- To:
- Subject: Re: [cgal-discuss] Problems during CGAL 3.4 installation under
- Date: Fri, 30 Jan 2009 10:36:44 +0100
Hello,
You should open the CGAL.sln, right click on ALL_BUILD
and select build.
Note that you may have to do this for the Debug and the Release build.
If during the cmake you have selected WITH_EXAMPLES
the configuration step will have generated .sln files
in the example directories. Otherwise you have to
run cmake (or cmake-gui) in the directory of the example
you want to build.
But, please read the installation manual. It is part of
the distribution and available online at
http://www.cgal.org/Manual/3.4/doc_html/installation_manual/contents.html
andreas
wrote:
Hi!
Thanks for your instruction!
So,I'd like to know after the CGAL.sln has been created successfully,what is
the order of building the projects in VS2005?
Should it be 1 CGAL.proj
2 Install.proj
3 example.proj(I've selected examples when buiding in CMake)
or something else?
Thanks!
- [cgal-discuss] Problems during CGAL 3.4 installation under WinXP+VS2005, wangk0705, 01/29/2009
- Re: [cgal-discuss] Problems during CGAL 3.4 installation under WinXP+VS2005, Laurent Rineau (GeometryFactory), 01/29/2009
- Re: [cgal-discuss] Problems during CGAL 3.4 installation under, Kye Wong, 01/30/2009
- Re: [cgal-discuss] Problems during CGAL 3.4 installation under, Andreas Fabri, 01/30/2009
- Re: Re: [cgal-discuss] Problems during CGAL 3.4 installation under, wangk0705, 01/30/2009
- Re: [cgal-discuss] Problems during CGAL 3.4 installation under, Laurent Rineau (GeometryFactory), 01/30/2009
- Re: Re: Re: [cgal-discuss] Problems during CGAL 3.4 installation, wangk0705, 01/30/2009
