- To:
- Subject: Re: [cgal-discuss] Progressive Mesh
- Date: Tue, 27 Jan 2009 19:36:10 -0200
Hi Rob,
More precisely, I can't seem to get a good handle on what from the
EdgeProfile is modified during the collapse.
The EdgeProfile is local cached "view" of the mesh around the collapsing edge.
After the collapse, there is no *explicit* guarantee for the validity of the cached elements, just like an iterator over a std::vector might or might be valid after removal.
> The EdgeProfile is passed
to the OnCollapsing function in the visitor *before* the actual collapse
occurs. Therefore, some of the information it points to becomes
invalid, or no longer actually represents the topology of the mesh.
Indeed.
> Can I reverse the edge collapses with just the information from the
EdgeProfiles passed into OnCollapsing?
Off the top of my head you could also need the "placement" argument which indicates where the remaning vertex will be placed. Unless in your particular application vertices are not moved.
Is any of the collapsed infoThe profile stores vertex and halfedge handles, some of which will be invalidated after the collapse. Wich ones depends on the actual euler operations applied based on the local topology before the collapse (topology which is described by the profile)
discarded (destructed etc.), or should it still reside in memory unused?
I'll take a close and I'll get back to you with details on how to implement the reverse operation using a stack of edge profiles.
Best
Fernando Cacciola
www.geometryfactory.com
- Re: [cgal-discuss] Polyhedron demo problem, (continued)
- Re: [cgal-discuss] Polyhedron demo problem, Laurent Rineau (GeometryFactory), 01/26/2009
- Re: [cgal-discuss] Polyhedron demo problem, Rob, 01/26/2009
- Re: Re: [cgal-discuss] Progressive Mesh, Pierre JUILLARD, 01/25/2009
- Re: [cgal-discuss] Progressive Mesh, Rob, 01/25/2009
- Re: [cgal-discuss] Progressive Mesh, Andreas Fabri, 01/25/2009
- Re: [cgal-discuss] Progressive Mesh, Rob Patro, 01/26/2009
- Re: [cgal-discuss] Progressive Mesh, Fernando Cacciola, 01/26/2009
- Re: [cgal-discuss] Progressive Mesh, Rob, 01/27/2009
- Re: [cgal-discuss] Progressive Mesh, Rob Patro, 01/27/2009
- Re: [cgal-discuss] Progressive Mesh, Fernando Cacciola, 01/27/2009
- Re: [cgal-discuss] Progressive Mesh, Fernando Cacciola, 01/28/2009
- Re: [cgal-discuss] Progressive Mesh, Rob Patro, 01/28/2009
- Re: [cgal-discuss] Progressive Mesh, Rob Patro, 01/29/2009
- Re: [cgal-discuss] Progressive Mesh, Fernando Cacciola, 01/29/2009
- [cgal-discuss] 2d delaunay_triangulation sample data (dot cgal), Ali Salami, 01/31/2009
