- To:
- Subject: Re: [cgal-discuss] Polyhedron demo problem
- Date: Mon, 26 Jan 2009 00:11:17 +0100
On Sunday 25 January 2009 22:09:45 Rob wrote:
> Laurent Rineau (GeometryFactory) wrote:
> > On Saturday 24 January 2009 17:44:12 Rob wrote:
> >> Hello,
> >> I seem to have a problem linking the Polyhedron demo in the 3.4
> >> release of CGAL. When I try to make the demo in /demo/Polyhedron, it
> >> compiles successfully, but then gives the following error during
> >> linking:
> >> CMakeFiles/Polyhedron_3.dir/Polyhedron_3.o: In function
> >> `CGAL::Monge_via_jet_fitting<CGAL::Filtered_kernel<CGAL::Simple_cartesia
> >>n<d ouble>
> >>> , CGAL::Cartesian<double>,
> >> CGAL::Lapack_svd>::solve_linear_system(CGAL::Lapack_matrix&,
> >> CGAL::Lapack_vector&)':
> >> Polyhedron_3.cpp:(.text._ZN4CGAL21Monge_via_jet_fittingINS_15Filtered_ke
> >>rne
> >> lINS_16Simple_cartesianIdEEEENS_9CartesianIdEENS_10Lapack_svdEE19solve_l
> >>inea
> >> r_systemERNS_13Lapack_matrixERNS_13Lapack_vectorE[CGAL::Monge_via_jet_fi
> >>ttin g<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> >> CGAL::Lapack_vector&)]+0x94): undefined reference to `dgelss'
> >> collect2: ld returned 1 exit status
> >> make[2]: *** [demo/Polyhedron/Polyhedron_3] Error 1
> >> make[2]: Leaving directory `/home/rob/SoftwareStaging/CGAL-3.4/build'
> >> make[1]: *** [demo/Polyhedron/CMakeFiles/Polyhedron_3.dir/all] Error 2
> >> make[1]: Leaving directory `/home/rob/SoftwareStaging/CGAL-3.4/build'
> >> make: *** [all] Error 2
> >> I've checked multiple times, and I configure cmake with lapack, so I
> >> can't figure out why it's complaining at me. Any help would be greatly
> >> appreciated.
> > Can you show us the output of cmake, and attach your CMakeCache.txt file?
> > It seems LAPACK is not configured correctly.
Rob,
I think the bug is my fault. The file demo/Polyhedron/CMakeList.txt does not
deal correctly with case when LAPACK is present but not TAUCS.
Please try to copy the attached CMakeLists.txt to
demo/Polyhedron/CMakeList.txt and recompile the Polyhedron demo, and tell us
if that fixes your linkage problem.
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
# This is the CMake script for compiling the CGAL Polyhedron demo. project( Polyhedron ) cmake_minimum_required(VERSION 2.4.5) set(CMAKE_ALLOW_LOOSE_LOOP_CONSTRUCTS true) #option(POLYHEDRON_DEMO_ENABLE_FORWARD_DECL "In the Polyhedron demo, enable " OFF) #mark_as_advanced(POLYHEDRON_DEMO_ENABLE_FORWARD_DECL) if(COMMAND cmake_policy) cmake_policy(SET CMP0003 NEW) endif(COMMAND cmake_policy) foreach(INCDIR ./include ../../../AABB_tree/include ../../../STL_Extension/include ../../../GraphicsView/include ../../../Surface_mesher/include ../../../filtered_kernel/include ) if(EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/${INCDIR}") include_directories (BEFORE "${CMAKE_CURRENT_SOURCE_DIR}/${INCDIR}") endif() endforeach() include_directories( ./ ) # Find CGAL and CGAL Qt4 find_package(CGAL COMPONENTS Qt4) include( ${CGAL_USE_FILE} ) # Find Qt4 itself set( QT_USE_QTXML TRUE ) set( QT_USE_QTMAIN TRUE ) set( QT_USE_QTSCRIPT TRUE ) set( QT_USE_QTOPENGL TRUE ) find_package(Qt4) # Find OpenGL find_package(OpenGL) # Find QGLViewer if(QT4_FOUND) include(${QT_USE_FILE}) find_package(QGLViewer ) endif(QT4_FOUND) # Find LAPACK (optional), for curvatures estimation find_package(LAPACK) # Find TAUCS (optionnal), for parametrization find_package(TAUCS) if(CGAL_Qt4_FOUND AND QT4_FOUND AND OPENGL_FOUND AND QGLVIEWER_FOUND) include_directories ( ${QGLVIEWER_INCLUDE_DIR} ) if(LAPACK_FOUND) include( ${LAPACK_USE_FILE} ) add_definitions(-DCGAL_LAPACK_ENABLED) else(LAPACK_FOUND) message(STATUS "warning: LAPACK is not found. curvatures estimation will not be available.") endif(LAPACK_FOUND) if(TAUCS_FOUND) include( ${TAUCS_USE_FILE} ) add_definitions(-DCGAL_TAUCS_ENABLED) else(TAUCS_FOUND) message(STATUS "warning: TAUCS is not found. parametrization will not be available.") endif(TAUCS_FOUND) qt4_wrap_ui( UI_FILES MainWindow.ui ) include(AddFileDependencies) qt4_generate_moc( "${CMAKE_CURRENT_SOURCE_DIR}/MainWindow.h" MainWindow_moc.cpp ) add_file_dependencies( MainWindow_moc.cpp "${CMAKE_CURRENT_SOURCE_DIR}/MainWindow.h" ) qt4_generate_moc( "${CMAKE_CURRENT_SOURCE_DIR}/Viewer.h" Viewer_moc.cpp ) add_file_dependencies( Viewer_moc.cpp "${CMAKE_CURRENT_SOURCE_DIR}/Viewer.h" ) qt4_generate_moc( "${CMAKE_CURRENT_SOURCE_DIR}/Scene.h" Scene_moc.cpp ) add_file_dependencies( Scene_moc.cpp "${CMAKE_CURRENT_SOURCE_DIR}/Scene.h" ) qt4_add_resources ( RESOURCE_FILES Polyhedron_3.qrc ) if(POLYHEDRON_DEMO_ENABLE_FORWARD_DECL) add_definitions(-DUSE_FORWARD_DECL) add_executable ( Polyhedron_3 MainWindow.cpp Polyhedron_3.cpp Viewer.cpp Scene.cpp Scene_nef_polyhedron_operations.cpp Scene_polyhedron_operations.cpp Scene_nef_and_polyhedron_operations.cpp Scene_rendering.cpp Scene_nef_rendering.cpp MainWindow_boolean_operations.cpp MainWindow_convex_hull.cpp MainWindow_curvature_estimation.cpp MainWindow_inside_out.cpp MainWindow_kernel.cpp MainWindow_pca.cpp MainWindow_remeshing.cpp MainWindow_self_intersection.cpp MainWindow_simplify.cpp MainWindow_subdivision_methods.cpp MainWindow_parameterization.cpp MainWindow_moc.cpp Scene_moc.cpp Viewer_moc.cpp texture.cpp ${UI_FILES} ${RESOURCE_FILES} ) if(TAUCS_FOUND) add_executable( Polyhedron_3 Scene_tex_rendering.cpp Scene_tex_polyhedron_operations.cpp ) endif() else(POLYHEDRON_DEMO_ENABLE_FORWARD_DECL) add_file_dependencies( Polyhedron_3.cpp "${CMAKE_CURRENT_BINARY_DIR}/MainWindow_moc.cpp" "${CMAKE_CURRENT_BINARY_DIR}/Scene_moc.cpp" "${CMAKE_CURRENT_BINARY_DIR}/Viewer_moc.cpp" ) add_executable ( Polyhedron_3 Polyhedron_3.cpp ${UI_FILES} ${RESOURCE_FILES} ) endif(POLYHEDRON_DEMO_ENABLE_FORWARD_DECL) # Link with Qt libraries target_link_libraries( Polyhedron_3 ${QT_LIBRARIES} ) # Link with CGAL target_link_libraries( Polyhedron_3 ${CGAL_LIBRARIES} ${CGAL_3RD_PARTY_LIBRARIES} ) # Link with libQGLViewer, OpenGL target_link_libraries( Polyhedron_3 ${QGLVIEWER_LIBRARIES} ${OPENGL_gl_LIBRARY} ${OPENGL_glu_LIBRARY} ) add_to_cached_list( CGAL_EXECUTABLE_TARGETS Polyhedron_3 ) else (CGAL_Qt4_FOUND AND QT4_FOUND AND OPENGL_FOUND AND QGLVIEWER_FOUND) set(POLYHEDRON_MISSING_DEPS "") if(NOT CGAL_Qt4_FOUND) set(POLYHEDRON_MISSING_DEPS "the CGAL Qt4 library, ${POLYHEDRON_MISSING_DEPS}") endif() if(NOT QT4_FOUND) set(POLYHEDRON_MISSING_DEPS "Qt4, ${POLYHEDRON_MISSING_DEPS}") endif() if(NOT OPENGL_FOUND) set(POLYHEDRON_MISSING_DEPS "OpenGL, ${POLYHEDRON_MISSING_DEPS}") endif() if(NOT QGLVIEWER_FOUND) set(POLYHEDRON_MISSING_DEPS "QGLViewer, ${POLYHEDRON_MISSING_DEPS}") endif() message(STATUS "NOTICE: This demo requires ${POLYHEDRON_MISSING_DEPS}and will not be compiled.") endif (CGAL_Qt4_FOUND AND QT4_FOUND AND OPENGL_FOUND AND QGLVIEWER_FOUND)
- [cgal-discuss] Progressive Mesh, rob.patro, 01/22/2009
- Re: [cgal-discuss] Progressive Mesh, Pierre JUILLARD, 01/23/2009
- Re: Re: [cgal-discuss] Progressive Mesh, rob.patro, 01/24/2009
- [cgal-discuss] Polyhedron demo problem, Rob, 01/24/2009
- Re: [cgal-discuss] Polyhedron demo problem, Laurent Rineau (GeometryFactory), 01/25/2009
- Re: [cgal-discuss] Polyhedron demo problem, Rob, 01/25/2009
- Re: [cgal-discuss] Polyhedron demo problem, Laurent Rineau (GeometryFactory), 01/26/2009
- Re: [cgal-discuss] Polyhedron demo problem, Rob, 01/26/2009
- Re: Re: [cgal-discuss] Progressive Mesh, Pierre JUILLARD, 01/25/2009
- Re: [cgal-discuss] Progressive Mesh, Rob, 01/25/2009
- Re: [cgal-discuss] Progressive Mesh, Andreas Fabri, 01/25/2009
- Re: [cgal-discuss] Progressive Mesh, Rob Patro, 01/26/2009
- Re: [cgal-discuss] Progressive Mesh, Fernando Cacciola, 01/26/2009
- Re: [cgal-discuss] Progressive Mesh, Rob, 01/27/2009
- Re: [cgal-discuss] Progressive Mesh, Rob Patro, 01/27/2009
- Re: [cgal-discuss] Progressive Mesh, Fernando Cacciola, 01/27/2009
