- To:
- Subject: Re: [cgal-discuss] Accessing Finite_Vertex_Iterator as std::iterator
- Date: Tue, 24 Feb 2009 16:59:11 +0100
>>>>>> I have an interface which represents access to delaunay
>>>>>> triangulation.
>>>>>> Part of this interface should be an iterator which allows me to go
>>>>>> through all the vertices of the triangulation. As an
>>>>>> implementation of
>>>>>> this interface I built an adapter to CGAL which works pretty well -
>>>>>> except for the iterator.
>>>>>> From CGAL I can get an Finite_vertices_iterator but I need a
>>>>>> std::iterator (or a boost iterator) (part of the interface)
>>>>>> - now I wonder if there is any other way for this then writing a
>>>>>> wrapper
>>>>>> class?
>>>>> It would be interesting to know the reason why you have such a
>>>>> requirement.
>>>> I am working currently on an university project in which I would
>>>> like to
>>>> easyly switch between delaunay triangulation variants (like between
>>>> CGAL
>>>> and an implementation of one of my professors). For this I wrote an
>>>> interface (lots of "virtual ... = 0;" functions) to write code only
>>>> against this interface (which is good habbit anyway I guess). This
>>>> again
>>>> would it make easy to see the behaviour of different triangulations
>>>> without changing much code.
>>> Then I guess the answer is that you have to write wrappers.
>>> You can also go on the generic programming path using a concept,
>>> and write adaptors for the 2 implementations.
>> Sylvain, thanks for your suggestions. CGAL makes a lot use of the
>> concept/template approach, doesn't it?
> Yes. You can even call it abuse, sometimes :)
> You will find the basic principles in the design of the STL.
Hehe, I see. Sorry, but I got one more littel question regarding the the
concept thing:
Concepts seem to be something like a not-written-out interface contract
- is this true? Like one assumes serveral methods in a instantiated
template.
- [cgal-discuss] Trouble cutting polyhedron using a plane., frederic.depourcq, 02/24/2009
- Re: [cgal-discuss] Trouble cutting polyhedron using a plane., Frederic De Pourcq, 02/24/2009
- [cgal-discuss] Accessing Finite_Vertex_Iterator as std::iterator or boost iterator, Tom Kazimiers, 02/24/2009
- Re: [cgal-discuss] Accessing Finite_Vertex_Iterator as std::iterator, Sylvain Pion, 02/24/2009
- Re: [cgal-discuss] Accessing Finite_Vertex_Iterator as std::iterator, Tom Kazimiers, 02/24/2009
