cgal-discuss - Re: [cgal-discuss] Accessing Finite_Vertex_Iterator as std::iterator
  • To:
  • Subject: Re: [cgal-discuss] Accessing Finite_Vertex_Iterator as std::iterator
  • Date: Tue, 24 Feb 2009 17:05:16 +0100
  • Organization: INRIA
I have an interface which represents access to delaunay
triangulation.
Part of this interface should be an iterator which allows me to go
through all the vertices of the triangulation. As an
implementation of
this interface I built an adapter to CGAL which works pretty well -
except for the iterator.
From CGAL I can get an Finite_vertices_iterator but I need a
std::iterator (or a boost iterator) (part of the interface)
- now I wonder if there is any other way for this then writing a
wrapper
class?
It would be interesting to know the reason why you have such a
requirement.
I am working currently on an university project in which I would
like to
easyly switch between delaunay triangulation variants (like between
CGAL
and an implementation of one of my professors). For this I wrote an
interface (lots of "virtual ... = 0;" functions) to write code only
against this interface (which is good habbit anyway I guess). This
again
would it make easy to see the behaviour of different triangulations
without changing much code.
Then I guess the answer is that you have to write wrappers.
You can also go on the generic programming path using a concept,
and write adaptors for the 2 implementations.
Sylvain, thanks for your suggestions. CGAL makes a lot use of the
concept/template approach, doesn't it?
Yes. You can even call it abuse, sometimes :)
You will find the basic principles in the design of the STL.
Hehe, I see. Sorry, but I got one more littel question regarding the the
concept thing:
Concepts seem to be something like a not-written-out interface contract
- is this true? Like one assumes serveral methods in a instantiated
template.
This is getting off-topic for this list.
I'd suggest that you take a look at some good book,
like Matt Austern's "Generic Programming and the STL".
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
Attachment: smime.p7s
Description: S/MIME Cryptographic Signature
