- To:
- Subject: Re: [cgal-discuss] Boolean operations on Nef Polyhedra
- Date: Fri, 20 Mar 2009 16:02:13 +0100
Hi Andreas,
thank you very much for giving me that very helpful advices.
Both ways seem to work, the simple test program is compilable, that is a
big step forward. It reads one file with test data, another one gives
some problems, but that i must investigate a little bit first, maybe
"triangles" consisting of three identical points.
Kind regards,
Christoph
- [cgal-discuss] Boolean operations on Nef Polyhedra, Christoph Conrad, 03/20/2009
- Re: [cgal-discuss] Boolean operations on Nef Polyhedra, Peter Hachenberger, 03/20/2009
- Re: [cgal-discuss] Boolean operations on Nef Polyhedra, Christoph Conrad, 03/20/2009
- Re: [cgal-discuss] Boolean operations on Nef Polyhedra, Andreas Fabri, 03/20/2009
- Re: [cgal-discuss] Boolean operations on Nef Polyhedra, Christoph Conrad, 03/23/2009
- Re: [cgal-discuss] Boolean operations on Nef Polyhedra, Christoph Conrad, 03/24/2009
- Re: [cgal-discuss] Boolean operations on Nef Polyhedra, Laurent Rineau (GeometryFactory), 03/24/2009
- Re: [cgal-discuss] Boolean operations on Nef Polyhedra, Andreas Fabri, 03/24/2009
- Re: [cgal-discuss] Boolean operations on Nef Polyhedra, Peter Hachenberger, 03/27/2009
