cgal-discuss - [cgal-discuss] Problems during CGAL 3.4 installation under WinXP+VS2005
  • To:
  • Subject: [cgal-discuss] Problems during CGAL 3.4 installation under WinXP+VS2005
  • Date: Thu, 29 Jan 2009 04:24:32 +0100 (CET)
Hi all:
I"ve got problems when installing CGAL 3.4.Things are like this:
First, I installed CGAL 3.4 using the CGAL-3.4-Setup.exe file,the destination
folder is as default.
Second, I copied the unziiped boost_1_37_0 folder to the CGAL -3.4 folder
Then when I use CMake 2.6 to install it,it reports an error when the progress
is 18% to hint me set the Boost variables(BOOST_ROOT and BOOST_LIBRARYDIR ).
After I set the system variables, the same error still occurs.
So I rename the boost_1_37_0 folder to boost,and set 3 variables in the system
variables(BOOST_ROOT,value: c:\program files\CGAL
-3.4\boost,Boost_INCLUDE_DIR,value: c:\program files\CGAL
-3.4\boost\boost,BOOST_LIBRARYDIR,value: c:\program files\CGAL
-3.4\boost\libs)
CMake then still hints me to set Boost_INCLUDE_DIR or BOOST_ROOT!!
Anybody has an idea on this problem please?
