- To:
- Subject: Re: [cgal-discuss] Transformation of 3d point without
- Date: Thu, 26 Feb 2009 17:13:43 +0100
Hi Matthias,
I'm sorry I did not read the whole thread, but what do you mean by "correct" delaunay triangulation? I don't have any problems on your point set. At least there is no error and it computes a triangulation which I suppose to be Delaunay.
Only a wild guess: might it be possible that you don't get the triangulation you expect due to roundoff errors in the input set?
best
Manuel
wrote:
Thank you. That worked.
After doing a transformation and writing the point to a file i can't perform a
correct delaunay_triangulation_2 with this points, even if i create a new one.
I'm using CGAL::Triangulation_euclidean_traits_xy_3.
Can some check the result for the following points (x, y, z)?
-1.0 -0.4900 3.00
1.0 -0.0300 1.00
1.0 -0.1600 2.00
1.0 -0.4200 4.00
1.1 -1.3000 2.90
1.1 -1.5000 4.80
2.0 -0.0600 2.00
2.0 0.0690 1.00
2.0 -0.1900 3.00
2.0 -0.4500 5.00
2.0 -0.5100 4.00
3.0 0.0390 2.00
3.0 -0.0900 3.00
3.0 -0.2200 4.00
3.0 -0.3500 5.00
3.0 -0.4200 0.95
3.0 -0.6000 7.00
4.0 0.0095 3.00
4.0 -0.1200 4.00
4.0 0.1400 2.00
4.0 -0.2500 5.00
4.0 0.2700 1.00
4.0 -0.5100 7.00
5.0 -0.0200 4.00
5.0 0.1100 3.00
5.0 0.2400 2.00
5.0 -0.3500 5.00
5.0 0.3700 1.10
6.0 0.2100 3.10
6.0 0.3400 2.10
I tried both, CGAL::Gmpq and the inexact_construction_kernel. But nothing
works.
- [cgal-discuss] Transformation of 3d point without p.transform, matthias.kunz, 02/25/2009
- Re: [cgal-discuss] Transformation of 3d point without p.transform, Sylvain Pion, 02/25/2009
- Re: Re: [cgal-discuss] Transformation of 3d point without, matthias.kunz, 02/26/2009
- Re: [cgal-discuss] Transformation of 3d point without, Manuel Caroli, 02/26/2009
- Re: [cgal-discuss] Transformation of 3d point without, Manuel Caroli, 02/27/2009
- Re: Re: [cgal-discuss] Transformation of 3d point without, matthias.kunz, 02/27/2009
- Re: [cgal-discuss] Transformation of 3d point without, Laurent Rineau (GeometryFactory), 02/27/2009
