- To:
- Subject: Re: [cgal-discuss] Progressive Mesh
- Date: Wed, 28 Jan 2009 12:02:40 -0200
Hi Rob,
Ok, here's a sketch of how the PM could be implemented based on the edge profile and placement passed to the visitor.
The following (pseudo) code describes the (forward) halfedge collaspe algorithm, as implemented in
haldedge_collapse_Polyhedron_3.h
but seen from the information visible in the visitor from the edge profile:
While you follow this look at the collapse figures in the manual:
http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/Surface_mesh_simplification_ref/Concept_EdgeCollapsableMesh.html#Cross_link_anchor_1335
v0_erased = false ;
v1_erased = false ;
if ( ! profile.is_v0_v1_a_border() )
if ( ! profile.vL_v0()->opposite()->is_border() )
surface.join_facet( profile.vL_v0()->opposite() ) ;
else
surface.erase_facet( profile.vL_v0() ) ;
v0_erased = profile.is_v1_v0_a_border() ;
if ( ! profile.is_v1_v0_a_border() )
surface.join_facet( profile.vR_v1() ) ;
else
surface.erase_facet( profile.vR_v1()->opposite() ) ;
v1_erased = profile.is_v0_v1_a_border() ;
if ( ! v0_erased && ! v1_erased )
surface.join_vertex( v0_v1() );
v0_erased = true ;
vertex_kept = v0_erased = profile.v1() : profile.v0() ;
if ( placement_given )
vertex_kept->point() = placement ;
Based on the above, I would implement the PM by recording on each visitor call not the edge profile but some record of the actual sequence of euler operations that took place.
Something like the following (*OFF THE TOP OF MY HEAD*):
void OnCollapsing(Profile const& profile, OPoint const& placement )
v0_erased = false ;
v1_erased = false ;
v01_joined = false ;
f01L_joined = false ;
f01L_erased = false ;
f10R_joined = false ;
f10R_erased = false ;
if ( profile.vL_v0()->opposite()->is_border() )
f01L_joined = true ;
else
else
v01_joined = true ;
v0_erased = true ;
// General Case:
if ( f01L_joined && f10R_joined && v01_joined )
PM.add_step( new General_case_step(profile.surface()
,profile.vL_v0()->opposite()
,profile.v1_vR()->opposite()
,profile.v0()
,profile.v1()
,placement
else
.. similar for all other possible cases ..
whith
class General_case_step
General_case_step( Surface s
, Halfedge_handle v0_vL
, Halfedge_handle v1_vR
, Vertex_handle v0
, Vertex_handle v1
, optional<Point> v1_new_point
virtual void do()
// some information needed for undo is initialized here
vx0_v0 = s.join_facet(v0_vL);
vy0_v1 = s.join_facet(v1_vR);
v0_point = v0->point();
v1_point = v1->point();
s.join_vertex(v0,v1);
if ( v1_new_point )
v1->point() = v1_new_point ;
// v0_vL, v1_vR and v0 invalid at this point
virtual void undo()
// undo resets the invalidated handles so that do()
// can be called again
v0 = s.split_vertex(v1);
v0->point() = v0_point ;
v1->point() = v1_point ;
v1_vR = s.split_facet(v1_vL,vx0_v0);
v0_vL = s.split_facet(v0_vR,vy0_v1);
then, executing the PM would amount to call do() or undo() over the collection of polymorhpic steps collected with the visitor.
That is of course totally untested and off the top of my head.
HTH
Fernando Cacciola
www.geometryfactory.com
- Re: [cgal-discuss] Polyhedron demo problem, (continued)
- Re: [cgal-discuss] Polyhedron demo problem, Rob, 01/26/2009
- Re: Re: [cgal-discuss] Progressive Mesh, Pierre JUILLARD, 01/25/2009
- Re: [cgal-discuss] Progressive Mesh, Rob, 01/25/2009
- Re: [cgal-discuss] Progressive Mesh, Andreas Fabri, 01/25/2009
- Re: [cgal-discuss] Progressive Mesh, Rob Patro, 01/26/2009
- Re: [cgal-discuss] Progressive Mesh, Fernando Cacciola, 01/26/2009
- Re: [cgal-discuss] Progressive Mesh, Rob, 01/27/2009
- Re: [cgal-discuss] Progressive Mesh, Rob Patro, 01/27/2009
- Re: [cgal-discuss] Progressive Mesh, Fernando Cacciola, 01/27/2009
- Re: [cgal-discuss] Progressive Mesh, Fernando Cacciola, 01/28/2009
- Re: [cgal-discuss] Progressive Mesh, Rob Patro, 01/28/2009
- Re: [cgal-discuss] Progressive Mesh, Rob Patro, 01/29/2009
- Re: [cgal-discuss] Progressive Mesh, Fernando Cacciola, 01/29/2009
- [cgal-discuss] 2d delaunay_triangulation sample data (dot cgal), Ali Salami, 01/31/2009
