cgal-discuss - Re: [cgal-discuss] Transformation of 3d point without
  • To:
  • Subject: Re: [cgal-discuss] Transformation of 3d point without
  • Date: Fri, 27 Feb 2009 15:16:43 +0100
On Friday 27 February 2009 14:46:18
wrote:
> I checked it from each direction and there is an error. I found that if i
> set all height values to 0.00 it works fine. So in some way the traits may
> take the height (z) value into the triangulation. Could this be possible or
> where else could that error be?
At the point, it seems clear to me that there are a lot of misunderstanding
in
the discussion.
Matthias, you should set us a small but compilable code that shows the faulty
behavious, and tell us what you except. Maybe you should the best practice to
report a bug:
http://www.cgal.org/report_bugs.html
Following that maximize your chance to get useful help from the mailing list.
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
