cgal-discuss - Re: [cgal-discuss] PSLG 2D Delaunay Triangulation
  • To:
  • Subject: Re: [cgal-discuss] PSLG 2D Delaunay Triangulation
  • Date: Fri, 03 Apr 2009 22:30:23 +0200
The infinite vertex is SYMBOLIC, that is you shouldn't take its point
and evaluate geometric predicates with it
andreas
panayiotis foteinos wrote:
Thank you.
There is something else I do not quite understand. Could you explain how I can orient an infinite triangle?
Why the predicate orientation(infinite_vertex()->point(), Point(0,0), Point(0,6)) gives -1 (CLOCKWISE), but the test orientation(infinite_vertex()->point(), Point(1,0), Point(0,6)) gives 1 (COUNTERCLOCKWISE) ?
Regards,
Panagiotis Foteinos
On Friday 03 April 2009 03:39:47 Olivier Devillers wrote:
panayiotis foteinos a écrit :
-----> is this because the resulting mesh does not triangulate the convex
hull
yes
(see the source of is_valid in Triuangulation_2.h)
either you only use the is_valid of the tds (do not check orientation
of triangles)
either you rewrite your own is_valid keeping the geometric check only
fot finite triangles.
