- To: <>
- Subject: RE: [cgal-discuss] orientation compatibility of triangular facets
- Date: Fri, 15 May 2009 12:13:24 +0800
Borrowing Nizar's thread to ask a different question...
> A 3D triangulation is a decomposition of the space into 3D cells
> (tetrahedra). 3D cells _are_ actually consistently oriented.
> (see the user manuals of chapters 3d traingulation and 3d triangulation
> data structure)
Hello Monique,
Does that mean a 3D triangulation could be regarded as a 3D version of
Arrangement_2?
If the answer is yes, is there an easy way to build such a decomposition of
the whole 3D
space with a given 2D triangular meshing (e.g. a 2d element model in finite
element analysis)
in the 3D space?
B/Rgds
Max
- [cgal-discuss] orientation compatibility of triangular facets, Nizar Khalifa Sallem, 05/14/2009
- Re: [cgal-discuss] orientation compatibility of triangular facets, Andreas Fabri, 05/14/2009
- Re: [cgal-discuss] orientation compatibility of triangular facets, Nizar Khalifa Sallem, 05/14/2009
- Re: [cgal-discuss] orientation compatibility of triangular facets, Monique Teillaud, 05/14/2009
- Re: [cgal-discuss] orientation compatibility of triangular facets, Laurent Rineau (GeometryFactory), 05/14/2009
- RE: [cgal-discuss] orientation compatibility of triangular facets, Max, 05/15/2009
