- To: <>
- Subject: RE: [cgal-discuss] about calling the function point() through
- Date: Wed, 4 Feb 2009 02:33:43 +0800
- Importance: Normal
Thank you for your reply I have tried several ways to deal with the problem. And I find out that may be it is related to the fact that I am using the following override class and therefore I cannot use v -> point() directly template < class GT, class Vb = CGAL::Triangulation_vertex_base_3<GT> > class Vertex_base_for_ssr : public Vb {.....}; after I have modified the class Vertex_base_for_ssr such that it becom the following template < class GT, class Vb = CGAL::Triangulation_vertex_base_3<GT> > class Vertex_base_for_ssr : public Vb { Point point() { return Vb::point() } //.....some other things here }; now, with the above modified class "Vertex_base_for_ss", the code can be compiled without any error. But may I still here ask if I am using the things in CGAL correctly to achieve the functionality of v -> point() i.e. to get the point from its vertex handle Thank you very much > From: > To: > Date: Tue, 3 Feb 2009 18:37:11 +0100 > Subject: Re: [cgal-discuss] about calling the function point() through vertex handle > > On Tuesday 03 February 2009 14:12:49 Kwok Jasper wrote: > > Excuse me. > > > > I have used the following in CGAL > > > > typedef CGAL::Delaunay_triangulation_3<K1> Triangulations; > > typedef Triangulations::Vertex Vertex; > > typedef Triangulations::Vertex_handle Vertex_handle; > > > > when I have a vertex handle, say v. > > I use the following line of code > > > > v -> point() > > > > However, the compile gives me the following > > > > term does not evaluate to a function taking 0 arguments > > What is your compiler? With the code sample you gave v->point() should be a > valid _expression_ of type Vertex_handle. That is the usual way (and probably > also the only way) to retrieve a point from a vertex handle. > > -- > Laurent Rineau, PhD > Engineer at GeometryFactory > http://www.geometryfactory.com/ > > -- > You are currently subscribed to cgal-discuss. > To unsubscribe or access the archives, go to > https://lists-sop.inria.fr/wws/info/cgal-discuss Windows Live Gallery 讓才華綻放,讓全世界看見你的創造。 |
- [cgal-discuss] about calling the function point() through vertex handle, Kwok Jasper, 02/03/2009
- RE: [cgal-discuss] about calling the function point() through, Kwok Jasper, 02/03/2009
- Re: [cgal-discuss] about calling the function point() through vertex handle, Laurent Rineau (GeometryFactory), 02/03/2009
- Re: [cgal-discuss] about calling the function point() through, Laurent Rineau (GeometryFactory), 02/04/2009
- RE: [cgal-discuss] about calling the function point() through, Kwok Jasper, 02/04/2009
- Re: [cgal-discuss] about calling the function point() through, Monique Teillaud, 02/04/2009
