cgal-discuss - Re: [cgal-discuss] use Surface mesher to re-mesh self-intersecting
  • To:
  • Subject: Re: [cgal-discuss] use Surface mesher to re-mesh self-intersecting
  • Date: Mon, 23 Feb 2009 08:54:25 +0100
Qianqian Fang wrote:
hi
In the past, I asked in this list about removing self-intersecting
elements from triangular surface. I was recommended to use
the surface mesher avoid repairing a bad mesh as it guarantees to
have no self-intersecting elements.
Now, I need to process a surface generated from other software,
unfortunately, this mesh contains self-intersecting elements. So, I
still need a program to fix this surface (and resample it to my
desired density).
Reading the documents of the Surface Mesher, I have the impression
that it can be applied for this situation. The only difference
is that the surface is not defined by gray-scale image, or an implicit
function, but by a triangular surface mesh.
Indeed, I can even define the surface by an implicit function, which
returns the distance from a Point_3 to a Polyhedron_3, similar to
the sphere case in the manual. Does this sound like a viable
approach to you?
If it may work, what I need is to find a subroutine to calculate the
distance. I only found a squared_distance() for Point_3
to Plane_3 in include/CGAL/squared_distance_3_2.h. I am wondering
if a similar function to calculate Point3 to a polyhedron exists?
if it does, can anyone show me an example how to use it?
thank you
Qianqian
The Surface mesher will be able to handle such a situation in a
a near future.
What is missing actually is the Polyhedral_surface_traits that can handle
surface defined as a triangle soup. Such a traits is going to be provided
in the next public release.
In the current release, you can find such a traits hidden in the polyhedron
demo, as Pierre said. However you will have to hack a bit the code, ti bypass
the construction of the Polyhedron_3 which does not work with a self intersecting
triangular surface
Mariette Yvinec
Geometrica project team
INRIA Sophia-Antipolis
