cgal-discuss - Re: [cgal-discuss] about calling the function point() through vertex handle
  • To:
  • Subject: Re: [cgal-discuss] about calling the function point() through vertex handle
  • Date: Tue, 3 Feb 2009 18:37:11 +0100
On Tuesday 03 February 2009 14:12:49 Kwok Jasper wrote:
> Excuse me.
> I have used the following in CGAL
> typedef CGAL::Delaunay_triangulation_3<K1> Triangulations;
> typedef Triangulations::Vertex Vertex;
> typedef Triangulations::Vertex_handle Vertex_handle;
> when I have a vertex handle, say v.
> I use the following line of code
> v -> point()
> However, the compile gives me the following
> term does not evaluate to a function taking 0 arguments
What is your compiler? With the code sample you gave v->point() should be a
valid expression of type Vertex_handle. That is the usual way (and probably
also the only way) to retrieve a point from a vertex handle.
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
