- To:
- Subject: Re: [cgal-discuss] Progressive Mesh
- Date: Mon, 26 Jan 2009 17:40:09 -0200
Hi Rob,
error: ‘class
CGAL::Surface_mesh_simplification::Edge_profile<CGAL::Polyhedron_3<CGAL::Simple_cartesian<double>,
m3_items, CGAL::HalfedgeDS_default, std::allocator<int> > >’ has no
member named ‘v0v1’
That's mistake in the documentation :( sorry about that.
The member is named: "v0_v1()"
You can see the actual class in the header:
$CGAL_DIR
/include
/CGAL
/Surface_mesh_simplification
/Policies
/Edge_collapse
/Edge_profile.h
Also, in the header:
$CGAL_DIR
/include
/CGAL
/halfedge_collapse_Polyhedron_3.h
there is the function:
vertex_descriptor halfedge_collapse( edge_descriptor const& pq
, Polyhedron_3<Gt,I,HDS,A>& aSurface
which you can just call to "replay" the decimation steps in the forward direction.
What is missing though is the reverse operation, which you will have to implement yourself. To do that, take close look at the implementation of halfedge_collapse() because the actual euler operation used depends on the local topology of the mesh around the collapsing edge.
HTH
Fernando Cacciola
www.geometryfactory.com
- [cgal-discuss] Polyhedron demo problem, (continued)
- [cgal-discuss] Polyhedron demo problem, Rob, 01/24/2009
- Re: [cgal-discuss] Polyhedron demo problem, Laurent Rineau (GeometryFactory), 01/25/2009
- Re: [cgal-discuss] Polyhedron demo problem, Rob, 01/25/2009
- Re: [cgal-discuss] Polyhedron demo problem, Laurent Rineau (GeometryFactory), 01/26/2009
- Re: [cgal-discuss] Polyhedron demo problem, Rob, 01/26/2009
- Re: Re: [cgal-discuss] Progressive Mesh, Pierre JUILLARD, 01/25/2009
- Re: [cgal-discuss] Progressive Mesh, Rob, 01/25/2009
- Re: [cgal-discuss] Progressive Mesh, Andreas Fabri, 01/25/2009
- Re: [cgal-discuss] Progressive Mesh, Rob Patro, 01/26/2009
- Re: [cgal-discuss] Progressive Mesh, Fernando Cacciola, 01/26/2009
- Re: [cgal-discuss] Progressive Mesh, Rob, 01/27/2009
- Re: [cgal-discuss] Progressive Mesh, Rob Patro, 01/27/2009
- Re: [cgal-discuss] Progressive Mesh, Fernando Cacciola, 01/27/2009
- Re: [cgal-discuss] Progressive Mesh, Fernando Cacciola, 01/28/2009
- Re: [cgal-discuss] Progressive Mesh, Rob Patro, 01/28/2009
- Re: [cgal-discuss] Progressive Mesh, Rob Patro, 01/29/2009
- Re: [cgal-discuss] Progressive Mesh, Fernando Cacciola, 01/29/2009
