[cgal-discuss] Accessing Finite_Vertex_Iterator as std::iterator or boost iterator
- To:
- Subject: [cgal-discuss] Accessing Finite_Vertex_Iterator as std::iterator or boost iterator
- Date: Tue, 24 Feb 2009 16:03:20 +0100
Hi there,
I have an interface which represents access to delaunay triangulation.
Part of this interface should be an iterator which allows me to go
through all the vertices of the triangulation. As an implementation of
this interface I built an adapter to CGAL which works pretty well -
except for the iterator.
From CGAL I can get an Finite_vertices_iterator but I need a
std::iterator (or a boost iterator) (part of the interface)
- now I wonder if there is any other way for this then writing a wrapper
class?
Thanks in advance,
Tom
- [cgal-discuss] Trouble cutting polyhedron using a plane., frederic.depourcq, 02/24/2009
- Re: [cgal-discuss] Trouble cutting polyhedron using a plane., Frederic De Pourcq, 02/24/2009
- [cgal-discuss] Accessing Finite_Vertex_Iterator as std::iterator or boost iterator, Tom Kazimiers, 02/24/2009
- Re: [cgal-discuss] Accessing Finite_Vertex_Iterator as std::iterator, Sylvain Pion, 02/24/2009
- Re: [cgal-discuss] Accessing Finite_Vertex_Iterator as std::iterator, Tom Kazimiers, 02/24/2009
