK2019: 無法解析的外部符號
> "__declspec(dllimport) public:
> > virtual __thiscall QApplication::~QApplication(void)"
> (__imp_??1QApplication@@UAE@XZ)
> 在函式 _main 中被參考 tr.obj
> You need to recompile Qt3 non-commercial using Visual C++. The one you
> use is probably for MinGW (a sort of g++ compiler, for Windows), and
> that version is not binary-compatible with C++ code made by Visual C++.
> Unfortunately, Trolltech does not support the compilation of Qt3
> non-commercial using Visual. You will need to find patches on the Internet.
> Are you stuck with Qt3 ? The free version of Qt4 is quite easily
> compilable using Visual C++. Next release of CGAL, 3.4, has some demos
> that have been reworked with Qt4. The 2D Triangulation demo has been is
> now using Qt4. A beta version of CGAL-3.4 has been released yesterday.
> If you feel sufficiently adventurous to test a beta software, maybe you
> will be more successful with that new versions of CGAL and Qt
> Laurent Rineau, PhD
> Engineer at GeometryFactory
> http://www.geometryfactory.com/
