cgal-discuss - Re: [cgal-discuss] orientation compatibility of triangular facets
  • To:
  • Subject: Re: [cgal-discuss] orientation compatibility of triangular facets
  • Date: Thu, 14 May 2009 16:23:00 +0200
Thank you all and especially to Laurent who guessed my needs :)
I think that a look to the function mentioned by Andreas could effectively help, else I thought about a little trick. I will let you know which one works for me.
Thank you all again
Nizar SALLEM
Robotics and Artificial Intelligence PhD student
LAAS-CNRS
7, Avenue Colonel Roche
31077 Toulouse CEDEX 4
FRANCE
On May 14, 2009, at 4:06 PM, Laurent Rineau (GeometryFactory) wrote:
On Thursday 14 May 2009 15:53:33 Monique Teillaud wrote:
A 3D triangulation is a decomposition of the space into 3D cells
(tetrahedra). 3D cells _are_ actually consistently oriented.
(see the user manuals of chapters 3d traingulation and 3d triangulation
data structure)
Nizar is talking about *facets* of a 3D triangulation. Facets of a 3D
triangulation are not stored in the data-structure. Only the vertices and the
cells of the triangulation are stored, and facets are implicit. The cells of
the triangulation are consistently oriented, and for that reason it is
possible to consistently orient two facets incident to the same edge, but that
is not strait-forward.
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
