- To:
- Subject: Re: [cgal-discuss] Problems during CGAL 3.4 installation under
- Date: Fri, 30 Jan 2009 22:15:44 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=WjRpiTrBfel78pJaez3OFH+Zoq8mq3a05Hxxe+Gic5ot0ve58HKUO/imrUB4QIikww 1951s16EmpY8RrNbY4bi4Wj4dPAW9RQjb49oSMWVAraZeTwcY/onHh0PkjcPBixcbjRG s1muN374dNqoku8zsJgkV0yHgyWMGw2rl9UDs=
Hi!
Yes! After packaging SP1 to VS2005,it works!
Thanks very much for your help!!
On Fri, Jan 30, 2009 at 7:30 PM, Laurent Rineau (GeometryFactory) <> wrote:
On Friday 30 January 2009 12:19:58 wrote:Are you suing VC2005 with *service pack 1*? If you have downloaded precompiled
> Hi!
> I tried to build it following what the manual says and have successfully
> built all the examples.
> But when I ran the built examples,it hints that:
> vs2005 this application has failed to start because the application
> configuration is incorrect...
binaries of Boost, they have been compiled with VC2005 SP1, which is binary
incompatible with the old VC2005 without SP1. That may explain why the
examples do not start.
If my hypothesis is right, you need to either:
- recompile Boost yourself,
- or upgrade your VC2005 twith SP1.
Kye Wong
- [cgal-discuss] Problems during CGAL 3.4 installation under WinXP+VS2005, wangk0705, 01/29/2009
- Re: [cgal-discuss] Problems during CGAL 3.4 installation under WinXP+VS2005, Laurent Rineau (GeometryFactory), 01/29/2009
- Re: [cgal-discuss] Problems during CGAL 3.4 installation under, Kye Wong, 01/30/2009
- Re: [cgal-discuss] Problems during CGAL 3.4 installation under, Andreas Fabri, 01/30/2009
- Re: Re: [cgal-discuss] Problems during CGAL 3.4 installation under, wangk0705, 01/30/2009
- Re: [cgal-discuss] Problems during CGAL 3.4 installation under, Laurent Rineau (GeometryFactory), 01/30/2009
- Re: Re: Re: [cgal-discuss] Problems during CGAL 3.4 installation, wangk0705, 01/30/2009
