- To: <>
- Subject: [cgal-discuss] about calling the function point() through vertex handle
- Date: Tue, 3 Feb 2009 21:12:49 +0800
- Importance: Normal
Excuse me. I have used the following in CGAL typedef CGAL::Delaunay_triangulation_3<K1> Triangulations; typedef Triangulations::Vertex Vertex; typedef Triangulations::Vertex_handle Vertex_handle; when I have a vertex handle, say v. I use the following line of code v -> point() However, the compile gives me the following term does not evaluate to a function taking 0 arguments In the past, i can use v -> point() successfully, but now, when I use v -> point(), the compile give me that error.. May I ask what is happening and what may I do ? Thank you very much 內在氣質才是致勝之道-您是哪一 最原始的溝通是用心的交流。 |
- [cgal-discuss] about calling the function point() through vertex handle, Kwok Jasper, 02/03/2009
- RE: [cgal-discuss] about calling the function point() through, Kwok Jasper, 02/03/2009
- Re: [cgal-discuss] about calling the function point() through vertex handle, Laurent Rineau (GeometryFactory), 02/03/2009
- Re: [cgal-discuss] about calling the function point() through, Laurent Rineau (GeometryFactory), 02/04/2009
- RE: [cgal-discuss] about calling the function point() through, Kwok Jasper, 02/04/2009
- Re: [cgal-discuss] about calling the function point() through, Monique Teillaud, 02/04/2009
