cgal-discuss - Re: [cgal-discuss] Nef_3 Question
  • To: <>
  • Subject: Re: [cgal-discuss] Nef_3 Question
  • Date: Mon, 11 May 2009 16:40:44 +0530
Hi Peter
>> We use a kd-tree for point location and ray shooting. But I guess
>> that was not what you were asking for, was it?
You are right. Basically I read in Geometeric Tools by Eberly about BSP tree. Acording to him BSP tree will faster then linear intersection.
But you said it use Kd-tree so it will do same Job as BSP so speed will be same.  In fact i was trying to search why CGAL implemetation of nef_3 is slower.
BTW. Since you are the auther let me ask .
Is there any method i can increase speed because my application has lot of operations. ?
Alex
----- Original Message -----
To:
Sent: Monday, May 11, 2009 3:51 PM
that was not what you were asking for, was it? Look into
the manual to get an idea of the data structure, or have
a look at the papers on our implementation for a deeper
insight.
http://www.win.tue.nl/~phachenb/Nef/Nef3D-DataStructureAlgorithms.pdf
Peter
-----"naresh" <> wrote: -----
To: <>
Date: 05/11/2009 10:52AM
Hi
> Unfortunately, the algorithms from the Nef package can not work with
> inexact numbers. I think one would need to use a completely different
> approach to make booleans work with inexact math, but that would
> probably sacrifice correctness in certain cases.
Is the polyhydron intersection is implemented with BSP tree ?
To: <>
Sent: Saturday, May 09, 2009 8:57 PM
> On Sat, May 9, 2009 at 1:20 PM, naresh <> wrote:
>> I am trying to find two polyhydron intersection in nef_3 package. But i
>> found process is very slow because of exact arithmatic calculations.
>> So i have question can i use use inexact arithmatic that gives me speed ?
> Hi Alex,
> Cheers,
> Bart
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
