cgal-discuss - Re: [cgal-discuss] Retrieving Subconstraints in CDTplus
  • To:
  • Subject: Re: [cgal-discuss] Retrieving Subconstraints in CDTplus
  • Date: Tue, 12 May 2009 15:00:03 +0200
Hi Matthias,
Damian is right. The value_type of the CDTplus::Subconstraint_iterator
is std::pair< std::pair<Vertex_handle, Vertex_handle>, undocumentedClass >
so it->first.first and it->first.second do the job.
We will fix the code, as the manual is right.
andreas
Damian Sheehy wrote:
Hi Matthias,
I believe it's a bug in the documentation.
Can someone from the CGAL dev team confirm?
Try this. . . .
CDTplus::Vertex_handle v1, v2;
for (CDTplus::Subconstraint_
iterator c_it = cdt.subconstraints_begin(); c_it != cdt.subconstraints_end(); ++c_it)
v1 = c_it->first.first;
v2 = c_it->first.second;
Regards,
Damian
On Mon, May 11, 2009 at 6:40 AM, Matthias Teich < <mailto:>> wrote:
Hi again!
I am still looking for a way to retrieve the vertex_handles from a
subconstraint in a constrained triangluation plus.
Any hints are really appreciated.
Best Regards,
Matthias
Matthias schrieb:
Hi!
The documentation says:
"Constrained triangulation plus 2<Tr>:: Subconstraint iterator
An iterator to visit all the sub-constraints of the triangulation.
The order of visit is arbitrary. The value type of this iterator is
a pair std::pair<Vertex handle, Vertex handle> corresponding
to the vertices of the sub-constraint"
So I thought the following should work:
for (CDTplus::Subconstraint_iterator c_it =
++c_it)
std::pair<CDTplus::Vertex_handle,CDTplus::Vertex_handle>
pair = *c_it;
// do sth with pair
Can anyone explain how I can retrieve the subconstraints?
What follows is the lengthy error message from visual studio:
::CC_iterator<DSC,Const>::CC_iterator(const
CGAL::CGALi::CC_iterator<DSC,Const> &)' : cannot convert
parameter 1 from 'const std::pair<_Ty1,_Ty2>' to 'const
CGAL::CGALi::CC_iterator<DSC,Const> &'
1> with
1> [
1> DSC=CGAL::Compact_container<CGAL::Triangulation_vertex_base_2<Kernel,CGAL::Triangulation_ds_vertex_base_2<CGAL::Triangulation_data_structure_2<Vb,Fb>>>>,
1> Const=false
1> ]
1> and
1> [
1> _Ty1=CGAL::CGALi::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_vertex_base_2<Kernel,CGAL::Triangulation_ds_vertex_base_2<CGAL::Triangulation_data_structure_2<Vb,Fb>>>>,false>,
1> _Ty2=CGAL::CGALi::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_vertex_base_2<Kernel,CGAL::Triangulation_ds_vertex_base_2<CGAL::Triangulation_data_structure_2<Vb,Fb>>>>,false>
1> ]
1> and
1> [
1> Const=false
1> ]
1> Reason: cannot convert from 'const
std::pair<_Ty1,_Ty2>' to 'const CGAL::CGALi::CC_iterator<DSC,Const>'
1> with
1> [
1> ]
1> and
1> [
1> Const=false
1> ]
1> No user-defined-conversion operator available that can
perform this conversion, or the operator cannot be called
1> .\MeshOffsetter.cpp(534) : see reference to function
template instantiation 'std::pair<_Ty1,_Ty2>::pair<const
_Kty,_Ty>(const std::pair<const _Kty,_Ty> &)' being compiled
1> with
1> [
1> _Ty2=CGAL::CGALi::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_vertex_base_2<Kernel,CGAL::Triangulation_ds_vertex_base_2<CGAL::Triangulation_data_structure_2<Vb,Fb>>>>,false>,
1> _Kty=std::pair<CGAL::CGALi::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_vertex_base_2<Kernel,CGAL::Triangulation_ds_vertex_base_2<CGAL::Triangulation_data_structure_2<Vb,Fb>>>>,false>,CGAL::CGALi::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_vertex_base_2<Kernel,CGAL::Triangulation_ds_vertex_base_2<CGAL::Triangulation_data_structure_2<Vb,Fb>>>>,false>>,
1> _Ty=std::list<CGAL::Constraint_hierarchy_2<CGAL::CGALi::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_vertex_base_2<Kernel,CGAL::Triangulation_ds_vertex_base_2<CGAL::Triangulation_data_structure_2<Vb,Fb>>>>,false>,bool>::H_context>
1> ]
Eingehende eMail ist virenfrei.
Von AVG überprüft - www.avg.de <http://www.avg.de> Version:
8.5.325 / Virendatenbank: 270.12.23/2106 - Ausgabedatum:
05/09/09 06:54:00
-- You are currently subscribed to cgal-discuss.
