cgal-discuss - Re: [cgal-discuss] Problems during CGAL 3.4 installation under
  • To:
  • Subject: Re: [cgal-discuss] Problems during CGAL 3.4 installation under
  • Date: Fri, 30 Jan 2009 12:30:05 +0100
On Friday 30 January 2009 12:19:58
wrote:
> Hi!
> I tried to build it following what the manual says and have successfully
> built all the examples.
> But when I ran the built examples,it hints that:
> vs2005 this application has failed to start because the application
> configuration is incorrect...
Are you suing VC2005 with *service pack 1*? If you have downloaded
precompiled
binaries of Boost, they have been compiled with VC2005 SP1, which is binary
incompatible with the old VC2005 without SP1. That may explain why the
examples do not start.
If my hypothesis is right, you need to either:
- recompile Boost yourself,
- or upgrade your VC2005 twith SP1.
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
