- To: <>
- Subject: Re: [cgal-discuss] Nef_3 Question
- Date: Mon, 11 May 2009 14:22:25 +0530
Hi
Unfortunately, the algorithms from the Nef package can not work with
inexact numbers. I think one would need to use a completely different
approach to make booleans work with inexact math, but that would
probably sacrifice correctness in certain cases.
Is the polyhydron intersection is implemented with BSP tree ?
----- Original Message ----- From: "Bart Janssens" <>
To:
Sent: Saturday, May 09, 2009 8:57 PM
On Sat, May 9, 2009 at 1:20 PM, naresh
wrote:
I am trying to find two polyhydron intersection in nef_3 package. But i
found process is very slow because of exact arithmatic calculations.
So i have question can i use use inexact arithmatic that gives me speed ?
Hi Alex,
Cheers,
Bart
- [cgal-discuss] Nef_3 Question, naresh, 05/09/2009
- Re: [cgal-discuss] Nef_3 Question, Bart Janssens, 05/09/2009
- [cgal-discuss] Retrieving Subconstraints in CDTplus, Matthias Teich, 05/10/2009
- Re: [cgal-discuss] Retrieving Subconstraints in CDTplus, Matthias Teich, 05/11/2009
- Re: [cgal-discuss] Retrieving Subconstraints in CDTplus, Damian Sheehy, 05/11/2009
- Re: [cgal-discuss] Retrieving Subconstraints in CDTplus, Andreas Fabri, 05/12/2009
- Re: [cgal-discuss] Nef_3 Question, naresh, 05/11/2009
- Re: [cgal-discuss] Nef_3 Question, Peter Hachenberger, 05/11/2009
- Re: [cgal-discuss] Nef_3 Question, dekosser, 05/11/2009
- Message not available
- Re: [cgal-discuss] Nef_3 Question, dekosser, 05/12/2009
- Re: [cgal-discuss] Nef_3 Question, Peter Hachenberger, 05/12/2009
