- To:
- Subject: [cgal-discuss] PSLG 2D Delaunay Triangulation
- Date: Thu, 2 Apr 2009 13:25:02 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=from:to:subject:date:user-agent:mime-version:content-type :content-transfer-encoding:content-disposition:message-id; b=TNAToF62EvOaPUyUhXjmaC3O5BWkviV6aWKpMk/fCPRo2tgt+lok2V39Sw4B3so4ch Yu6u2IkkFVdZH+97/OluZpENiJxuFULoywFKSNw2z5SKv+gZGLhuReE2iXWSErdqvfJp 1kWVzeFTnG7u1x6cM8EbTfRuru7ZA+mHG5QEo=
Hello all.
I use CGAL to get a 2D Contrained Delaunay Triangulation (CDT) of a PSLG.
Since CGAL returns only the CDT of the convex hull of the input points (that
belong to the PSLG), I then apply a post-processing method to remove all the
triangles outiside the PSLG.
The resulting mesh is correct: correct number of (infinite/finite) edges,
correct number of (infinite/finite) faces, and correct interconnection among
all the faces. The visualization of the resulting mesh further confirms its
correctness.
However, the mesh does not pass the is_valid() assertion method provided by
CGAL:
-----> is this because the resulting mesh does not triangulate the convex
hull
(as expected) of the PSLG, or there is a well-hidden error in the output mesh
that only the CGAL assertion method can detect?
Now, lets try to play with this output mesh, depsite the fact the CGAL
assertion method complains. Strange things again.
If I insert a point inside the PSLG, the updated mesh is no more invalid: it
passes any kind of assertion tests. However, when I insert a point outside
the PSLG, the updated test does not still pass the assertion test.
---> Any ideas?
I would really appreciate any help,
Thank you very much,
Panagiotis Foteinos
- [cgal-discuss] PSLG 2D Delaunay Triangulation, panayiotis foteinos, 04/02/2009
- Re: [cgal-discuss] PSLG 2D Delaunay Triangulation, Andreas Fabri, 04/02/2009
- Re: [cgal-discuss] PSLG 2D Delaunay Triangulation, Olivier Devillers, 04/03/2009
- Re: [cgal-discuss] PSLG 2D Delaunay Triangulation, panayiotis foteinos, 04/03/2009
- Re: [cgal-discuss] PSLG 2D Delaunay Triangulation, Andreas Fabri, 04/03/2009
- Re: [cgal-discuss] PSLG 2D Delaunay Triangulation, Olivier Devillers, 04/05/2009
- Re: [cgal-discuss] PSLG 2D Delaunay Triangulation, Mariette Yvinec, 04/06/2009
