- To:
- Subject: Re: [cgal-discuss] use Surface mesher to re-mesh self-intersecting
- Date: Mon, 23 Feb 2009 13:00:39 +0100
Mariette Yvinec wrote:
Qianqian Fang wrote:
hi
In the past, I asked in this list about removing self-intersecting
elements from triangular surface. I was recommended to use
the surface mesher avoid repairing a bad mesh as it guarantees to
have no self-intersecting elements.
Now, I need to process a surface generated from other software,
unfortunately, this mesh contains self-intersecting elements. So, I
still need a program to fix this surface (and resample it to my
desired density).
Reading the documents of the Surface Mesher, I have the impression
that it can be applied for this situation. The only difference
is that the surface is not defined by gray-scale image, or an implicit
function, but by a triangular surface mesh.
Indeed, I can even define the surface by an implicit function, which
returns the distance from a Point_3 to a Polyhedron_3, similar to
the sphere case in the manual. Does this sound like a viable
approach to you?
If it may work, what I need is to find a subroutine to calculate the
distance. I only found a squared_distance() for Point_3
to Plane_3 in include/CGAL/squared_distance_3_2.h. I am wondering
if a similar function to calculate Point3 to a polyhedron exists?
if it does, can anyone show me an example how to use it?
thank you
Qianqian
The Surface mesher will be able to handle such a situation in a
a near future.
What is missing actually is the Polyhedral_surface_traits that can handle
surface defined as a triangle soup. Such a traits is going to be provided
in the next public release.
In the current release, you can find such a traits hidden in the polyhedron
demo, as Pierre said. However you will have to hack a bit the code, ti bypass the construction of the Polyhedron_3 which does not work with a self intersecting triangular surface.
Hi Qianqian Fang,
I attached to this post the AABB_polyhedral_oracle class mentioned by Mariette above, that can remesh a triangles soup. Triangles must be convertible to type CGAL::Triangle_3.
Best regards,
Laurent Saboret
INRIA Sophia-Antipolis
#ifndef AABB_POLYHEDRAL_ORACLE_H
#define AABB_POLYHEDRAL_ORACLE_H
#include <boost/static_warning.hpp>
#include <utility>
#include <CGAL/iterator.h>
#include "AABB_tree.h"
// Modified version of CGAL::AABB_polyhedral_oracle to be independent of a
polyhedron class.
template <class TriangleKernel, ///< Triangles' kernel
class TriangleIterator, ///< Value type must be Triangle_3
class AABBTree_kernel = CGAL::Simple_cartesian<typename
TriangleKernel::FT>
///< Local kernel for fast bounding
box intersections
//template <class Polyhedron, class TriangleKernel, class AABBTree_kernel>
class AABB_polyhedral_oracle
//: public Polyhedron
typedef AABB_polyhedral_oracle Self;
public:
//typedef typename TriangleKernel::FT FT;
//typedef typename TriangleKernel::Ray_3 Ray_3;
//typedef typename TriangleKernel::Line_3 Line_3;
typedef typename TriangleKernel::Point_3 Point_3;
//typedef typename TriangleKernel::Segment_3 Segment_3;
typedef Self Surface_mesher_traits_3;
typedef Point_3 Intersection_point;
typedef Self Surface_3;
// AABB tree
typedef AABB_tree<TriangleKernel, TriangleIterator, AABBTree_kernel> Tree;
typedef typename Tree::Point_with_triangle Point_with_triangle;
private:
Tree *m_pTree;
public:
Tree* tree() const{ return m_pTree; }
public:
// constructor
AABB_polyhedral_oracle()
m_pTree = NULL;
AABB_polyhedral_oracle(Tree *pTree)
m_pTree = pTree;
//AABB_polyhedral_oracle(const AABB_polyhedral_oracle& oracle)
// m_pTree = oracle.tree();
//class Intersect_3;
//friend class Intersect_3;
class Intersect_3 {
const Self& self;
public:
Intersect_3(const Self& self) : self(self)
template<class SegmentType> ///< tested with Segment_3 and Ray_3
CGAL::Object operator()(const Surface_3& surface, const SegmentType&
segment) const
Point_with_triangle pwh;
if(surface.tree()->first_intersection(segment,pwh))
return CGAL::make_object(pwh.first);
else
return CGAL::Object();
//Object operator()(const Surface_3& surface, const Ray_3& ray) const
// Converter convert;
// BConverter bconvert;
// Point_with_triangle pwh;
// if(surface.tree()->first_intersection(convert(ray),pwh))
// return make_object(bconvert(pwh.first));
// else
// return Object();
//Object operator()(const Surface_3& surface, const Line_3& line)
const
// if(surface.tree()->first_intersection(convert(line),pwh))
// else
// return Object();
}; // class Intersect_3
Intersect_3 intersect_3_object() const
return Intersect_3(*this);
//class Construct_initial_points;
//friend class Construct_initial_points;
const Self& self;
public:
Construct_initial_points(const Self& self) : self(self)
template <typename OutputIteratorPoints>
OutputIteratorPoints operator() (const Surface_3& surface,
OutputIteratorPoints out,
int n) const
// TODO (with visitor)
// std::cout << "construct initial point set" << std::endl;
// *out++= p;
return out;
}; // class Construct_initial_points
Construct_initial_points construct_initial_points_object() const
return Construct_initial_points(*this);
template <class P>
bool is_in_volume(const Surface_3& surface, const P& p)
std::cout << "DEBUG: call is in volume" << std::endl;
return true;
}; // end class AABB_polyhedral_oracle
#endif // AABB_POLYHEDRAL_ORACLE_H
// Author(s) : Camille Wormser, Jane Tournois, Pierre Alliez, Laurent
Saboret
#ifndef AABB_TREE_H_INCLUDED
#define AABB_TREE_H_INCLUDED
#include "AABB_node.h"
#include <CGAL/Simple_cartesian.h>
#include <stack>
// Modified version of CGAL::AABB_tree to be independent of a polyhedron
class.
class Kernel = CGAL::Simple_cartesian<typename TriangleKernel::FT>
box intersections
class AABB_tree
private:
// Nodes of the tree
typedef AABB_node<TriangleKernel,
TriangleIterator,
typename std::vector<TriangleIterator>::iterator,
Kernel> Node;
public:
// Local kernel object types
typedef typename Kernel::FT FT;
typedef typename Kernel::Point_3 Point;
// Global kernel object types
typedef typename TriangleKernel::Triangle_3 Triangle;
typedef typename TriangleKernel::Point_3 Triangle_point;
typedef std::pair<Triangle_point, TriangleIterator> Point_with_triangle;
private:
// set of triangle pointers (global to the tree)
std::vector<TriangleIterator> m_data;
// root node
Node* m_root;
public:
// life cycle
AABB_tree() : m_root(NULL) {}
AABB_tree(TriangleIterator first, TriangleIterator beyond)
m_root = NULL;
build_faces(first, beyond);
~AABB_tree()
cleanup();
void cleanup()
m_data.clear();
delete m_root; m_root = NULL;
// build tree
bool build_faces(TriangleIterator first, TriangleIterator beyond)
cleanup();
set_face_data(first, beyond);
if(!empty())
m_root = new Node(m_data.begin(), m_data.end());
return true;
return false;
private:
void set_face_data(TriangleIterator first, TriangleIterator beyond)
unsigned int nbf = std::distance(first, beyond);
m_data.reserve(nbf);
for (TriangleIterator triangle = first; triangle != beyond; triangle++)
m_data.push_back(triangle);
public:
bool empty()
return m_data.size() < 2; // TODO: change this requirement to < 1
// --------------------RAY/SEGMENT ORACLES----------------------//
bool first_intersection(const SegmentType& seg, Point_with_triangle& pwh)
const
std::stack<Node*> nodes;
nodes.push(m_root);
while(!nodes.empty())
Node *pNode = nodes.top();
nodes.pop();
// Test against primitive if leaf, against box if not
if(pNode->do_intersect(seg))
if(pNode->is_leaf())
// found intersecting triangle
Triangle t(*pNode->primitive());
CGAL::Object inter = CGAL::intersection(t.supporting_plane(),seg);
Triangle_point result;
bool ok = CGAL::assign(result, inter);
assert(ok);
pwh = Point_with_triangle(result, pNode->primitive());
return true;
else // recurse (test against bbox only)
nodes.push(pNode->left_child());
nodes.push(pNode->right_child());
return false;
template<class SegmentType, ///< tested with Segment_3 and Ray_3
class OutputIterator> ///< value type must be TriangleIterator
OutputIterator find_intersections(const SegmentType& seg, OutputIterator
output) const
nodes.push(m_root);
nodes.pop();
*output = pNode->primitive();
output++;
return output;
unsigned int nb_intersections(const SegmentType& seg) const
std::vector<TriangleIterator> intersections;
find_intersections(seg, std::back_inserter(intersections));
return intersections.size();
}; // class AABB_tree
#endif // AABB_TREE_H_INCLUDED
Saboret
#ifndef AABB_NODE_H_INCLUDED
#define AABB_NODE_H_INCLUDED
#include <CGAL/Cartesian_converter.h>
#include <CGAL/intersections.h>
#include <limits>
#include <vector>
#include <cassert>
// Modified version of CGAL::AABB_node to be independent of a polyhedron
class.
class TriangleIteratorIterator, ///< Value type must be
TriangleIterator
box intersections
class AABB_node
public:
// Bounding box with (double) floating point arithmetic
typedef CGAL::Iso_cuboid_3<Kernel> Bbox;
private:
// Converter of number types, points and vectors
typedef CGAL::Cartesian_converter<TriangleKernel, Kernel> Converter;
private:
// bounding box
Bbox m_bbox;
// if leaf: data
TriangleIterator m_primitive;
// else: children data as iterator range (stored only in the tree)...
TriangleIteratorIterator m_begin, m_end;
// ...and children nodes.
AABB_node *m_left_child;
AABB_node *m_right_child;
public:
// life cycle
AABB_node(TriangleIteratorIterator a, TriangleIteratorIterator b)
m_left_child = m_right_child = NULL;
expand(a, b);
~AABB_node()
cleanup_recurse();
// access to primitive
TriangleIterator primitive() { return m_primitive; }
// access to children
AABB_node* left_child() { return m_left_child; }
AABB_node* right_child() { return m_right_child; }
bool is_leaf()
return m_left_child == NULL && m_right_child == NULL;
// deletes the whole subtree rooted at this node (except this node, of
course).
void cleanup_recurse()
delete m_left_child;
delete m_right_child;
private:
// compute bbox for iterator range of input primitives
void compute_bbox()
assert(m_begin != m_end);
FT xmin,xmax,ymin,ymax,zmin,zmax;
std::vector<TriangleIterator>::iterator it = m_begin;
// init with any point in container
TriangleIterator triangle = *it;
const Triangle_point& any_point = (*triangle)[0];
xmin = xmax = any_point.x();
ymin = ymax = any_point.y();
zmin = zmax = any_point.z();
// compute bbox
for(; it != m_end; it++)
xyz_min(triangle,xmin,ymin,zmin);
xyz_max(triangle,xmax,ymax,zmax);
// Enlarge it a little to avoid missing intersections
// due to floating point computation errors.
FT epsilon = FT(100)*std::numeric_limits<FT>::epsilon();
Point p(xmin-epsilon, ymin-epsilon, zmin-epsilon);
Point q(xmax+epsilon, ymax+epsilon, zmax+epsilon);
m_bbox = Bbox(p,q);
void xyz_min(TriangleIterator triangle,
FT& xmin, FT& ymin, FT& zmin)
Triangle_point a = (*triangle)[0];
Triangle_point b = (*triangle)[1];
Triangle_point c = (*triangle)[2];
xmin = (std::min)(xmin,(std::min)(a.x(),(std::min)(b.x(),c.x())));
ymin = (std::min)(ymin,(std::min)(a.y(),(std::min)(b.y(),c.y())));
zmin = (std::min)(zmin,(std::min)(a.z(),(std::min)(b.z(),c.z())));
void xyz_max(TriangleIterator triangle,
FT& xmax, FT& ymax, FT& zmax)
xmax = (std::max)(xmax,(std::max)(a.x(),(std::max)(b.x(),c.x())));
ymax = (std::max)(ymax,(std::max)(a.y(),(std::max)(b.y(),c.y())));
zmax = (std::max)(zmax,(std::max)(a.z(),(std::max)(b.z(),c.z())));
// builds the tree by recursive expansion.
// [a,b[ is the range of primitives to be added to the tree.
void expand(TriangleIteratorIterator a, TriangleIteratorIterator b)
m_begin = a;
m_end = b;
int range = std::distance(m_begin, m_end);
compute_bbox();
// sort primitives along longest axis aabb
sort_primitives();
if(range > 1)
// split
m_left_child = new AABB_node(m_begin, m_begin+range/2);
m_right_child = new AABB_node(m_begin+range/2, m_end);
else // this is a leaf node, set one primitive
m_primitive = *m_begin;
static Triangle_point centroid(TriangleIterator triangle)
return CGAL::centroid(a,b,c);
static bool lower_x(const TriangleIterator& f1,
const TriangleIterator& f2)
return centroid(f1).x() < centroid(f2).x();
static bool lower_y(const TriangleIterator& f1,
return centroid(f1).y() < centroid(f2).y();
static bool lower_z(const TriangleIterator& f1,
return centroid(f1).z() < centroid(f2).z();
void sort_primitives()
switch(longest_axis())
case 0: // sort along x
std::sort(m_begin,m_end, lower_x);
break;
case 1: // sort along y
std::sort(m_begin,m_end, lower_y);
break;
default: // sort along z
std::sort(m_begin,m_end, lower_z);
// Return the node's longest axis as 0 (X), 1 (Y) or 2 (Z)
int longest_axis()
FT max_size = (std::max)(xsize(),(std::max)(ysize(),zsize()));
if(max_size == xsize())
return 0; // axis along x
if(max_size == ysize())
return 1; // axis along y
return 2; // axis along z
// size of bounding box along each axis
FT xsize() { return m_bbox.xmax() - m_bbox.xmin(); }
FT ysize() { return m_bbox.ymax() - m_bbox.ymin(); }
FT zsize() { return m_bbox.zmax() - m_bbox.zmin(); }
public:
bool do_intersect(const SegmentType& seg)
Converter convert;
if(!is_leaf())
// check against bbox
return CGAL::do_intersect(convert(seg),m_bbox);
else
// optimization: check first against triangle's bbox
if (!CGAL::do_intersect(convert(seg),m_bbox))
return false;
// check against input primitive
return CGAL::do_intersect(Triangle(*m_primitive), seg);
}; // class AABB_node
#endif // AABB_NODE_H_INCLUDED
- [cgal-discuss] use Surface mesher to re-mesh self-intersecting surfaces, Qianqian Fang, 02/22/2009
- Re: [cgal-discuss] use Surface mesher to re-mesh self-intersecting surfaces, avaxman, 02/22/2009
- Re: [cgal-discuss] use Surface mesher to re-mesh self-intersecting, Qianqian Fang, 02/22/2009
- Re: [cgal-discuss] use Surface mesher to re-mesh self-intersecting, Pierre Alliez, 02/23/2009
- Re: [cgal-discuss] use Surface mesher to re-mesh self-intersecting, Mariette Yvinec, 02/23/2009
- [cgal-discuss] CoCone and Tight CoCone with CGAL, naresh, 02/23/2009
- Re: [cgal-discuss] CoCone and Tight CoCone with CGAL, Laurent Rineau (GeometryFactory), 02/23/2009
- [cgal-discuss] Learning CGAL Absolute Beginner, naresh, 02/23/2009
- Re: [cgal-discuss] Learning CGAL Absolute Beginner, Samuel Hornus, 02/23/2009
- Re: [cgal-discuss] use Surface mesher to re-mesh self-intersecting, Laurent Saboret, 02/23/2009
- Re: [cgal-discuss] use Surface mesher to re-mesh self-intersecting, Qianqian Fang, 02/23/2009
