- To:
- Subject: Re: [cgal-discuss] performance of Delaunay Triangulation of random
- Date: Sat, 20 Dec 2008 11:42:55 -0500
Hi df,
In my work with the 2-d DT code in CGAL I found that the insert order of the points makes an immense difference in performance!
Unfortunately, I tuned my DT code almost 3 years ago and do not exactly remember what I found. :-(
But...if I remember correctly, Dt insertion is much faster when inserting a point into a "relatively small" bounded area of the mesh...and inserting points outside mesh is slow.
I think that if you insert a point in at triangle, the mese locally produces three sub triangles, and then does a localized bunch of edge-flips.
By comparison, if you insert a point outside the mesh (which is a convex hull) then the code must calculate "visibility" around the entire hull and build a potentially large number of triangles which will all get nuked later as you insert your points.
My point set was a sub-sampling of a regular grid, so I used sort of an Adam-7-like iteration to build the bounds first, then course grids, then the bulk points. The result was that most inserts were local and much faster.
(My code inserts the points one at a time - I do not know if the bulk inserter attempts to do something smarter.)
Now that is all 2-d, and probably wrong since it is from memory, but...looking at your in-order nested for loop definitely jogged my memory. (My first attempt was to iterate across my grid in order and insert each "keeper" point, and it was sloooow.)
So...perhaps experiment with different ordering of the points and time the results?
The other issue would be (and this is not as much a factor with DT as other parts of CGAL) to check your optimizer and #define settings carefully...you'll want to make sure that all condition checking is compiled out and that the optimizer is inlining...from what I can tell GCC on OS X won't inline if the optimizer is off, which makes virtually any template code under-perform.
cheers
Ben
Ding wrote:
Dear all,
There are some statements saying that CGAL can perform 3D DT of 1M random
points under 20 sec (13 or 16 sec). However, I tried the example provided in
the CGAL manual, 3D DT of only 0.125M points took 52.59 sec on a 2.13 GHz Core
2 Duo computer with 2G memory (Mac OSX 10.5). So I'm just wondering if any
options need to be set for better performance. Thank you!
The testing code is as follows, which is almost the same as provided in the
manual.
/******************* code begin *******************/
#include <CGAL/Delaunay_triangulation_3.h>
#include <CGAL/Triangulation_hierarchy_3.h>
#include <cassert>
#include <vector>
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Triangulation_vertex_base_3<K> Vb;
typedef CGAL::Triangulation_hierarchy_vertex_base_3<Vb> Vbh;
typedef CGAL::Triangulation_data_structure_3<Vbh> Tds;
typedef CGAL::Delaunay_triangulation_3<K,Tds> Dt;
typedef CGAL::Triangulation_hierarchy_3<Dt> Dh;
typedef Dh::Finite_vertices_iterator Finite_vertices_iterator;
typedef Dh::Vertex_handle Vertex_handle;
typedef Dh::Point Point;
#include <boost/progress.hpp>
int main()
// generating points on a grid.
std::vector<Point> P;
for (int z=0 ; z<50 ; z++)
for (int y=0 ; y<50 ; y++)
for (int x=0 ; x<50 ; x++)
P.push_back(Point(x,y,z));
Dh T;
boost::progress_timer timer(std::cout);
T.insert (P.begin(), P.end());
return 0;
/******************* code end *******************/
regards,
df
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://xplanescenery.blogspot.com/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list:
Developer mailing list:
- [cgal-discuss] performance of Delaunay Triangulation of random 3D points, Ding, 12/20/2008
- Re: [cgal-discuss] performance of Delaunay Triangulation of random, Sylvain Pion, 12/20/2008
- [cgal-discuss] about using qt3 to dislay a triangulation generated, Kwok Jasper, 12/20/2008
- Re: [cgal-discuss] about using qt3 to dislay a triangulation generated, Laurent Rineau (GeometryFactory), 12/20/2008
- RE: [cgal-discuss] about using qt3 to dislay a triangulation, Kwok Jasper, 12/21/2008
- Re: [cgal-discuss] about using qt3 to dislay a triangulation, Andreas Fabri, 12/21/2008
- Re: [cgal-discuss] performance of Delaunay Triangulation of random, Ben Supnik, 12/20/2008
- Re: [cgal-discuss] performance of Delaunay Triangulation of random, Ding, 12/20/2008
