cgal-discuss - [cgal-discuss] Boolean operations on Nef Polyhedra
  • To:
  • Subject: [cgal-discuss] Boolean operations on Nef Polyhedra
  • Date: Fri, 20 Mar 2009 14:22:13 +0100
Hello!
I am new to CGAL and i am having two questions, wondering (after reading
some parts of the documentation) whether our requirements could be
fulfilled by the library.
We have OFF files describing surfaces of bone structures in 3d. Boolean
operations in 3d require Nef polyhedra, not only Polyhedron_3. I
inspected the example source files. All source code examples of Nef
Polyhedra are built with GMP integers.
typedef CGAL::Gmpz NT;
typedef CGAL::Homogeneous<NT> Kernel;
Is it possible to built a nef polyhedra e.g. with
typedef CGAL::Simple_cartesian<double> Kernel;
When i try that, a multitude of error messages occurs from several
headers (see below). When i use Gmpz the program compiles but does not
read in the OFF files, cause they contain float values.
My program so far consists of:
- reading in two polyhedra as in
"CGAL/examples/Polyhedron_IO/off2stl.cpp"
- converting the polygon p with the Nef_polyhedron constructor:
Nef_polyhedron N1(P);
- Subtracting the nef polyhedra
N2 -= N1;
- converting the nef polyhedra back to a polyhedra_3
N2.convert_to_Polyhedron(P);
- and writing this polyhedra back to a file, like in the example
"off2stl.cpp".
See below for the declarations and error messages. Some advice or hint
would be very nice. Thank you.
Kind regards,
Christoph
typedef Kernel::Point_3 Point;
typedef Kernel::Vector_3 Vector;
typedef CGAL::Polyhedron_3<Kernel> Polyhedron;
typedef Polyhedron::Vertex_iterator Vertex_iterator;
typedef Polyhedron::Facet_iterator Facet_iterator;
typedef Polyhedron::Halfedge_handle Halfedge_handle;
#include <CGAL/Nef_polyhedron_3.h>
#include <CGAL/IO/Nef_polyhedron_iostream_3.h>
typedef CGAL::Nef_polyhedron_3<Kernel> Nef_polyhedron;
i had to translate the error messages back to english (german msvc++).
*** multiple times:
Fehler 3 error C2676: Binärer Operator '*=': 'CGAL::Null_tag' operator
or conversion not defined
C:\Programme\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h 306
*** multiple times:
Fehler 18 error C2440: '<function-style-cast>': 'CGAL::Null_tag' can't
be converted to 'FT'
C:\Programme\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h 323
*** multiple times:
Fehler 1 error C2064: expression does not evaluate to a function taking
three arguments
übernimmt C:\Programme\CGAL-3.3.1\include\CGAL\Nef_S2\Normalizing.h 300
