- To:
- Subject: Re: [cgal-discuss] Boolean operations on Nef Polyhedra
- Date: Tue, 24 Mar 2009 11:14:33 +0100
Hi all,
After debugging i see: the application simply fails after some minutes
cause it gets no more memory when doing a "new" while construction the
polyhedron from the bone structure. I have 2 Gig physical memory and up
to 8 Gig virtual.
So far the memory requirements of CGAL seem to be too high for us.
Kind regards,
Christoph
- [cgal-discuss] Boolean operations on Nef Polyhedra, Christoph Conrad, 03/20/2009
- Re: [cgal-discuss] Boolean operations on Nef Polyhedra, Peter Hachenberger, 03/20/2009
- Re: [cgal-discuss] Boolean operations on Nef Polyhedra, Christoph Conrad, 03/20/2009
- Re: [cgal-discuss] Boolean operations on Nef Polyhedra, Andreas Fabri, 03/20/2009
- Re: [cgal-discuss] Boolean operations on Nef Polyhedra, Christoph Conrad, 03/23/2009
- Re: [cgal-discuss] Boolean operations on Nef Polyhedra, Christoph Conrad, 03/24/2009
- Re: [cgal-discuss] Boolean operations on Nef Polyhedra, Laurent Rineau (GeometryFactory), 03/24/2009
- Re: [cgal-discuss] Boolean operations on Nef Polyhedra, Andreas Fabri, 03/24/2009
- Re: [cgal-discuss] Boolean operations on Nef Polyhedra, Peter Hachenberger, 03/27/2009
