- To: <>
- Subject: RE: [cgal-discuss] about calling the function point() through
- Date: Tue, 3 Feb 2009 22:01:41 +0800
- Importance: Normal
Excuse me. I have tried several ways to deal with the problem. And I find out that may be it is related to the fact that I am using the following override class and therefore I cannot use v -> point() directly template < class GT, class Vb = CGAL::Triangulation_vertex_base_3<GT> > class Vertex_base_for_ssr : public Vb {.....}; after I have modified the class Vertex_base_for_ssr such that it becom the following template < class GT, class Vb = CGAL::Triangulation_vertex_base_3<GT> > class Vertex_base_for_ssr : public Vb { Point point() { return Vb::point() } //.....some other things here }; now, with the above modified class "Vertex_base_for_ss", the code can be compiled without any error. But may I still here ask if I am using the things in CGAL correctly to achieve the functionality of v -> point() i.e. to get the point from its vertex handle Thank you very much for your attention. From: To: Date: Tue, 3 Feb 2009 21:12:49 +0800 Subject: [cgal-discuss] about calling the function point() through vertex handle Excuse me. I have used the following in CGAL typedef CGAL::Delaunay_triangulation_3<K1> Triangulations; typedef Triangulations::Vertex Vertex; typedef Triangulations::Vertex_handle Vertex_handle; when I have a vertex handle, say v. I use the following line of code v -> point() However, the compile gives me the following term does not evaluate to a function taking 0 arguments In the past, i can use v -> point() successfully, but now, when I use v -> point(), the compile give me that error.. May I ask what is happening and what may I do ? Thank you very much 內在氣質才是致勝之道-您是哪一 最原始的溝通是用心的交流。 給我一個身份 We need a name! |
- [cgal-discuss] about calling the function point() through vertex handle, Kwok Jasper, 02/03/2009
- RE: [cgal-discuss] about calling the function point() through, Kwok Jasper, 02/03/2009
- Re: [cgal-discuss] about calling the function point() through vertex handle, Laurent Rineau (GeometryFactory), 02/03/2009
- Re: [cgal-discuss] about calling the function point() through, Laurent Rineau (GeometryFactory), 02/04/2009
- RE: [cgal-discuss] about calling the function point() through, Kwok Jasper, 02/04/2009
- Re: [cgal-discuss] about calling the function point() through, Monique Teillaud, 02/04/2009
