- To:
- Subject: Re: [cgal-discuss] Accessing Finite_Vertex_Iterator as std::iterator
- Date: Tue, 24 Feb 2009 16:30:18 +0100
Sylvain Pion schrieb:
> Tom Kazimiers wrote:
>> I have an interface which represents access to delaunay triangulation.
>> Part of this interface should be an iterator which allows me to go
>> through all the vertices of the triangulation. As an implementation of
>> this interface I built an adapter to CGAL which works pretty well -
>> except for the iterator.
>> From CGAL I can get an Finite_vertices_iterator but I need a
>> std::iterator (or a boost iterator) (part of the interface)
>> - now I wonder if there is any other way for this then writing a wrapper
>> class?
> It would be interesting to know the reason why you have such a
> requirement.
I am working currently on an university project in which I would like to
easyly switch between delaunay triangulation variants (like between CGAL
and an implementation of one of my professors). For this I wrote an
interface (lots of "virtual ... = 0;" functions) to write code only
against this interface (which is good habbit anyway I guess). This again
would it make easy to see the behaviour of different triangulations
without changing much code.
Thanks and regards,
Tom
- [cgal-discuss] Trouble cutting polyhedron using a plane., frederic.depourcq, 02/24/2009
- Re: [cgal-discuss] Trouble cutting polyhedron using a plane., Frederic De Pourcq, 02/24/2009
- [cgal-discuss] Accessing Finite_Vertex_Iterator as std::iterator or boost iterator, Tom Kazimiers, 02/24/2009
- Re: [cgal-discuss] Accessing Finite_Vertex_Iterator as std::iterator, Sylvain Pion, 02/24/2009
- Re: [cgal-discuss] Accessing Finite_Vertex_Iterator as std::iterator, Tom Kazimiers, 02/24/2009
