- To:
- Subject: Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?
- Date: Mon, 09 Mar 2009 11:27:13 -0200
Hi Tom,
P:\Program Files (x86)\CGAL-3.4>cmake .^^^^^^^^^^^^^^^^^^^^
So you have a 64-bits Windows, right?
Did you try with the 32-bits or 64-bits gmp libs?
And did you try with the 32 or 64 bits Configuration in the VS IDE?
Thanks
Fernando Cacciola
www.geometryfactory.com
- Re: [cgal-discuss] Jet_fitting_3, (continued)
- Re: [cgal-discuss] Jet_fitting_3, Andreas Fabri, 03/05/2009
- [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/05/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Fernando Cacciola, 03/05/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/05/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/06/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/07/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Mahmood Naderan, 03/08/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/08/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Fernando Cacciola, 03/09/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Tom Kazimiers, 03/10/2009
- Re: [cgal-discuss] Linker errors in CGAL 3.4 examples?, Fernando Cacciola, 03/10/2009
- Re: [cgal-discuss] Jet_fitting_3, Priyamvad Deshmukh, 03/05/2009
- [cgal-discuss] Triangulation of a Polygon_with_holes_2 without introducing Steiner points, BBB HHH, 03/05/2009
- Re: [cgal-discuss] Triangulation of a Polygon_with_holes_2 without introducing Steiner points, Laurent Rineau (GeometryFactory), 03/05/2009
- Re : [cgal-discuss] Triangulation of a Polygon_with_holes_2 without introducing Steiner points, BBB HHH, 03/05/2009
- Re: [cgal-discuss] Jet_fitting_3, Priyamvad Deshmukh, 03/06/2009
- Re: [cgal-discuss] Jet_fitting_3, Marc Pouget, 03/08/2009
