- To:
- Subject: Re: [cgal-discuss] Boolean operations on Nef Polyhedra
- Date: Mon, 23 Mar 2009 12:19:59 +0100
Hi David,
> since you are ending up with something that sounds like it does most
> of what I'm needing, could you please send me your program for me to
> use as a starting point?
Yes, sure. But there seems to be a lot of work left. I send the source
code to you. Essentially it is a raw hacked and only slightly modified
"off2stl.cpp" from the examples directory, and far away from beeing
production ready code.
Kind regards,
Christoph
- Re: [cgal-discuss] Boolean operations on Nef Polyhedra, (continued)
- Re: [cgal-discuss] Boolean operations on Nef Polyhedra, Christoph Conrad, 03/20/2009
- Re: [cgal-discuss] Boolean operations on Nef Polyhedra, Andreas Fabri, 03/20/2009
- Re: [cgal-discuss] Boolean operations on Nef Polyhedra, Christoph Conrad, 03/23/2009
- Re: [cgal-discuss] Boolean operations on Nef Polyhedra, Christoph Conrad, 03/24/2009
- Re: [cgal-discuss] Boolean operations on Nef Polyhedra, Laurent Rineau (GeometryFactory), 03/24/2009
- Re: [cgal-discuss] Boolean operations on Nef Polyhedra, Andreas Fabri, 03/24/2009
- Re: [cgal-discuss] Boolean operations on Nef Polyhedra, Peter Hachenberger, 03/27/2009
