- To:
- Subject: Re: [cgal-discuss] Transformation of 3d point without
- Date: Fri, 27 Feb 2009 11:57:55 +0100
Hi Matthias,
make sure you look in the right direction. Using the Triangulation_euclidean_traits_xy_3 you projected the triangulation in the xy plane. Followingly you should look along the z-axis to "see" a Delaunay triangulation, which is the case (at least on my machine).
Might it be possible that you expected it to be projected on the xz-plane? Your data set sort of suggests that. In this case you see edge intersections, but that's of course a completely correct behavior.
hope this helped
Manuel
wrote:
It might be a rounding error. That seems to be quite common when using double
values. However if i use the dataset independent from the calculation from
which it is produced it still introduces errors at the edges when i display
the
triangulation. That means, i take that dataset completely new in my
triangulation process. So for some datasets it works and for some it doesn't.
By correct i mean that there are no intersection of edges in the 3d space. I
want to do the triangulation in a plane with 3d points. So there should be no
intersection?
- [cgal-discuss] Transformation of 3d point without p.transform, matthias.kunz, 02/25/2009
- Re: [cgal-discuss] Transformation of 3d point without p.transform, Sylvain Pion, 02/25/2009
- Re: Re: [cgal-discuss] Transformation of 3d point without, matthias.kunz, 02/26/2009
- Re: [cgal-discuss] Transformation of 3d point without, Manuel Caroli, 02/26/2009
- Re: [cgal-discuss] Transformation of 3d point without, Manuel Caroli, 02/27/2009
- Re: Re: [cgal-discuss] Transformation of 3d point without, matthias.kunz, 02/27/2009
- Re: [cgal-discuss] Transformation of 3d point without, Laurent Rineau (GeometryFactory), 02/27/2009
