- To:
- Subject: Re: Re: [cgal-discuss] Progressive Mesh
- Date: Sat, 24 Jan 2009 08:39:25 +0100 (CET)
Pierre,
Thanks for the suggestion, but this is not really what I mean by the term
progressive mesh. Rather, what I meant was the progressive mesh structure
introduced by Hoppe
(http://research.microsoft.com/en-us/um/people/hoppe/proj/pm). Basically, the
reason I asked on the CGAL discuss list is because it seems like CGAL takes on
part of the way to implementing this structure. Namely, they provide the
EdgeCollapsable mesh concept. I was just curious how difficult it would be to
implement and properly keep track of the edge collapses and to reintroduce
removed vertices with a vertex split. I also wanted to see if anyone else had
done this, as I see no real use in re-inventing the wheel.
Thanks,
Rob
- [cgal-discuss] Progressive Mesh, rob.patro, 01/22/2009
- Re: [cgal-discuss] Progressive Mesh, Pierre JUILLARD, 01/23/2009
- Re: Re: [cgal-discuss] Progressive Mesh, rob.patro, 01/24/2009
- [cgal-discuss] Polyhedron demo problem, Rob, 01/24/2009
- Re: [cgal-discuss] Polyhedron demo problem, Laurent Rineau (GeometryFactory), 01/25/2009
- Re: [cgal-discuss] Polyhedron demo problem, Rob, 01/25/2009
- Re: [cgal-discuss] Polyhedron demo problem, Laurent Rineau (GeometryFactory), 01/26/2009
- Re: [cgal-discuss] Polyhedron demo problem, Rob, 01/26/2009
- Re: Re: [cgal-discuss] Progressive Mesh, Pierre JUILLARD, 01/25/2009
- Re: [cgal-discuss] Progressive Mesh, Rob, 01/25/2009
- Re: [cgal-discuss] Progressive Mesh, Andreas Fabri, 01/25/2009
- Re: [cgal-discuss] Progressive Mesh, Rob Patro, 01/26/2009
