cgal-discuss - Re: [cgal-discuss] PSLG 2D Delaunay Triangulation
  • To:
  • Subject: Re: [cgal-discuss] PSLG 2D Delaunay Triangulation
  • Date: Fri, 03 Apr 2009 09:39:47 +0200
panayiotis foteinos a écrit :
-----> is this because the resulting mesh does not triangulate the convex hull
yes
(see the source of is_valid in Triuangulation_2.h)
either you only use the is_valid of the tds (do not check orientation of triangles)
either you rewrite your own is_valid keeping the geometric check only fot finite triangles.
