- To:
- Subject: Re: [cgal-discuss] Polyhedron demo problem (bis)
- Date: Wed, 20 May 2009 11:49:46 +0200
On Wednesday 20 May 2009 10:35:36 Martial TOLA (CNRS-Liris) wrote:
> Hello
> >Strange: libCGAL_Qt4.dylib is not in that list! Have you build CGAL with
> > Qt4 support?
> Of course, Qt4 is on (but Qt3 is off like under windows and linux), you can
> see that in cmake-gui.txt.
> Here is the logs with -v (make cgal and make Polyhedron).
> Thank you for your help.
That confirms that, although CGAL_Qt4 is detected at the configuration time,
libCGAL_Qt4.dylib is not linked with the executable. Add -lCGAL_Qt4 manually
to CMAKE_EXE_LINKER_FLAGS.
Well,... I now remember that we (CGAL developers) have detected that
CMake-2.6.3 broke the compatibility with previous versions of CMake on one
detail used in CGAL scripts. We have a patch for the upcoming CGAL-3.4.1.
I have attached the patch, if you are willing to test it...
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
Index: cmake/modules/CGAL_VersionUtils.cmake =================================================================== --- cmake/modules/CGAL_VersionUtils.cmake (revision 0) +++ cmake/modules/CGAL_VersionUtils.cmake (revision 49504) @@ -0,0 +1,230 @@ +set(CMAKE_ALLOW_LOOSE_LOOP_CONSTRUCTS true) + +if ( NOT CGAL_VERSION_UTILS_FILE_INCLUDED ) + set( CGAL_VERSION_UTILS_FILE_INCLUDED 1 ) + +# +# Given a version string of the form "major.[minor.[patch.[tweak]]]" +# decomposes it into components +# +macro( VERSION_DECOMPOSE v major minor patch tweak ) + + string(REPLACE "." ";" VERSION_DECOMPOSE_LIST ${v} ) + + list( LENGTH VERSION_DECOMPOSE_LIST VERSION_DECOMPOSE_LIST_LEN ) + + if ( VERSION_DECOMPOSE_LIST_LEN GREATER 0 ) + list( GET VERSION_DECOMPOSE_LIST 0 ${major} ) + else() + set ( ${major} -1 ) + endif() + + if ( VERSION_DECOMPOSE_LIST_LEN GREATER 1 ) + list( GET VERSION_DECOMPOSE_LIST 1 ${minor} ) + else() + set ( ${minor} -1 ) + endif() + + if ( VERSION_DECOMPOSE_LIST_LEN GREATER 2 ) + list( GET VERSION_DECOMPOSE_LIST 2 ${patch} ) + else() + set ( ${patch} -1 ) + endif() + + if ( VERSION_DECOMPOSE_LIST_LEN GREATER 3 ) + list( GET VERSION_DECOMPOSE_LIST 3 ${tweak} ) + else() + set ( ${tweak} -1 ) + endif() + +endmacro() + +# +# Given two version string of the form "major.[minor.[patch.[tweak]]]" +# returns TRUE if they are equal, FALSE otherwise. +# +macro( IS_VERSION_EQUAL a b r ) + + VERSION_DECOMPOSE( ${a} _IVE_a_major _IVE_a_minor _IVE_a_patch _IVE_a_tweak ) + VERSION_DECOMPOSE( ${b} _IVE_b_major _IVE_b_minor _IVE_b_patch _IVE_b_tweak ) + + set ( ${r} FALSE ) + + if ( _IVE_a_major EQUAL ${_IVE_b_major} ) + if ( _IVE_a_minor EQUAL ${_IVE_b_minor} ) + if ( _IVE_a_patch EQUAL ${_IVE_b_patch} ) + if ( _IVE_a_tweak EQUAL ${_IVE_b_tweak} ) + set ( ${r} TRUE ) + endif() + endif() + endif() + endif() + +endmacro() + +# +# Given two version string of the form "major.[minor.[patch.[tweak]]]" +# returns TRUE if the first is smaller than the second, FALSE otherwise. +# +macro( IS_VERSION_LESS a b r ) + + VERSION_DECOMPOSE( ${a} _IVL_a_major _IVL_a_minor _IVL_a_patch _IVL_a_tweak ) + VERSION_DECOMPOSE( ${b} _IVL_b_major _IVL_b_minor _IVL_b_patch _IVL_b_tweak ) + + set ( ${r} FALSE ) + + if ( _IVL_a_major LESS ${_IVL_b_major} ) + set ( ${r} TRUE ) + elseif( _IVL_a_major EQUAL ${_IVL_b_major}) + if ( _IVL_a_minor LESS ${_IVL_b_minor} ) + set ( ${r} TRUE ) + elseif( _IVL_a_minor EQUAL ${_IVL_b_minor} ) + if ( _IVL_a_patch LESS ${_IVL_b_patch} ) + set ( ${r} TRUE ) + elseif( _IVL_a_patch EQUAL ${_IVL_b_patch} ) + if ( _IVL_a_tweak LESS ${_IVL_b_tweak} ) + set ( ${r} TRUE ) + endif() + endif() + endif() + endif() + +endmacro() + +# +# Given two version string of the form "major.[minor.[patch.[tweak]]]" +# returns TRUE if the first is greater than the second, FALSE otherwise. +# +macro( IS_VERSION_GREATER a b r ) + + IS_VERSION_LESS( ${a} ${b} _IVG_less ) + + if ( _IVG_less ) + set( ${r} FALSE ) + else() + + IS_VERSION_EQUAL( ${a} ${b} _IVG_eq ) + + if ( _IVG_eq ) + set( ${r} FALSE ) + else() + set( ${r} TRUE ) + endif() + + endif() + +endmacro() + + + + + + + + + + + + + + +# +# -= TESTING =- +# + + +macro ( TEST_VERSION_DECOMPOSE v expected_major expected_minor expected_patch expected_tweak ) + + VERSION_DECOMPOSE( ${v} major minor patch tweak ) + + set ( OK 0 ) + + if ( major EQUAL "${expected_major}" ) + if ( minor EQUAL "${expected_minor}" ) + if ( patch EQUAL "${expected_patch}" ) + if ( tweak EQUAL "${expected_tweak}" ) + set ( OK 1 ) + endif() + endif() + endif() + endif() + + if ( OK ) + message( STATUS "correct - ${v} -> ${major}, ${minor}, ${patch}, ${tweak} " ) + else() + message( STATUS "FAILED - ${v} -> ${major}, ${minor}, ${patch}, ${tweak} " ) + endif() + +endmacro() + +macro ( TEST_VERSION_COMPARISON op v0 v1 expected ) + + if ( "${op}" STREQUAL "<" ) + IS_VERSION_LESS( ${v0} ${v1} result ) + elseif ( "${op}" STREQUAL ">" ) + IS_VERSION_GREATER( ${v0} ${v1} result ) + else() + IS_VERSION_EQUAL( ${v0} ${v1} result ) + endif() + + if ( result STREQUAL ${expected} ) + message( STATUS "correct - ${v0} ${op} ${v1} => ${result}" ) + else() + message( STATUS "FAILED - ${v0} ${op} ${v1} => ${result}" ) + endif() + +endmacro() + +if ( UNIT_TEST_VERSION_UTILS ) + + TEST_VERSION_DECOMPOSE("1.2.3.4" 1 2 3 4 ) + TEST_VERSION_DECOMPOSE("1.2.3" 1 2 3 -1 ) + TEST_VERSION_DECOMPOSE("1.2" 1 2 -1 -1 ) + TEST_VERSION_DECOMPOSE("1" 1 -1 -1 -1 ) + + TEST_VERSION_COMPARISON( "==" "1.2.3.4" "1.2.3.4" TRUE ) + TEST_VERSION_COMPARISON( "==" "1.2.3" "1.2.3" TRUE ) + TEST_VERSION_COMPARISON( "==" "1.2" "1.2" TRUE ) + TEST_VERSION_COMPARISON( "==" "1" "1" TRUE ) + + TEST_VERSION_COMPARISON( "==" "1.2.3.4" "1.2.3" FALSE ) + TEST_VERSION_COMPARISON( "==" "1.2.3" "1.2" FALSE ) + TEST_VERSION_COMPARISON( "==" "1.2" "1" FALSE ) + + TEST_VERSION_COMPARISON( "==" "1.2.3.4" "1.2.3.5" FALSE ) + TEST_VERSION_COMPARISON( "==" "1.2.3" "1.2.4" FALSE ) + TEST_VERSION_COMPARISON( "==" "1.2" "1.3" FALSE ) + TEST_VERSION_COMPARISON( "==" "1" "2" FALSE ) + + TEST_VERSION_COMPARISON( "<" "1.2.3.4" "1.2.3.4" FALSE ) + TEST_VERSION_COMPARISON( "<" "1.2.3" "1.2.3" FALSE ) + TEST_VERSION_COMPARISON( "<" "1.2" "1.2" FALSE ) + TEST_VERSION_COMPARISON( "<" "1" "1" FALSE ) + + TEST_VERSION_COMPARISON( "<" "1.2.3.4" "1.2.3.5" TRUE ) + TEST_VERSION_COMPARISON( "<" "1.2.3.4" "1.2.4.5" TRUE ) + TEST_VERSION_COMPARISON( "<" "1.2.3.4" "1.3.4.5" TRUE ) + TEST_VERSION_COMPARISON( "<" "1.2.3.4" "2.3.4.5" TRUE ) + + TEST_VERSION_COMPARISON( "<" "1.2.3.4" "1.2.4" TRUE ) + TEST_VERSION_COMPARISON( "<" "1.2.3.4" "1.3" TRUE ) + TEST_VERSION_COMPARISON( "<" "1.2.3.4" "2" TRUE ) + + TEST_VERSION_COMPARISON( "<" "1.2.3" "1.2.4" TRUE ) + TEST_VERSION_COMPARISON( "<" "1.2" "1.3" TRUE ) + TEST_VERSION_COMPARISON( "<" "1" "2" TRUE ) + + TEST_VERSION_COMPARISON( "<" "1.2.3.6" "1.2.4.5" TRUE ) + TEST_VERSION_COMPARISON( "<" "1.2.5.6" "1.3.4.5" TRUE ) + TEST_VERSION_COMPARISON( "<" "1.4.5.6" "2.3.4.5" TRUE ) + + TEST_VERSION_COMPARISON( ">" "1.2.3.4" "1.2.3.4" FALSE ) + TEST_VERSION_COMPARISON( ">" "1.2.3" "1.2.3" FALSE ) + TEST_VERSION_COMPARISON( ">" "1.2" "1.2" FALSE ) + TEST_VERSION_COMPARISON( ">" "1" "1" FALSE ) + + TEST_VERSION_COMPARISON( ">" "1.2.3.5" "1.2.3.4" TRUE ) + +endif() + +endif() \ No newline at end of file Index: cmake/modules/CGAL_SetupFlags.cmake =================================================================== --- cmake/modules/CGAL_SetupFlags.cmake (revision 47550) +++ cmake/modules/CGAL_SetupFlags.cmake (working copy) @@ -1,3 +1,6 @@ +if ( NOT CGAL_SETUP_FLAGS_INCLUDED ) + set( CGAL_SETUP_FLAGS_INCLUDED 1 ) + # # Set CGAL_DONT_OVERRIDE_CMAKE_FLAGS to TRUE if you need to prevent the CGAL configuration to # override the flags used to build the libraries @@ -75,3 +78,4 @@ endif() +endif() Index: cmake/modules/CGALConfig_binary.cmake.in =================================================================== --- cmake/modules/CGALConfig_binary.cmake.in (revision 47550) +++ cmake/modules/CGALConfig_binary.cmake.in (working copy) @@ -122,3 +122,6 @@ check_cgal_component("_${CGAL_COMPONENT}") endforeach() +# Starting with cmake 2.6.3, CGAL_FIND_COMPONENTS is cleared out when find_package returns. +# But we need it within UseCGAL.cmake, so we save it aside into another variable +set( CGAL_REQUESTED_COMPONENTS ${CGAL_FIND_COMPONENTS} ) Index: cmake/modules/CGALConfig_install.cmake.fhs.in =================================================================== --- cmake/modules/CGALConfig_install.cmake.fhs.in (revision 47550) +++ cmake/modules/CGALConfig_install.cmake.fhs.in (working copy) @@ -124,3 +124,6 @@ check_cgal_component("_${CGAL_COMPONENT}") endforeach() +# Starting with cmake 2.6.3, CGAL_FIND_COMPONENTS is cleared out when find_package returns. +# But we need it within UseCGAL.cmake, so we save it aside into another variable +set( CGAL_REQUESTED_COMPONENTS ${CGAL_FIND_COMPONENTS} ) Index: cmake/modules/FindQGLViewer.cmake =================================================================== --- cmake/modules/FindQGLViewer.cmake (revision 47550) +++ cmake/modules/FindQGLViewer.cmake (working copy) @@ -15,7 +15,7 @@ ) find_library(QGLVIEWER_LIBRARY_RELEASE - NAMES QGLViewer QGLViewer2 + NAMES qglviewer QGLViewer QGLViewer2 PATHS /usr/lib /usr/local/lib ENV QGLVIEWERROOT @@ -25,7 +25,7 @@ ) find_library(QGLVIEWER_LIBRARY_DEBUG - NAMES dQGLViewer dQGLViewer2 + NAMES dqglviewer dQGLViewer dQGLViewer2 PATHS /usr/lib /usr/local/lib ENV QGLVIEWERROOT @@ -40,10 +40,11 @@ else() set(QGLVIEWER_LIBRARIES_ ${QGLVIEWER_LIBRARY_RELEASE}) endif() + + set(QGLVIEWER_LIBRARIES ${QGLVIEWER_LIBRARIES_} CACHE FILEPATH "The QGLViewer library") + endif() -set(QGLVIEWER_LIBRARIES ${QGLVIEWER_LIBRARIES_} CACHE FILEPATH "The QGLViewer library") - IF(QGLVIEWER_INCLUDE_DIR AND QGLVIEWER_LIBRARIES) SET(QGLVIEWER_FOUND TRUE) ENDIF(QGLVIEWER_INCLUDE_DIR AND QGLVIEWER_LIBRARIES) Index: cmake/modules/FindCGAL.cmake =================================================================== --- cmake/modules/FindCGAL.cmake (revision 47550) +++ cmake/modules/FindCGAL.cmake (working copy) @@ -11,7 +11,7 @@ # # Construct consitent error messages for use below. -set(CGAL_DIR_DESCRIPTION "directory containing CGALConfig.cmake. This is either the binary directory where CGAL was configured or PREFIX/lib/CGAL-3.4 for an installation.") +set(CGAL_DIR_DESCRIPTION "directory containing CGALConfig.cmake. This is either the binary directory where CGAL was configured or PREFIX/lib/CGAL for an installation.") set(CGAL_DIR_MESSAGE "CGAL not found. Set the CGAL_DIR cmake variable or environment variable to the ${CGAL_DIR_DESCRIPTION}") set(CMAKE_ALLOW_LOOSE_LOOP_CONSTRUCTS true) @@ -32,7 +32,7 @@ foreach(dir ${CGAL_DIR_SEARCH2}) - set(CGAL_DIR_SEARCH ${CGAL_DIR_SEARCH} ${dir}/../lib/CGAL-3.4 ) + set(CGAL_DIR_SEARCH ${CGAL_DIR_SEARCH} ${dir}/../lib/CGAL ) endforeach() @@ -49,8 +49,8 @@ ${CGAL_DIR_SEARCH} # Look in standard UNIX install locations. - /usr/local/lib/CGAL-3.4 - /usr/lib/CGAL-3.4 + /usr/local/lib/CGAL + /usr/lib/CGAL # Read from the CMakeSetup registry entries. It is likely that # CGAL will have been recently built. Index: cmake/modules/CGAL_Common.cmake =================================================================== --- cmake/modules/CGAL_Common.cmake (revision 47550) +++ cmake/modules/CGAL_Common.cmake (working copy) @@ -17,9 +17,19 @@ if (NOT CMAKE_ROOT) message( FATAL_ERROR "CMAKE_ROOT enviroment variable not set. It should point to the directory where CMake is installed.") endif() - + + # CMAKE_VERSION was introduced in 2.6.3 so we use it to detect the fact + if ( CMAKE_VERSION ) + set( CMAKE_2_6_3_OR_ABOVE TRUE ) + else() + set( CMAKE_2_6_3_OR_ABOVE FALSE ) + endif() + if ( COMMAND cmake_policy ) cmake_policy( SET CMP0007 OLD ) + if ( CMAKE_2_6_3_OR_ABOVE ) + cmake_policy( SET CMP0011 OLD ) + endif() endif() if ( "${BUILD_SHARED_LIBS}" STREQUAL "" ) @@ -52,7 +62,4 @@ set(CMAKE_COLORMAKEFILE ON) - # Needed by the testsuite results parser - set(CMAKE_VERBOSE_MAKEFILE ON) - endif() \ No newline at end of file Index: cmake/modules/UseCGAL.cmake =================================================================== --- cmake/modules/UseCGAL.cmake (revision 47550) +++ cmake/modules/UseCGAL.cmake (working copy) @@ -14,15 +14,12 @@ set(USE_CGAL_FILE_INCLUDED 1) include(CGAL_Common) + include(CGAL_SetupFlags) + include(CGAL_GeneratorSpecificSettings) - if ( CGAL_IS_CURRENT_SCRIPT_TOP_LEVEL ) - include(CGAL_SetupFlags) - include(CGAL_GeneratorSpecificSettings) - endif() - set( CGAL_LIBRARIES ) - foreach ( CGAL_COMPONENT ${CGAL_FIND_COMPONENTS} ) + foreach ( CGAL_COMPONENT ${CGAL_REQUESTED_COMPONENTS} ) add_to_list( CGAL_LIBRARIES ${CGAL_${CGAL_COMPONENT}_LIBRARY} ) add_to_list( CGAL_3RD_PARTY_LIBRARIES ${CGAL_${CGAL_COMPONENT}_3RD_PARTY_LIBRARIES} ) Index: cmake/modules/FindBoost.cmake =================================================================== --- cmake/modules/FindBoost.cmake (revision 47550) +++ cmake/modules/FindBoost.cmake (working copy) @@ -1,631 +1,895 @@ -# - Try to find Boost include dirs and libraries -# Usage of this module as follows: -# -# SET(Boost_USE_STATIC_LIBS ON) -# SET(Boost_USE_MULTITHREAD OFF) -# FIND_PACKAGE( Boost 1.34.1 COMPONENTS date_time filesystem iostreams ... ) -# -# The Boost_ADDITIONAL_VERSIONS variable can be used to specify a list of -# boost version numbers that should be taken into account when searching -# for the libraries. Unfortunately boost puts the version number into the -# actual filename for the libraries, so this might be needed in the future -# when new Boost versions are released. -# -# Currently this module searches for the following version numbers: -# 1.33, 1.33.0, 1.33.1, 1.34, 1.34.0, 1.34.1, 1.35, 1.35.0, 1.35.1, 1.36.0, -# 1.36.1 -# -# The components list needs to be the actual names of boost libraries, that is -# the part of the actual library files that differ on different libraries. So -# its "date_time" for "libboost_date_time...". Anything else will result in -# errors -# -# You can provide a minimum version number that should be used. If you provide this -# version number and specify the REQUIRED attribute, this module will fail if it -# can't find the specified or a later version. If you specify a version number this is -# automatically put into the considered list of version numbers and thus doesn't need -# to be specified in the Boost_ADDITIONAL_VERSIONS variable -# -# Variables used by this module, they can change the default behaviour and need to be set -# before calling find_package: -# Boost_USE_MULTITHREAD Can be set to OFF to use the non-multithreaded -# boost libraries. Defaults to ON. -# Boost_USE_STATIC_LIBS Can be set to ON to force the use of the static -# boost libraries. Defaults to OFF. -# Boost_ADDITIONAL_VERSIONS A list of version numbers to use for searching -# the boost include directory. The default list -# of version numbers is: -# 1.33, 1.33.0, 1.33.1, 1.34, 1.34.0, 1.34.1, -# 1.35, 1.35.0, 1.35.1, 1.36.0, 1.36.1 -# If you want to look for an older or newer -# version set this variable to a list of -# strings, where each string contains a number, i.e. -# SET(Boost_ADDITIONAL_VERSIONS "0.99.0" "1.35.0") -# BOOST_ROOT or BOOSTROOT Preferred installation prefix for searching for Boost, -# set this if the module has problems finding the proper Boost installation -# BOOST_INCLUDEDIR Set this to the include directory of Boost, if the -# module has problems finding the proper Boost installation -# BOOST_LIBRARYDIR Set this to the lib directory of Boost, if the -# module has problems finding the proper Boost installation -# -# The last three variables are available also as environment variables -# -# -# Variables defined by this module: -# -# Boost_FOUND System has Boost, this means the include dir was found, -# as well as all the libraries specified in the COMPONENTS list -# Boost_INCLUDE_DIRS Boost include directories, not cached -# Boost_INCLUDE_DIR This is almost the same as above, but this one is cached and may be -# modified by advanced users -# Boost_LIBRARIES Link these to use the Boost libraries that you specified, not cached -# Boost_LIBRARY_DIRS The path to where the Boost library files are. -# Boost_VERSION The version number of the boost libraries that have been found, -# same as in version.hpp from Boost -# Boost_LIB_VERSION The version number in filename form as its appended to the library filenames -# Boost_MAJOR_VERSION major version number of boost -# Boost_MINOR_VERSION minor version number of boost -# Boost_SUBMINOR_VERSION subminor version number of boost -# Boost_LIB_DIAGNOSTIC_DEFINITIONS Only set on windows. Can be used with add_definitions -# to print diagnostic information about the automatic -# linking done on windows. - -# For each component you list the following variables are set. -# ATTENTION: The component names need to be in lower case, just as the boost -# library names however the cmake variables use upper case for the component -# part. So you'd get Boost_SERIALIZATION_FOUND for example. -# -# Boost_${COMPONENT}_FOUND True IF the Boost library "component" was found. -# Boost_${COMPONENT}_LIBRARY The absolute path of the Boost library "component". -# Boost_${COMPONENT}_LIBRARY_DEBUG The absolute path of the debug version of the -# Boost library "component". -# Boost_${COMPONENT}_LIBRARY_RELEASE The absolute path of the release version of the -# Boost library "component" -# -# Copyright (c) 2006-2008 Andreas Schneider <> -# Copyright (c) 2007 Wengo -# Copyright (c) 2007 Mike Jackson -# Copyright (c) 2008 Andreas Pakulat <> -# -# Redistribution AND use is allowed according to the terms of the New -# BSD license. -# For details see the accompanying COPYING-CMAKE-SCRIPTS file. -# -OPTION(Boost_USE_MULTITHREADED - "Use the multithreaded versions of the Boost libraries" ON) - -if (Boost_FIND_VERSION_EXACT) - if (Boost_FIND_VERSION_PATCH) - set( _boost_TEST_VERSIONS - "${Boost_FIND_VERSION_MAJOR}.${Boost_FIND_VERSION_MINOR}.${Boost_FIND_VERSION_PATCH}") - else (Boost_FIND_VERSION_PATCH) - set( _boost_TEST_VERSIONS - "${Boost_FIND_VERSION_MAJOR}.${Boost_FIND_VERSION_MINOR}.0" - "${Boost_FIND_VERSION_MAJOR}.${Boost_FIND_VERSION_MINOR}") - endif (Boost_FIND_VERSION_PATCH) -else (Boost_FIND_VERSION_EXACT) - set( _boost_TEST_VERSIONS ${Boost_ADDITIONAL_VERSIONS} - "1.36.1" "1.36.0" "1.35.1" "1.35.0" "1.35" "1.34.1" "1.34.0" "1.34" "1.33.1" - "1.33.0" "1.33" ) -endif (Boost_FIND_VERSION_EXACT) - -# The reason that we failed to find Boost. This will be set to a -# user-friendly message when we fail to find some necessary piece of -# Boost. -set(Boost_ERROR_REASON) - -############################################ -# -# Check the existence of the libraries. -# -############################################ -# This macro was taken directly from the FindQt4.cmake file that is included -# with the CMake distribution. This is NOT my work. All work was done by the -# original authors of the FindQt4.cmake file. Only minor modifications were -# made to remove references to Qt and make this file more generally applicable -######################################################################### - -MACRO (_Boost_ADJUST_LIB_VARS basename) - IF (Boost_INCLUDE_DIR ) - IF (Boost_${basename}_LIBRARY_DEBUG AND Boost_${basename}_LIBRARY_RELEASE) - # if the generator supports configuration types then set - # optimized and debug libraries, or if the CMAKE_BUILD_TYPE has a value - IF (CMAKE_CONFIGURATION_TYPES OR CMAKE_BUILD_TYPE) - SET(Boost_${basename}_LIBRARY optimized ${Boost_${basename}_LIBRARY_RELEASE} debug ${Boost_${basename}_LIBRARY_DEBUG}) - ELSE(CMAKE_CONFIGURATION_TYPES OR CMAKE_BUILD_TYPE) - # if there are no configuration types and CMAKE_BUILD_TYPE has no value - # then just use the release libraries - SET(Boost_${basename}_LIBRARY ${Boost_${basename}_LIBRARY_RELEASE} ) - ENDIF(CMAKE_CONFIGURATION_TYPES OR CMAKE_BUILD_TYPE) - SET(Boost_${basename}_LIBRARIES optimized ${Boost_${basename}_LIBRARY_RELEASE} debug ${Boost_${basename}_LIBRARY_DEBUG}) - ENDIF (Boost_${basename}_LIBRARY_DEBUG AND Boost_${basename}_LIBRARY_RELEASE) - - # if only the release version was found, set the debug variable also to the release version - IF (Boost_${basename}_LIBRARY_RELEASE AND NOT Boost_${basename}_LIBRARY_DEBUG) - SET(Boost_${basename}_LIBRARY_DEBUG ${Boost_${basename}_LIBRARY_RELEASE}) - SET(Boost_${basename}_LIBRARY ${Boost_${basename}_LIBRARY_RELEASE}) - SET(Boost_${basename}_LIBRARIES ${Boost_${basename}_LIBRARY_RELEASE}) - ENDIF (Boost_${basename}_LIBRARY_RELEASE AND NOT Boost_${basename}_LIBRARY_DEBUG) - - # if only the debug version was found, set the release variable also to the debug version - IF (Boost_${basename}_LIBRARY_DEBUG AND NOT Boost_${basename}_LIBRARY_RELEASE) - SET(Boost_${basename}_LIBRARY_RELEASE ${Boost_${basename}_LIBRARY_DEBUG}) - SET(Boost_${basename}_LIBRARY ${Boost_${basename}_LIBRARY_DEBUG}) - SET(Boost_${basename}_LIBRARIES ${Boost_${basename}_LIBRARY_DEBUG}) - ENDIF (Boost_${basename}_LIBRARY_DEBUG AND NOT Boost_${basename}_LIBRARY_RELEASE) - - IF (Boost_${basename}_LIBRARY) - SET(Boost_${basename}_LIBRARY ${Boost_${basename}_LIBRARY} CACHE FILEPATH "The Boost ${basename} library") - IF(NOT Boost_LIBRARY_DIRS) - FOREACH(Boost_${basename}_LIBRARY_path ${Boost_${basename}_LIBRARY}) - GET_FILENAME_COMPONENT(Boost_LIBRARY_DIRS "${Boost_${basename}_LIBRARY_path}" PATH) - SET(Boost_LIBRARY_DIRS ${Boost_LIBRARY_DIRS} CACHE FILEPATH "Boost library directory") - ENDFOREACH(Boost_${basename}_LIBRARY_path ${Boost_${basename}_LIBRARY}) - ENDIF(NOT Boost_LIBRARY_DIRS) - SET(Boost_${basename}_FOUND ON CACHE INTERNAL "Whether the Boost ${basename} library found") - ENDIF (Boost_${basename}_LIBRARY) - - ENDIF (Boost_INCLUDE_DIR ) - # Make variables changeble to the advanced user - MARK_AS_ADVANCED( - Boost_${basename}_LIBRARY - Boost_${basename}_LIBRARY_RELEASE - Boost_${basename}_LIBRARY_DEBUG - ) -ENDMACRO (_Boost_ADJUST_LIB_VARS) - -#------------------------------------------------------------------------------- - - -SET( _boost_IN_CACHE TRUE) -IF(Boost_INCLUDE_DIR) - FOREACH(COMPONENT ${Boost_FIND_COMPONENTS}) - STRING(TOUPPER ${COMPONENT} COMPONENT) - IF(NOT Boost_${COMPONENT}_FOUND) - SET( _boost_IN_CACHE FALSE) - ENDIF(NOT Boost_${COMPONENT}_FOUND) - ENDFOREACH(COMPONENT) -ELSE(Boost_INCLUDE_DIR) - SET( _boost_IN_CACHE FALSE) -ENDIF(Boost_INCLUDE_DIR) - -IF (_boost_IN_CACHE) - # in cache already - SET(Boost_FOUND TRUE) - FOREACH(COMPONENT ${Boost_FIND_COMPONENTS}) - STRING(TOUPPER ${COMPONENT} COMPONENT) - _Boost_ADJUST_LIB_VARS( ${COMPONENT} ) - SET(Boost_LIBRARIES ${Boost_LIBRARIES} ${Boost_${COMPONENT}_LIBRARY}) - ENDFOREACH(COMPONENT) - SET(Boost_INCLUDE_DIRS ${Boost_INCLUDE_DIR}) - IF(Boost_VERSION AND NOT "${Boost_VERSION}" STREQUAL "0") - MATH(EXPR Boost_MAJOR_VERSION "${Boost_VERSION} / 100000") - MATH(EXPR Boost_MINOR_VERSION "${Boost_VERSION} / 100 % 1000") - MATH(EXPR Boost_SUBMINOR_VERSION "${Boost_VERSION} % 100") - ENDIF(Boost_VERSION AND NOT "${Boost_VERSION}" STREQUAL "0") -ELSE (_boost_IN_CACHE) - # Need to search for boost - - IF(WIN32) - # In windows, automatic linking is performed, so you do not have - # to specify the libraries. If you are linking to a dynamic - # runtime, then you can choose to link to either a static or a - # dynamic Boost library, the default is to do a static link. You - # can alter this for a specific library "whatever" by defining - # BOOST_WHATEVER_DYN_LINK to force Boost library "whatever" to be - # linked dynamically. Alternatively you can force all Boost - # libraries to dynamic link by defining BOOST_ALL_DYN_LINK. - - # This feature can be disabled for Boost library "whatever" by - # defining BOOST_WHATEVER_NO_LIB, or for all of Boost by defining - # BOOST_ALL_NO_LIB. - - # If you want to observe which libraries are being linked against - # then defining BOOST_LIB_DIAGNOSTIC will cause the auto-linking - # code to emit a #pragma message each time a library is selected - # for linking. - SET(Boost_LIB_DIAGNOSTIC_DEFINITIONS - "-DBOOST_LIB_DIAGNOSTIC" CACHE STRING "Boost diagnostic define") - ENDIF(WIN32) - - SET(_boost_INCLUDE_SEARCH_DIRS - C:/boost/include - "C:/boost" - "$ENV{ProgramFiles}/boost/boost_${Boost_FIND_VERSION_MAJOR}_${Boost_FIND_VERSION_MINOR}_${Boost_FIND_VERSION_PATCH}" - "$ENV{ProgramFiles}/Boost" - /sw/local/include - ) - - SET(_boost_LIBRARIES_SEARCH_DIRS - C:/boost/lib - "C:/boost" - "$ENV{ProgramFiles}/boost/boost_${Boost_FIND_VERSION_MAJOR}_${Boost_FIND_VERSION_MINOR}_${Boost_FIND_VERSION_PATCH}/lib" - "$ENV{ProgramFiles}/Boost" - /sw/local/lib - ) - - IF(Boost_LIBRARY_DIRS) - SET(_boost_LIBRARIES_SEARCH_DIRS ${Boost_LIBRARY_DIRS} ${_boost_LIBRARIES_SEARCH_DIRS}) - ENDIF(Boost_LIBRARY_DIRS) - - # If BOOST_ROOT was defined in the environment, use it. - if (NOT BOOST_ROOT AND NOT $ENV{BOOST_ROOT} STREQUAL "") - set(BOOST_ROOT $ENV{BOOST_ROOT}) - endif(NOT BOOST_ROOT AND NOT $ENV{BOOST_ROOT} STREQUAL "") - - # If BOOSTROOT was defined in the environment, use it. - if (NOT BOOST_ROOT AND NOT $ENV{BOOSTROOT} STREQUAL "") - set(BOOST_ROOT $ENV{BOOSTROOT}) - endif(NOT BOOST_ROOT AND NOT $ENV{BOOSTROOT} STREQUAL "") - - # If BOOST_INCLUDEDIR was defined in the environment, use it. - IF( NOT $ENV{BOOST_INCLUDEDIR} STREQUAL "" ) - set(BOOST_INCLUDEDIR $ENV{BOOST_INCLUDEDIR}) - ENDIF( NOT $ENV{BOOST_INCLUDEDIR} STREQUAL "" ) - - # If BOOST_LIBRARYDIR was defined in the environment, use it. - IF( NOT $ENV{BOOST_LIBRARYDIR} STREQUAL "" ) - set(BOOST_LIBRARYDIR $ENV{BOOST_LIBRARYDIR}) - ENDIF( NOT $ENV{BOOST_LIBRARYDIR} STREQUAL "" ) - - IF( BOOST_ROOT ) - file(TO_CMAKE_PATH ${BOOST_ROOT} BOOST_ROOT) - SET(_boost_INCLUDE_SEARCH_DIRS - ${BOOST_ROOT}/include - ${BOOST_ROOT} - ${_boost_INCLUDE_SEARCH_DIRS}) - SET(_boost_LIBRARIES_SEARCH_DIRS - ${BOOST_ROOT}/lib - ${BOOST_ROOT}/stage/lib - ${_boost_LIBRARIES_SEARCH_DIRS}) - ENDIF( BOOST_ROOT ) - - IF( BOOST_INCLUDEDIR ) - file(TO_CMAKE_PATH ${BOOST_INCLUDEDIR} BOOST_INCLUDEDIR) - SET(_boost_INCLUDE_SEARCH_DIRS - ${BOOST_INCLUDEDIR} ${_boost_INCLUDE_SEARCH_DIRS}) - ENDIF( BOOST_INCLUDEDIR ) - - IF( BOOST_LIBRARYDIR ) - file(TO_CMAKE_PATH ${BOOST_LIBRARYDIR} BOOST_LIBRARYDIR) - SET(_boost_LIBRARIES_SEARCH_DIRS - ${BOOST_LIBRARYDIR} ${_boost_LIBRARIES_SEARCH_DIRS}) - ENDIF( BOOST_LIBRARYDIR ) - - # Try to find Boost by stepping backwards through the Boost versions - # we know about. - FOREACH(_boost_VER ${_boost_TEST_VERSIONS}) - IF( NOT Boost_INCLUDE_DIR ) - # Add in a path suffix, based on the required version, ideally - # we could read this from version.hpp, but for that to work we'd - # need to know the include dir already - if (WIN32 AND NOT CYGWIN) - set(_boost_PATH_SUFFIX boost_${_boost_VER}) - else (WIN32 AND NOT CYGWIN) - set(_boost_PATH_SUFFIX boost-${_boost_VER}) - endif (WIN32 AND NOT CYGWIN) - - IF(_boost_PATH_SUFFIX MATCHES "[0-9]+\\.[0-9]+\\.[0-9]+") - STRING(REGEX REPLACE "([0-9]+)\\.([0-9]+)\\.([0-9]+)" "\\1_\\2_\\3" - _boost_PATH_SUFFIX ${_boost_PATH_SUFFIX}) - ELSEIF(_boost_PATH_SUFFIX MATCHES "[0-9]+\\.[0-9]+") - STRING(REGEX REPLACE "([0-9]+)\\.([0-9]+)" "\\1_\\2" - _boost_PATH_SUFFIX ${_boost_PATH_SUFFIX}) - ENDIF(_boost_PATH_SUFFIX MATCHES "[0-9]+\\.[0-9]+\\.[0-9]+") - - FIND_PATH(Boost_INCLUDE_DIR - NAMES boost/config.hpp - PATHS ${_boost_INCLUDE_SEARCH_DIRS} - PATH_SUFFIXES ${_boost_PATH_SUFFIX} - ) - - ENDIF( NOT Boost_INCLUDE_DIR ) - ENDFOREACH(_boost_VER) - - IF(Boost_INCLUDE_DIR) - # Extract Boost_VERSION and Boost_LIB_VERSION from version.hpp - # Read the whole file: - # - SET(BOOST_VERSION 0) - SET(BOOST_LIB_VERSION "") - FILE(READ "${Boost_INCLUDE_DIR}/boost/version.hpp" _boost_VERSION_HPP_CONTENTS) - - STRING(REGEX REPLACE ".*#define BOOST_VERSION ([0-9]+).*" "\\1" Boost_VERSION "${_boost_VERSION_HPP_CONTENTS}") - STRING(REGEX REPLACE ".*#define BOOST_LIB_VERSION \"([0-9_]+)\".*" "\\1" Boost_LIB_VERSION "${_boost_VERSION_HPP_CONTENTS}") - - SET(Boost_LIB_VERSION ${Boost_LIB_VERSION} CACHE INTERNAL "The library version string for boost libraries") - SET(Boost_VERSION ${Boost_VERSION} CACHE INTERNAL "The version number for boost libraries") - - IF(NOT "${Boost_VERSION}" STREQUAL "0") - MATH(EXPR Boost_MAJOR_VERSION "${Boost_VERSION} / 100000") - MATH(EXPR Boost_MINOR_VERSION "${Boost_VERSION} / 100 % 1000") - MATH(EXPR Boost_SUBMINOR_VERSION "${Boost_VERSION} % 100") - - set(Boost_ERROR_REASON - "${Boost_ERROR_REASON}Boost version: ${Boost_MAJOR_VERSION}.${Boost_MINOR_VERSION}.${Boost_SUBMINOR_VERSION}\nBoost include path: ${Boost_INCLUDE_DIR}") - ENDIF(NOT "${Boost_VERSION}" STREQUAL "0") - ELSE(Boost_INCLUDE_DIR) - set(Boost_ERROR_REASON - "${Boost_ERROR_REASON}Unable to find the Boost header files. Please set BOOST_ROOT to the root directory containing Boost or BOOST_INCLUDEDIR to the directory containing Boost's headers.") - ENDIF(Boost_INCLUDE_DIR) - - # Setting some more suffixes for the library - SET (Boost_LIB_PREFIX "") - IF ( WIN32 AND Boost_USE_STATIC_LIBS ) - SET (Boost_LIB_PREFIX "lib") - ENDIF ( WIN32 AND Boost_USE_STATIC_LIBS ) - SET (_boost_COMPILER "-gcc") - IF (MSVC90) - SET (_boost_COMPILER "-vc90") - ELSEIF (MSVC80) - SET (_boost_COMPILER "-vc80") - ELSEIF (MSVC71) - SET (_boost_COMPILER "-vc71") - ENDIF(MSVC90) - IF (MINGW) - EXEC_PROGRAM(${CMAKE_CXX_COMPILER} - ARGS -dumpversion - OUTPUT_VARIABLE _boost_COMPILER_VERSION - ) - STRING(REGEX REPLACE "([0-9])\\.([0-9])\\.[0-9]" "\\1\\2" - _boost_COMPILER_VERSION ${_boost_COMPILER_VERSION}) - SET (_boost_COMPILER "-mgw${_boost_COMPILER_VERSION}") - ENDIF(MINGW) - IF (UNIX) - IF (APPLE) - # Due to a quirk in Boost.Build, there is no compiler name - # mangled into library names on Mac OS X/Darwin. - SET (_boost_COMPILER "") - ELSE (APPLE) - IF (NOT CMAKE_COMPILER_IS_GNUCXX) - # We assume that we have the Intel compiler. - SET (_boost_COMPILER "-il") - ELSE (NOT CMAKE_COMPILER_IS_GNUCXX) - # Determine which version of GCC we have. - EXEC_PROGRAM(${CMAKE_CXX_COMPILER} - ARGS -dumpversion - OUTPUT_VARIABLE _boost_COMPILER_VERSION - ) - STRING(REGEX REPLACE "([0-9])\\.([0-9])\\.[0-9]" "\\1\\2" - _boost_COMPILER_VERSION ${_boost_COMPILER_VERSION}) - SET (_boost_COMPILER "-gcc${_boost_COMPILER_VERSION}") - ENDIF (NOT CMAKE_COMPILER_IS_GNUCXX) - ENDIF (APPLE) - ENDIF(UNIX) - - SET (_boost_MULTITHREADED "-mt") - - IF( NOT Boost_USE_MULTITHREADED ) - SET (_boost_MULTITHREADED "") - ENDIF( NOT Boost_USE_MULTITHREADED ) - - SET( _boost_STATIC_TAG "") - IF (WIN32) - IF(MSVC) - SET (_boost_ABI_TAG "g") - ENDIF(MSVC) - IF( Boost_USE_STATIC_LIBS ) - SET( _boost_STATIC_TAG "-s") - ENDIF( Boost_USE_STATIC_LIBS ) - ENDIF(WIN32) - SET (_boost_ABI_TAG "${_boost_ABI_TAG}d") - - # ------------------------------------------------------------------------ - # Begin finding boost libraries - # ------------------------------------------------------------------------ - FOREACH(COMPONENT ${Boost_FIND_COMPONENTS}) - STRING(TOUPPER ${COMPONENT} UPPERCOMPONENT) - SET( Boost_${UPPERCOMPONENT}_LIBRARY "Boost_${UPPERCOMPONENT}_LIBRARY-NOTFOUND" ) - SET( Boost_${UPPERCOMPONENT}_LIBRARY_RELEASE "Boost_${UPPERCOMPONENT}_LIBRARY_RELEASE-NOTFOUND" ) - SET( Boost_${UPPERCOMPONENT}_LIBRARY_DEBUG "Boost_${UPPERCOMPONENT}_LIBRARY_DEBUG-NOTFOUND") - - # Support preference of static libs by adjusting CMAKE_FIND_LIBRARY_SUFFIXES - IF( Boost_USE_STATIC_LIBS ) - SET( _boost_ORIG_CMAKE_FIND_LIBRARY_SUFFIXES ${CMAKE_FIND_LIBRARY_SUFFIXES}) - IF(WIN32) - SET(CMAKE_FIND_LIBRARY_SUFFIXES .lib .a ${CMAKE_FIND_LIBRARY_SUFFIXES}) - ELSE(WIN32) - SET(CMAKE_FIND_LIBRARY_SUFFIXES .a ${CMAKE_FIND_LIBRARY_SUFFIXES}) - ENDIF(WIN32) - ENDIF( Boost_USE_STATIC_LIBS ) - - FIND_LIBRARY(Boost_${UPPERCOMPONENT}_LIBRARY_RELEASE - NAMES ${Boost_LIB_PREFIX}boost_${COMPONENT}${_boost_COMPILER}${_boost_MULTITHREADED}-${Boost_LIB_VERSION} - ${Boost_LIB_PREFIX}boost_${COMPONENT}${_boost_COMPILER}${_boost_MULTITHREADED}${_boost_STATIC_TAG}-${Boost_LIB_VERSION} - ${Boost_LIB_PREFIX}boost_${COMPONENT}${_boost_MULTITHREADED} - ${Boost_LIB_PREFIX}boost_${COMPONENT}${_boost_MULTITHREADED}${_boost_STATIC_TAG} - ${Boost_LIB_PREFIX}boost_${COMPONENT} - PATHS ${_boost_LIBRARIES_SEARCH_DIRS} - ) - - FIND_LIBRARY(Boost_${UPPERCOMPONENT}_LIBRARY_DEBUG - NAMES ${Boost_LIB_PREFIX}boost_${COMPONENT}${_boost_COMPILER}${_boost_MULTITHREADED}-${_boost_ABI_TAG}-${Boost_LIB_VERSION} - ${Boost_LIB_PREFIX}boost_${COMPONENT}${_boost_COMPILER}${_boost_MULTITHREADED}${_boost_STATIC_TAG}${_boost_ABI_TAG}-${Boost_LIB_VERSION} - ${Boost_LIB_PREFIX}boost_${COMPONENT}${_boost_MULTITHREADED}-${_boost_ABI_TAG} - ${Boost_LIB_PREFIX}boost_${COMPONENT}${_boost_MULTITHREADED}${_boost_STATIC_TAG}${_boost_ABI_TAG} - ${Boost_LIB_PREFIX}boost_${COMPONENT}-${_boost_ABI_TAG} - PATHS ${_boost_LIBRARIES_SEARCH_DIRS} - ) - - _Boost_ADJUST_LIB_VARS(${UPPERCOMPONENT}) - IF( Boost_USE_STATIC_LIBS ) - SET(CMAKE_FIND_LIBRARY_SUFFIXES ${_boost_ORIG_CMAKE_FIND_LIBRARY_SUFFIXES}) - ENDIF( Boost_USE_STATIC_LIBS ) - ENDFOREACH(COMPONENT) - # ------------------------------------------------------------------------ - # End finding boost libraries - # ------------------------------------------------------------------------ - - SET(Boost_INCLUDE_DIRS - ${Boost_INCLUDE_DIR} - ) - - SET(Boost_FOUND FALSE) - IF(Boost_INCLUDE_DIR) - SET( Boost_FOUND TRUE ) - - # Check the version of Boost against the requested version. - if (Boost_FIND_VERSION AND NOT Boost_FIND_VERSION_MINOR) - message(SEND_ERROR "When requesting a specific version of Boost, you must provide at least the major and minor version numbers, e.g., 1.34") - endif (Boost_FIND_VERSION AND NOT Boost_FIND_VERSION_MINOR) - if(Boost_MAJOR_VERSION LESS "${Boost_FIND_VERSION_MAJOR}" ) - set( Boost_FOUND FALSE ) - set(_Boost_VERSION_AGE "old") - elseif(Boost_MAJOR_VERSION EQUAL "${Boost_FIND_VERSION_MAJOR}" ) - if(Boost_MINOR_VERSION LESS "${Boost_FIND_VERSION_MINOR}" ) - set( Boost_FOUND FALSE ) - set(_Boost_VERSION_AGE "old") - elseif(Boost_MINOR_VERSION EQUAL "${Boost_FIND_VERSION_MINOR}" ) - if( Boost_FIND_VERSION_PATCH AND Boost_SUBMINOR_VERSION LESS "${Boost_FIND_VERSION_PATCH}" ) - set( Boost_FOUND FALSE ) - set(_Boost_VERSION_AGE "old") - endif( Boost_FIND_VERSION_PATCH AND Boost_SUBMINOR_VERSION LESS "${Boost_FIND_VERSION_PATCH}" ) - endif( Boost_MINOR_VERSION LESS "${Boost_FIND_VERSION_MINOR}" ) - endif( Boost_MAJOR_VERSION LESS "${Boost_FIND_VERSION_MAJOR}" ) - - if (Boost_FOUND AND Boost_FIND_VERSION_EXACT) - # If the user requested an exact version of Boost, check - # that. We already know that the Boost version we have is >= the - # requested version. - set(_Boost_VERSION_AGE "new") - - # If the user didn't specify a patchlevel, it's 0. - if (NOT Boost_FIND_VERSION_PATCH) - set(Boost_FIND_VERSION_PATCH 0) - endif (NOT Boost_FIND_VERSION_PATCH) - - # We'll set Boost_FOUND true again if we have an exact version match. - set(Boost_FOUND FALSE) - if(Boost_MAJOR_VERSION EQUAL "${Boost_FIND_VERSION_MAJOR}" ) - if(Boost_MINOR_VERSION EQUAL "${Boost_FIND_VERSION_MINOR}" ) - if(Boost_SUBMINOR_VERSION EQUAL "${Boost_FIND_VERSION_PATCH}" ) - set( Boost_FOUND TRUE ) - endif(Boost_SUBMINOR_VERSION EQUAL "${Boost_FIND_VERSION_PATCH}" ) - endif( Boost_MINOR_VERSION EQUAL "${Boost_FIND_VERSION_MINOR}" ) - endif( Boost_MAJOR_VERSION EQUAL "${Boost_FIND_VERSION_MAJOR}" ) - endif (Boost_FOUND AND Boost_FIND_VERSION_EXACT) - - if(NOT Boost_FOUND) - # State that we found a version of Boost that is too new or too old. - set(Boost_ERROR_REASON - "${Boost_ERROR_REASON}\nDetected version of Boost is too ${_Boost_VERSION_AGE}. Requested version was ${Boost_FIND_VERSION_MAJOR}.${Boost_FIND_VERSION_MINOR}") - if (Boost_FIND_VERSION_PATCH) - set(Boost_ERROR_REASON - "${Boost_ERROR_REASON}.${Boost_FIND_VERSION_PATCH}") - endif (Boost_FIND_VERSION_PATCH) - if (NOT Boost_FIND_VERSION_EXACT) - set(Boost_ERROR_REASON "${Boost_ERROR_REASON} (or newer)") - endif (NOT Boost_FIND_VERSION_EXACT) - set(Boost_ERROR_REASON "${Boost_ERROR_REASON}.") - endif (NOT Boost_FOUND) - - if (Boost_FOUND) - set(_boost_CHECKED_COMPONENT FALSE) - set(_Boost_MISSING_COMPONENTS) - foreach(COMPONENT ${Boost_FIND_COMPONENTS}) - string(TOUPPER ${COMPONENT} COMPONENT) - set(_boost_CHECKED_COMPONENT TRUE) - if(NOT Boost_${COMPONENT}_FOUND) - string(TOLOWER ${COMPONENT} COMPONENT) - list(APPEND _Boost_MISSING_COMPONENTS ${COMPONENT}) - set( Boost_FOUND FALSE) - endif(NOT Boost_${COMPONENT}_FOUND) - endforeach(COMPONENT) - endif (Boost_FOUND) - - if (_Boost_MISSING_COMPONENTS) - # We were unable to find some libraries, so generate a sensible - # error message that lists the libraries we were unable to find. - set(Boost_ERROR_REASON - "${Boost_ERROR_REASON}\nThe following Boost libraries could not be found:\n") - foreach(COMPONENT ${_Boost_MISSING_COMPONENTS}) - set(Boost_ERROR_REASON - "${Boost_ERROR_REASON} boost_${COMPONENT}\n") - endforeach(COMPONENT) - - list(LENGTH Boost_FIND_COMPONENTS Boost_NUM_COMPONENTS_WANTED) - list(LENGTH _Boost_MISSING_COMPONENTS Boost_NUM_MISSING_COMPONENTS) - if (${Boost_NUM_COMPONENTS_WANTED} EQUAL ${Boost_NUM_MISSING_COMPONENTS}) - set(Boost_ERROR_REASON - "${Boost_ERROR_REASON}No Boost libraries were found. You may need to set Boost_LIBRARYDIR to the directory containing Boost libraries or BOOST_ROOT to the location of Boost.") - else (${Boost_NUM_COMPONENTS_WANTED} EQUAL ${Boost_NUM_MISSING_COMPONENTS}) - set(Boost_ERROR_REASON - "${Boost_ERROR_REASON}Some (but not all) of the required Boost libraries were found. You may need to install these additional Boost libraries. Alternatively, set Boost_LIBRARYDIR to the directory containing Boost libraries or BOOST_ROOT to the location of Boost.") - endif (${Boost_NUM_COMPONENTS_WANTED} EQUAL ${Boost_NUM_MISSING_COMPONENTS}) - endif (_Boost_MISSING_COMPONENTS) - - IF( NOT Boost_LIBRARY_DIRS AND NOT _boost_CHECKED_COMPONENT ) - # Compatibility Code for backwards compatibility with CMake - # 2.4's FindBoost module. - - # Look for the boost library path. - # Note that the user may not have installed any libraries - # so it is quite possible the Boost_LIBRARY_PATH may not exist. - SET(_boost_LIB_DIR ${Boost_INCLUDE_DIR}) - - IF("${_boost_LIB_DIR}" MATCHES "boost-[0-9]+") - GET_FILENAME_COMPONENT(_boost_LIB_DIR ${_boost_LIB_DIR} PATH) - ENDIF ("${_boost_LIB_DIR}" MATCHES "boost-[0-9]+") - - IF("${_boost_LIB_DIR}" MATCHES "/include$") - # Strip off the trailing "/include" in the path. - GET_FILENAME_COMPONENT(_boost_LIB_DIR ${_boost_LIB_DIR} PATH) - ENDIF("${_boost_LIB_DIR}" MATCHES "/include$") - - IF(EXISTS "${_boost_LIB_DIR}/lib") - SET (_boost_LIB_DIR ${_boost_LIB_DIR}/lib) - ELSE(EXISTS "${_boost_LIB_DIR}/lib") - IF(EXISTS "${_boost_LIB_DIR}/stage/lib") - SET(_boost_LIB_DIR ${_boost_LIB_DIR}/stage/lib) - ELSE(EXISTS "${_boost_LIB_DIR}/stage/lib") - SET(_boost_LIB_DIR "") - ENDIF(EXISTS "${_boost_LIB_DIR}/stage/lib") - ENDIF(EXISTS "${_boost_LIB_DIR}/lib") - - IF(_boost_LIB_DIR AND EXISTS "${_boost_LIB_DIR}") - SET(Boost_LIBRARY_DIRS ${_boost_LIB_DIR} CACHE FILEPATH "Boost library directory") - ENDIF(_boost_LIB_DIR AND EXISTS "${_boost_LIB_DIR}") - - ENDIF( NOT Boost_LIBRARY_DIRS AND NOT _boost_CHECKED_COMPONENT ) - - ELSE(Boost_INCLUDE_DIR) - SET( Boost_FOUND FALSE) - ENDIF(Boost_INCLUDE_DIR) - - IF (Boost_FOUND) - IF (NOT Boost_FIND_QUIETLY) - MESSAGE(STATUS "Boost version: ${Boost_MAJOR_VERSION}.${Boost_MINOR_VERSION}.${Boost_SUBMINOR_VERSION}") - ENDIF(NOT Boost_FIND_QUIETLY) - IF (NOT Boost_FIND_QUIETLY) - MESSAGE(STATUS "Found the following Boost libraries:") - ENDIF(NOT Boost_FIND_QUIETLY) - FOREACH ( COMPONENT ${Boost_FIND_COMPONENTS} ) - STRING( TOUPPER ${COMPONENT} UPPERCOMPONENT ) - IF ( Boost_${UPPERCOMPONENT}_FOUND ) - IF (NOT Boost_FIND_QUIETLY) - MESSAGE (STATUS " ${COMPONENT}") - ENDIF(NOT Boost_FIND_QUIETLY) - SET(Boost_LIBRARIES ${Boost_LIBRARIES} ${Boost_${UPPERCOMPONENT}_LIBRARY}) - ENDIF ( Boost_${UPPERCOMPONENT}_FOUND ) - ENDFOREACH(COMPONENT) - ELSE (Boost_FOUND) - IF (Boost_FIND_REQUIRED) - message(SEND_ERROR "Unable to find the requested Boost libraries.\n${Boost_ERROR_REASON}") - ENDIF(Boost_FIND_REQUIRED) - ENDIF(Boost_FOUND) - - # Under Windows, automatic linking is performed, so no need to specify the libraries. - IF (WIN32) - IF (NOT MINGW) - SET(Boost_LIBRARIES "") - ENDIF (NOT MINGW) - ENDIF(WIN32) - - # show the Boost_INCLUDE_DIRS AND Boost_LIBRARIES variables only in the advanced view - MARK_AS_ADVANCED(Boost_INCLUDE_DIR - Boost_INCLUDE_DIRS - Boost_LIBRARY_DIRS - Boost_USE_MULTITHREADED - ) -ENDIF(_boost_IN_CACHE) - +# - Try to find Boost include dirs and libraries +# Usage of this module as follows: +# +# == Using Header-Only libraries from within Boost: == +# +# find_package( Boost 1.38.0 ) +# if(Boost_FOUND) +# include_directories(${Boost_INCLUDE_DIRS}) +# add_executable(foo foo.cc) +# endif() +# +# +# == Using actual libraries from within Boost: == +# +# set(Boost_USE_STATIC_LIBS ON) +# set(Boost_USE_MULTITHREADED ON) +# find_package( Boost 1.38.0 COMPONENTS date_time filesystem system ... ) +# +# if(Boost_FOUND) +# include_directories(${Boost_INCLUDE_DIRS}) +# add_executable(foo foo.cc) +# target_link_libraries(foo ${Boost_LIBRARIES}) +# endif() +# +# +# The components list needs to contain actual names of boost libraries only, +# such as "date_time" for "libboost_date_time". If you're using parts of +# Boost that contain header files only (e.g. foreach) you do not need to +# specify COMPONENTS. +# +# You should provide a minimum version number that should be used. If you provide this +# version number and specify the REQUIRED attribute, this module will fail if it +# can't find the specified or a later version. If you specify a version number this is +# automatically put into the considered list of version numbers and thus doesn't need +# to be specified in the Boost_ADDITIONAL_VERSIONS variable (see below). +# +# NOTE for Visual Studio Users: +# Automatic linking is used on MSVC & Borland compilers by default when +# #including things in Boost. It's important to note that setting +# Boost_USE_STATIC_LIBS to OFF is NOT enough to get you dynamic linking, +# should you need this feature. Automatic linking typically uses static +# libraries with a few exceptions (Boost.Python is one). +# +# Please see the section below near Boost_LIB_DIAGNOSTIC_DEFINITIONS for +# more details. Adding a TARGET_LINK_LIBRARIES() as shown in the example +# above appears to cause VS to link dynamically if Boost_USE_STATIC_LIBS +# gets set to OFF. It is suggested you avoid automatic linking since it +# will make your application less portable. +# +# =========== The mess that is Boost_ADDITIONAL_VERSIONS (sorry?) ============ +# +# OK, so the Boost_ADDITIONAL_VERSIONS variable can be used to specify a list of +# boost version numbers that should be taken into account when searching +# for Boost. Unfortunately boost puts the version number into the +# actual filename for the libraries, so this variable will certainly be needed +# in the future when new Boost versions are released. +# +# Currently this module searches for the following version numbers: +# 1.33, 1.33.0, 1.33.1, 1.34, 1.34.0, 1.34.1, 1.35, 1.35.0, 1.35.1, +# 1.36, 1.36.0, 1.36.1, 1.37, 1.37.0, 1.38, 1.38.0, 1.38.1 +# 1.39, 1.39.0, 1.39.1 1.40, 1.40.0, 1.40.1 1.41, 1.41.0, 1.41.1 +# 1.42, 1.42.0, 1.42.1 +# +# NOTE: If you add a new major 1.x version in Boost_ADDITIONAL_VERSIONS you should +# add both 1.x and 1.x.0 as shown above. Official Boost include directories +# omit the 3rd version number from include paths if it is 0 although not all +# binary Boost releases do so. +# +# SET(Boost_ADDITIONAL_VERSIONS "0.99" "0.99.0" "1.78" "1.78.0") +# +# ============================================================================ +# +# Variables used by this module, they can change the default behaviour and +# need to be set before calling find_package: +# +# Boost_USE_MULTITHREADED Can be set to OFF to use the non-multithreaded +# boost libraries. If not specified, defaults +# to ON. +# +# Boost_USE_STATIC_LIBS Can be set to ON to force the use of the static +# boost libraries. Defaults to OFF. +# +# Other Variables used by this module which you may want to set. +# +# Boost_ADDITIONAL_VERSIONS A list of version numbers to use for searching +# the boost include directory. Please see +# the documentation above regarding this +# annoying, but necessary variable :( +# +# Boost_DEBUG Set this to TRUE to enable debugging output +# of FindBoost.cmake if you are having problems. +# Please enable this before filing any bug +# reports. +# +# Boost_COMPILER Set this to the compiler suffix used by Boost +# (e.g. "-gcc43") if FindBoost has problems finding +# the proper Boost installation +# +# These last three variables are available also as environment variables: +# +# BOOST_ROOT or BOOSTROOT The preferred installation prefix for searching for +# Boost. Set this if the module has problems finding +# the proper Boost installation. +# +# BOOST_INCLUDEDIR Set this to the include directory of Boost, if the +# module has problems finding the proper Boost installation +# +# BOOST_LIBRARYDIR Set this to the lib directory of Boost, if the +# module has problems finding the proper Boost installation +# +# Variables defined by this module: +# +# Boost_FOUND System has Boost, this means the include dir was +# found, as well as all the libraries specified in +# the COMPONENTS list. +# +# Boost_INCLUDE_DIRS Boost include directories: not cached +# +# Boost_INCLUDE_DIR This is almost the same as above, but this one is +# cached and may be modified by advanced users +# +# Boost_LIBRARIES Link to these to use the Boost libraries that you +# specified: not cached +# +# Boost_LIBRARY_DIRS The path to where the Boost library files are. +# +# Boost_VERSION The version number of the boost libraries that +# have been found, same as in version.hpp from Boost +# +# Boost_LIB_VERSION The version number in filename form as +# it's appended to the library filenames +# +# Boost_MAJOR_VERSION major version number of boost +# Boost_MINOR_VERSION minor version number of boost +# Boost_SUBMINOR_VERSION subminor version number of boost +# +# Boost_LIB_DIAGNOSTIC_DEFINITIONS [WIN32 Only] You can call +# add_definitions(${Boost_LIB_DIAGNOSTIC_DEFINTIIONS}) +# to have diagnostic information about Boost's +# automatic linking outputted during compilation time. +# +# For each component you specify in find_package(), the following (UPPER-CASE) +# variables are set. You can use these variables if you would like to pick and +# choose components for your targets instead of just using Boost_LIBRARIES. +# +# Boost_${COMPONENT}_FOUND True IF the Boost library "component" was found. +# +# Boost_${COMPONENT}_LIBRARY Contains the libraries for the specified Boost +# "component" (includes debug and optimized keywords +# when needed). +# +# ===================================================================== +# +# +# Copyright (c) 2006-2008 Andreas Schneider <> +# Copyright (c) 2007 Wengo +# Copyright (c) 2007 Mike Jackson +# Copyright (c) 2008 Andreas Pakulat <> +# +# Redistribution AND use is allowed according to the terms of the New +# BSD license. +# For details see the accompanying COPYING-CMAKE-SCRIPTS file. +# + +# +# Adapted for CGAL (wwww.cgal.org) by , 2009 +# + +include( CGAL_VersionUtils ) + + +#------------------------------------------------------------------------------- +# FindBoost functions & macros +# +############################################ +# +# Check the existence of the libraries. +# +############################################ +# This macro was taken directly from the FindQt4.cmake file that is included +# with the CMake distribution. This is NOT my work. All work was done by the +# original authors of the FindQt4.cmake file. Only minor modifications were +# made to remove references to Qt and make this file more generally applicable +# And ELSE/ENDIF pairs were removed for readability. +######################################################################### + +MACRO (_Boost_ADJUST_LIB_VARS basename) + IF (Boost_INCLUDE_DIR ) + IF (Boost_${basename}_LIBRARY_DEBUG AND Boost_${basename}_LIBRARY_RELEASE) + # if the generator supports configuration types then set + # optimized and debug libraries, or if the CMAKE_BUILD_TYPE has a value + IF (CMAKE_CONFIGURATION_TYPES OR CMAKE_BUILD_TYPE) + SET(Boost_${basename}_LIBRARY optimized ${Boost_${basename}_LIBRARY_RELEASE} debug ${Boost_${basename}_LIBRARY_DEBUG}) + ELSE() + # if there are no configuration types and CMAKE_BUILD_TYPE has no value + # then just use the release libraries + SET(Boost_${basename}_LIBRARY ${Boost_${basename}_LIBRARY_RELEASE} ) + ENDIF() + # FIXME: This probably should be set for both cases + SET(Boost_${basename}_LIBRARIES optimized ${Boost_${basename}_LIBRARY_RELEASE} debug ${Boost_${basename}_LIBRARY_DEBUG}) + ENDIF() + + # if only the release version was found, set the debug variable also to the release version + IF (Boost_${basename}_LIBRARY_RELEASE AND NOT Boost_${basename}_LIBRARY_DEBUG) + SET(Boost_${basename}_LIBRARY_DEBUG ${Boost_${basename}_LIBRARY_RELEASE}) + SET(Boost_${basename}_LIBRARY ${Boost_${basename}_LIBRARY_RELEASE}) + SET(Boost_${basename}_LIBRARIES ${Boost_${basename}_LIBRARY_RELEASE}) + ENDIF() + + # if only the debug version was found, set the release variable also to the debug version + IF (Boost_${basename}_LIBRARY_DEBUG AND NOT Boost_${basename}_LIBRARY_RELEASE) + SET(Boost_${basename}_LIBRARY_RELEASE ${Boost_${basename}_LIBRARY_DEBUG}) + SET(Boost_${basename}_LIBRARY ${Boost_${basename}_LIBRARY_DEBUG}) + SET(Boost_${basename}_LIBRARIES ${Boost_${basename}_LIBRARY_DEBUG}) + ENDIF() + + IF (Boost_${basename}_LIBRARY) + set(Boost_${basename}_LIBRARY ${Boost_${basename}_LIBRARY} CACHE FILEPATH "The Boost ${basename} library") + + # Remove superfluous "debug" / "optimized" keywords from + # Boost_LIBRARY_DIRS + FOREACH(_boost_my_lib ${Boost_${basename}_LIBRARY}) + GET_FILENAME_COMPONENT(_boost_my_lib_path "${_boost_my_lib}" PATH) + if ( NOT "${_boost_my_lib_path}" STREQUAL "" ) + LIST(APPEND Boost_LIBRARY_DIRS ${_boost_my_lib_path}) + endif() + ENDFOREACH() + + set(Boost_LIBRARY_DIRS ${Boost_LIBRARY_DIRS} CACHE FILEPATH "Boost library directory") + SET(Boost_${basename}_FOUND ON CACHE INTERNAL "Whether the Boost ${basename} library found") + ENDIF(Boost_${basename}_LIBRARY) + + ENDIF (Boost_INCLUDE_DIR ) + # Make variables changeble to the advanced user + MARK_AS_ADVANCED( + Boost_${basename}_LIBRARY + Boost_${basename}_LIBRARY_RELEASE + Boost_${basename}_LIBRARY_DEBUG + ) +ENDMACRO (_Boost_ADJUST_LIB_VARS) + +#------------------------------------------------------------------------------- + +# +# Runs compiler with "-dumpversion" and parses major/minor +# version with a regex. +# +MACRO(_Boost_COMPILER_DUMPVERSION _OUTPUT_VERSION) + + EXEC_PROGRAM(${CMAKE_CXX_COMPILER} + ARGS ${CMAKE_CXX_COMPILER_ARG1} -dumpversion + OUTPUT_VARIABLE _boost_COMPILER_VERSION + ) + STRING(REGEX REPLACE "([0-9])\\.([0-9])(\\.[0-9])?" "\\1\\2" + _boost_COMPILER_VERSION ${_boost_COMPILER_VERSION}) + + SET(${_OUTPUT_VERSION} ${_boost_COMPILER_VERSION} PARENT_SCOPE) +ENDMACRO() + +# +# End functions/macros +# +#------------------------------------------------------------------------------- + + + + +IF(NOT DEFINED Boost_USE_MULTITHREADED) + SET(Boost_USE_MULTITHREADED TRUE) +ENDIF() + +if(Boost_FIND_VERSION_EXACT) + # The version may appear in a directory with or without the patch + # level, even when the patch level is non-zero. + set(_boost_TEST_VERSIONS + "${Boost_FIND_VERSION_MAJOR}.${Boost_FIND_VERSION_MINOR}.${Boost_FIND_VERSION_PATCH}" + "${Boost_FIND_VERSION_MAJOR}.${Boost_FIND_VERSION_MINOR}") +else(Boost_FIND_VERSION_EXACT) + # The user has not requested an exact version. Among known + # versions, find those that are acceptable to the user request. + set(_Boost_KNOWN_VERSIONS ${Boost_ADDITIONAL_VERSIONS} + "1.42.1" "1.42.0" "1.42" + "1.41.1" "1.41.0" "1.41" + "1.40.1" "1.40.0" "1.40" + "1.39.1" "1.39.0" "1.39" + "1.38.1" "1.38.0" "1.38" + "1.37.0" "1.37" + "1.36.1" "1.36.0" "1.36" "1.35.1" "1.35.0" "1.35" "1.34.1" "1.34.0" + "1.34" "1.33.1" "1.33.0" "1.33") + set(_boost_TEST_VERSIONS) + if(Boost_FIND_VERSION) + set(_Boost_FIND_VERSION_SHORT "${Boost_FIND_VERSION_MAJOR}.${Boost_FIND_VERSION_MINOR}") + # Select acceptable versions. + foreach(version ${_Boost_KNOWN_VERSIONS}) + IS_VERSION_LESS( "${version}" "${Boost_FIND_VERSION}" _Boost_IS_VERSION_LESS ) + if(NOT _Boost_IS_VERSION_LESS ) + # This version is high enough. + list(APPEND _boost_TEST_VERSIONS "${version}") + else() + IS_VERSION_EQUAL( "${version}" "${_Boost_FIND_VERSION_SHORT}" _Boost_IS_VERSION_EQUAL ) + if( _Boost_IS_VERSION_EQUAL ) + # This version is a short-form for the requested version with + # the patch level dropped. + list(APPEND _boost_TEST_VERSIONS "${version}") + endif() + endif() + endforeach(version) + else(Boost_FIND_VERSION) + # Any version is acceptable. + set(_boost_TEST_VERSIONS "${_Boost_KNOWN_VERSIONS}") + endif(Boost_FIND_VERSION) +endif(Boost_FIND_VERSION_EXACT) + +# The reason that we failed to find Boost. This will be set to a +# user-friendly message when we fail to find some necessary piece of +# Boost. +set(Boost_ERROR_REASON) + + +SET( _boost_IN_CACHE TRUE) +IF(Boost_INCLUDE_DIR) + FOREACH(COMPONENT ${Boost_FIND_COMPONENTS}) + STRING(TOUPPER ${COMPONENT} COMPONENT) + IF(NOT Boost_${COMPONENT}_FOUND) + SET( _boost_IN_CACHE FALSE) + ENDIF(NOT Boost_${COMPONENT}_FOUND) + ENDFOREACH(COMPONENT) +ELSE(Boost_INCLUDE_DIR) + SET( _boost_IN_CACHE FALSE) +ENDIF(Boost_INCLUDE_DIR) + +IF (_boost_IN_CACHE) + # in cache already + SET(Boost_FOUND TRUE) + FOREACH(COMPONENT ${Boost_FIND_COMPONENTS}) + STRING(TOUPPER ${COMPONENT} COMPONENT) + _Boost_ADJUST_LIB_VARS( ${COMPONENT} ) + SET(Boost_LIBRARIES ${Boost_LIBRARIES} ${Boost_${COMPONENT}_LIBRARY}) + ENDFOREACH(COMPONENT) + SET(Boost_INCLUDE_DIRS ${Boost_INCLUDE_DIR}) + IF(Boost_VERSION AND NOT "${Boost_VERSION}" STREQUAL "0") + MATH(EXPR Boost_MAJOR_VERSION "${Boost_VERSION} / 100000") + MATH(EXPR Boost_MINOR_VERSION "${Boost_VERSION} / 100 % 1000") + MATH(EXPR Boost_SUBMINOR_VERSION "${Boost_VERSION} % 100") + ENDIF(Boost_VERSION AND NOT "${Boost_VERSION}" STREQUAL "0") + if(Boost_DEBUG) + message(STATUS "[ ${CMAKE_CURRENT_LIST_FILE}:${CMAKE_CURRENT_LIST_LINE} ] " + "boost ${Boost_MAJOR_VERSION}.${Boost_MINOR_VERSION}.${Boost_SUBMINOR_VERSION} " + "is already in the cache. For debugging messages, please clear the cache.") + endif() +ELSE (_boost_IN_CACHE) + # Need to search for boost + if(Boost_DEBUG) + message(STATUS "[ ${CMAKE_CURRENT_LIST_FILE}:${CMAKE_CURRENT_LIST_LINE} ] " + "Boost not in cache") + # Output some of their choices + message(STATUS "[ ${CMAKE_CURRENT_LIST_FILE}:${CMAKE_CURRENT_LIST_LINE} ] " + "_boost_TEST_VERSIONS = ${_boost_TEST_VERSIONS}") + message(STATUS "[ ${CMAKE_CURRENT_LIST_FILE}:${CMAKE_CURRENT_LIST_LINE} ] " + "Boost_USE_MULTITHREADED = ${Boost_USE_MULTITHREADED}") + message(STATUS "[ ${CMAKE_CURRENT_LIST_FILE}:${CMAKE_CURRENT_LIST_LINE} ] " + "Boost_USE_STATIC_LIBS = ${Boost_USE_STATIC_LIBS}") + endif() + + IF(WIN32) + # In windows, automatic linking is performed, so you do not have + # to specify the libraries. If you are linking to a dynamic + # runtime, then you can choose to link to either a static or a + # dynamic Boost library, the default is to do a static link. You + # can alter this for a specific library "whatever" by defining + # BOOST_WHATEVER_DYN_LINK to force Boost library "whatever" to be + # linked dynamically. Alternatively you can force all Boost + # libraries to dynamic link by defining BOOST_ALL_DYN_LINK. + + # This feature can be disabled for Boost library "whatever" by + # defining BOOST_WHATEVER_NO_LIB, or for all of Boost by defining + # BOOST_ALL_NO_LIB. + + # If you want to observe which libraries are being linked against + # then defining BOOST_LIB_DIAGNOSTIC will cause the auto-linking + # code to emit a #pragma message each time a library is selected + # for linking. + SET(Boost_LIB_DIAGNOSTIC_DEFINITIONS + "-DBOOST_LIB_DIAGNOSTIC" CACHE STRING "Boost diagnostic define") + ENDIF(WIN32) + + set( boost_ENV_PROGRAM_FILES_DIR $ENV{ProgramFiles} ) + file(TO_CMAKE_PATH "${boost_ENV_PROGRAM_FILES_DIR}" boost_ENV_PROGRAM_FILES_DIR) + + SET(_boost_INCLUDE_SEARCH_DIRS + C:/boost/include + C:/boost + "${boost_ENV_PROGRAM_FILES_DIR}/boost" + /sw/local/include + ) + + # If BOOST_ROOT was defined in the environment, use it. + if (NOT BOOST_ROOT AND NOT $ENV{BOOST_ROOT} STREQUAL "") + set(BOOST_ROOT $ENV{BOOST_ROOT}) + endif(NOT BOOST_ROOT AND NOT $ENV{BOOST_ROOT} STREQUAL "") + + # If BOOSTROOT was defined in the environment, use it. + if (NOT BOOST_ROOT AND NOT $ENV{BOOSTROOT} STREQUAL "") + set(BOOST_ROOT $ENV{BOOSTROOT}) + endif(NOT BOOST_ROOT AND NOT $ENV{BOOSTROOT} STREQUAL "") + + # If BOOST_INCLUDEDIR was defined in the environment, use it. + IF( NOT $ENV{BOOST_INCLUDEDIR} STREQUAL "" ) + set(BOOST_INCLUDEDIR $ENV{BOOST_INCLUDEDIR}) + ENDIF( NOT $ENV{BOOST_INCLUDEDIR} STREQUAL "" ) + + # If BOOST_LIBRARYDIR was defined in the environment, use it. + IF( NOT $ENV{BOOST_LIBRARYDIR} STREQUAL "" ) + set(BOOST_LIBRARYDIR $ENV{BOOST_LIBRARYDIR}) + ENDIF( NOT $ENV{BOOST_LIBRARYDIR} STREQUAL "" ) + + IF( BOOST_ROOT ) + file(TO_CMAKE_PATH ${BOOST_ROOT} BOOST_ROOT) + ENDIF( BOOST_ROOT ) + + if(Boost_DEBUG) + message(STATUS "[ ${CMAKE_CURRENT_LIST_FILE}:${CMAKE_CURRENT_LIST_LINE} ] " + "Declared as CMake or Environmental Variables:") + message(STATUS "[ ${CMAKE_CURRENT_LIST_FILE}:${CMAKE_CURRENT_LIST_LINE} ] " + " BOOST_ROOT = ${BOOST_ROOT}") + message(STATUS "[ ${CMAKE_CURRENT_LIST_FILE}:${CMAKE_CURRENT_LIST_LINE} ] " + " BOOST_INCLUDEDIR = ${BOOST_INCLUDEDIR}") + message(STATUS "[ ${CMAKE_CURRENT_LIST_FILE}:${CMAKE_CURRENT_LIST_LINE} ] " + " BOOST_LIBRARYDIR = ${BOOST_LIBRARYDIR}") + message(STATUS "[ ${CMAKE_CURRENT_LIST_FILE}:${CMAKE_CURRENT_LIST_LINE} ] " + "_boost_TEST_VERSIONS = ${_boost_TEST_VERSIONS}") + endif() + + IF( BOOST_ROOT ) + SET(_boost_INCLUDE_SEARCH_DIRS + ${BOOST_ROOT}/include + ${BOOST_ROOT} + ${_boost_INCLUDE_SEARCH_DIRS}) + ENDIF( BOOST_ROOT ) + + IF( BOOST_INCLUDEDIR ) + file(TO_CMAKE_PATH ${BOOST_INCLUDEDIR} BOOST_INCLUDEDIR) + SET(_boost_INCLUDE_SEARCH_DIRS + ${BOOST_INCLUDEDIR} ${_boost_INCLUDE_SEARCH_DIRS}) + ENDIF( BOOST_INCLUDEDIR ) + + # ------------------------------------------------------------------------ + # Search for Boost include DIR + # ------------------------------------------------------------------------ + # Try to find Boost by stepping backwards through the Boost versions + # we know about. + IF( NOT Boost_INCLUDE_DIR ) + # Build a list of path suffixes for each version. + SET(_boost_PATH_SUFFIXES) + FOREACH(_boost_VER ${_boost_TEST_VERSIONS}) + # Add in a path suffix, based on the required version, ideally + # we could read this from version.hpp, but for that to work we'd + # need to know the include dir already + set(_boost_BOOSTIFIED_VERSION) + + # Transform 1.35 => 1_35 and 1.36.0 => 1_36_0 + IF(_boost_VER MATCHES "[0-9]+\\.[0-9]+\\.[0-9]+") + STRING(REGEX REPLACE "([0-9]+)\\.([0-9]+)\\.([0-9]+)" "\\1_\\2_\\3" + _boost_BOOSTIFIED_VERSION ${_boost_VER}) + ELSEIF(_boost_VER MATCHES "[0-9]+\\.[0-9]+") + STRING(REGEX REPLACE "([0-9]+)\\.([0-9]+)" "\\1_\\2" + _boost_BOOSTIFIED_VERSION ${_boost_VER}) + ENDIF() + + list(APPEND _boost_PATH_SUFFIXES "boost-${_boost_BOOSTIFIED_VERSION}") + if(WIN32) + # For BoostPro's underscores (and others?) + list(APPEND _boost_PATH_SUFFIXES "boost_${_boost_BOOSTIFIED_VERSION}") + endif() + + ENDFOREACH(_boost_VER) + + if(Boost_DEBUG) + message(STATUS "[ ${CMAKE_CURRENT_LIST_FILE}:${CMAKE_CURRENT_LIST_LINE} ] " + "Include debugging info:") + message(STATUS "[ ${CMAKE_CURRENT_LIST_FILE}:${CMAKE_CURRENT_LIST_LINE} ] " + " _boost_INCLUDE_SEARCH_DIRS = ${_boost_INCLUDE_SEARCH_DIRS}") + message(STATUS "[ ${CMAKE_CURRENT_LIST_FILE}:${CMAKE_CURRENT_LIST_LINE} ] " + " _boost_PATH_SUFFIXES = ${_boost_PATH_SUFFIXES}") + endif() + + # Look for a standard boost header file. + FIND_PATH(Boost_INCLUDE_DIR + NAMES boost/config.hpp + PATHS ${_boost_INCLUDE_SEARCH_DIRS} + PATH_SUFFIXES ${_boost_PATH_SUFFIXES} + ) + ENDIF( NOT Boost_INCLUDE_DIR ) + + # ------------------------------------------------------------------------ + # Extract version information from version.hpp + # ------------------------------------------------------------------------ + + IF(Boost_INCLUDE_DIR) + # Extract Boost_VERSION and Boost_LIB_VERSION from version.hpp + # Read the whole file: + # + SET(BOOST_VERSION 0) + SET(BOOST_LIB_VERSION "") + FILE(READ "${Boost_INCLUDE_DIR}/boost/version.hpp" _boost_VERSION_HPP_CONTENTS) + if(Boost_DEBUG) + message(STATUS "[ ${CMAKE_CURRENT_LIST_FILE}:${CMAKE_CURRENT_LIST_LINE} ] " + "location of version.hpp: ${Boost_INCLUDE_DIR}/boost/version.hpp") + endif() + + STRING(REGEX REPLACE ".*#define BOOST_VERSION ([0-9]+).*" "\\1" Boost_VERSION "${_boost_VERSION_HPP_CONTENTS}") + STRING(REGEX REPLACE ".*#define BOOST_LIB_VERSION \"([0-9_]+)\".*" "\\1" Boost_LIB_VERSION "${_boost_VERSION_HPP_CONTENTS}") + + SET(Boost_LIB_VERSION ${Boost_LIB_VERSION} CACHE INTERNAL "The library version string for boost libraries") + SET(Boost_VERSION ${Boost_VERSION} CACHE INTERNAL "The version number for boost libraries") + + IF(NOT "${Boost_VERSION}" STREQUAL "0") + MATH(EXPR Boost_MAJOR_VERSION "${Boost_VERSION} / 100000") + MATH(EXPR Boost_MINOR_VERSION "${Boost_VERSION} / 100 % 1000") + MATH(EXPR Boost_SUBMINOR_VERSION "${Boost_VERSION} % 100") + + set(Boost_ERROR_REASON + "${Boost_ERROR_REASON}Boost version: ${Boost_MAJOR_VERSION}.${Boost_MINOR_VERSION}.${Boost_SUBMINOR_VERSION}\nBoost include path: ${Boost_INCLUDE_DIR}") + ENDIF(NOT "${Boost_VERSION}" STREQUAL "0") + if(Boost_DEBUG) + message(STATUS "[ ${CMAKE_CURRENT_LIST_FILE}:${CMAKE_CURRENT_LIST_LINE} ] " + "version.hpp reveals boost " + "${Boost_MAJOR_VERSION}.${Boost_MINOR_VERSION}.${Boost_SUBMINOR_VERSION}") + endif() + ELSE(Boost_INCLUDE_DIR) + set(Boost_ERROR_REASON + "${Boost_ERROR_REASON}Unable to find the Boost header files. Please set BOOST_ROOT to the root directory containing Boost or BOOST_INCLUDEDIR to the directory containing Boost's headers.") + ENDIF(Boost_INCLUDE_DIR) + + # ------------------------------------------------------------------------ + # Suffix initialization and compiler suffix detection. + # ------------------------------------------------------------------------ + + # Setting some more suffixes for the library + SET (Boost_LIB_PREFIX "") + if ( WIN32 AND Boost_USE_STATIC_LIBS ) + SET (Boost_LIB_PREFIX "lib") + endif() + + if (Boost_COMPILER) + set(_boost_COMPILER ${Boost_COMPILER}) + if(Boost_DEBUG) + message(STATUS "[ ${CMAKE_CURRENT_LIST_FILE}:${CMAKE_CURRENT_LIST_LINE} ] " + "using user-specified Boost_COMPILER = ${_boost_COMPILER}") + endif() + else(Boost_COMPILER) + + SET(_boost_COMPILER "-gcc") # Fall back to GCC for cygwin + + # Attempt to guess the compiler suffix + # NOTE: this is not perfect yet, if you experience any issues + # please report them and use the Boost_COMPILER variable + # to work around the problems. + if (MSVC90) + SET (_boost_COMPILER "-vc90") + elseif (MSVC80) + SET (_boost_COMPILER "-vc80") + elseif (MSVC71) + SET (_boost_COMPILER "-vc71") + elseif (MSVC70) # Good luck! + SET (_boost_COMPILER "-vc7") # yes, this is correct + elseif (MSVC60) # Good luck! + SET (_boost_COMPILER "-vc6") # yes, this is correct + elseif (BORLAND) + SET (_boost_COMPILER "-bcb") + elseif("${CMAKE_CXX_COMPILER}" MATCHES "icl" + OR "${CMAKE_CXX_COMPILER}" MATCHES "icpc") + if(WIN32) + set (_boost_COMPILER "-iw") + else() + set (_boost_COMPILER "-il") + endif() + elseif (MINGW) + + IS_VERSION_LESS( "${Boost_MAJOR_VERSION}.${Boost_MINOR_VERSION}" "1.34" _Boost_IS_VERSION_LESS ) + if( _Boost_IS_VERSION_LESS ) + SET(_boost_COMPILER "-mgw") # no GCC version encoding prior to 1.34 + else() + _Boost_COMPILER_DUMPVERSION(_boost_COMPILER_VERSION) + SET (_boost_COMPILER "-mgw${_boost_COMPILER_VERSION}") + endif() + elseif (UNIX) + if (CMAKE_COMPILER_IS_GNUCXX) + IS_VERSION_LESS( "${Boost_MAJOR_VERSION}.${Boost_MINOR_VERSION}" "1.34" _Boost_IS_VERSION_LESS ) + if( _Boost_IS_VERSION_LESS ) + SET(_boost_COMPILER "-gcc") # no GCC version encoding prior to 1.34 + else() + _Boost_COMPILER_DUMPVERSION(_boost_COMPILER_VERSION) + # Determine which version of GCC we have. + IF(APPLE) + IF(Boost_MINOR_VERSION) + IF(${Boost_MINOR_VERSION} GREATER 35) + # In Boost 1.36.0 and newer, the mangled compiler name used + # on Mac OS X/Darwin is "xgcc". + SET(_boost_COMPILER "-xgcc${_boost_COMPILER_VERSION}") + ELSE(${Boost_MINOR_VERSION} GREATER 35) + # In Boost <= 1.35.0, there is no mangled compiler name for + # the Mac OS X/Darwin version of GCC. + SET(_boost_COMPILER "") + ENDIF(${Boost_MINOR_VERSION} GREATER 35) + ELSE(Boost_MINOR_VERSION) + # We don't know the Boost version, so assume it's + # pre-1.36.0. + SET(_boost_COMPILER "") + ENDIF(Boost_MINOR_VERSION) + ELSE() + SET (_boost_COMPILER "-gcc${_boost_COMPILER_VERSION}") + ENDIF() + endif() + endif (CMAKE_COMPILER_IS_GNUCXX) + endif() + if(Boost_DEBUG) + message(STATUS "[ ${CMAKE_CURRENT_LIST_FILE}:${CMAKE_CURRENT_LIST_LINE} ] " + "guessed _boost_COMPILER = ${_boost_COMPILER}") + endif() + endif(Boost_COMPILER) + + SET (_boost_MULTITHREADED "-mt") + if( NOT Boost_USE_MULTITHREADED ) + set (_boost_MULTITHREADED "") + endif() + if(Boost_DEBUG) + message(STATUS "[ ${CMAKE_CURRENT_LIST_FILE}:${CMAKE_CURRENT_LIST_LINE} ] " + "_boost_MULTITHREADED = ${_boost_MULTITHREADED}") + endif() + + SET( _boost_STATIC_TAG "") + set( _boost_ABI_TAG "") + IF (WIN32) + IF(MSVC) + SET (_boost_ABI_TAG "g") + ENDIF(MSVC) + IF( Boost_USE_STATIC_LIBS ) + SET( _boost_STATIC_TAG "-s") + ENDIF( Boost_USE_STATIC_LIBS ) + ENDIF(WIN32) + SET (_boost_ABI_TAG "${_boost_ABI_TAG}d") + if(Boost_DEBUG) + message(STATUS "[ ${CMAKE_CURRENT_LIST_FILE}:${CMAKE_CURRENT_LIST_LINE} ] " + "_boost_STATIC_TAG = ${_boost_STATIC_TAG}") + message(STATUS "[ ${CMAKE_CURRENT_LIST_FILE}:${CMAKE_CURRENT_LIST_LINE} ] " + "_boost_ABI_TAG = ${_boost_ABI_TAG}") + endif() + + # ------------------------------------------------------------------------ + # Begin finding boost libraries + # ------------------------------------------------------------------------ + + SET(_boost_LIBRARIES_SEARCH_DIRS + C:/boost/lib + C:/boost + "${boost_ENV_PROGRAM_FILES_DIR}/boost/boost_${Boost_MAJOR_VERSION}_${Boost_MINOR_VERSION}_${Boost_SUBMINOR_VERSION}/lib" + "${boost_ENV_PROGRAM_FILES_DIR}/boost/boost_${Boost_MAJOR_VERSION}_${Boost_MINOR_VERSION}/lib" + "${boost_ENV_PROGRAM_FILES_DIR}/boost" + /sw/local/lib + ) + IF( BOOST_ROOT ) + SET(_boost_LIBRARIES_SEARCH_DIRS + ${BOOST_ROOT}/lib + ${BOOST_ROOT}/stage/lib + ${_boost_LIBRARIES_SEARCH_DIRS}) + ENDIF( BOOST_ROOT ) + + IF( BOOST_LIBRARYDIR ) + file(TO_CMAKE_PATH ${BOOST_LIBRARYDIR} BOOST_LIBRARYDIR) + SET(_boost_LIBRARIES_SEARCH_DIRS + ${BOOST_LIBRARYDIR} ${_boost_LIBRARIES_SEARCH_DIRS}) + ENDIF( BOOST_LIBRARYDIR ) + + if(Boost_DEBUG) + message(STATUS "[ ${CMAKE_CURRENT_LIST_FILE}:${CMAKE_CURRENT_LIST_LINE} ] " + "_boost_LIBRARIES_SEARCH_DIRS = ${_boost_LIBRARIES_SEARCH_DIRS}") + endif() + + FOREACH(COMPONENT ${Boost_FIND_COMPONENTS}) + STRING(TOUPPER ${COMPONENT} UPPERCOMPONENT) + SET( Boost_${UPPERCOMPONENT}_LIBRARY "Boost_${UPPERCOMPONENT}_LIBRARY-NOTFOUND" ) + SET( Boost_${UPPERCOMPONENT}_LIBRARY_RELEASE "Boost_${UPPERCOMPONENT}_LIBRARY_RELEASE-NOTFOUND" ) + SET( Boost_${UPPERCOMPONENT}_LIBRARY_DEBUG "Boost_${UPPERCOMPONENT}_LIBRARY_DEBUG-NOTFOUND") + + # Support preference of static libs by adjusting CMAKE_FIND_LIBRARY_SUFFIXES + IF( Boost_USE_STATIC_LIBS ) + SET( _boost_ORIG_CMAKE_FIND_LIBRARY_SUFFIXES ${CMAKE_FIND_LIBRARY_SUFFIXES}) + IF(WIN32) + SET(CMAKE_FIND_LIBRARY_SUFFIXES .lib .a ${CMAKE_FIND_LIBRARY_SUFFIXES}) + ELSE(WIN32) + SET(CMAKE_FIND_LIBRARY_SUFFIXES .a ${CMAKE_FIND_LIBRARY_SUFFIXES}) + ENDIF(WIN32) + ENDIF( Boost_USE_STATIC_LIBS ) + + FIND_LIBRARY(Boost_${UPPERCOMPONENT}_LIBRARY_RELEASE + NAMES ${Boost_LIB_PREFIX}boost_${COMPONENT}${_boost_COMPILER}${_boost_MULTITHREADED}-${Boost_LIB_VERSION} + ${Boost_LIB_PREFIX}boost_${COMPONENT}${_boost_COMPILER}${_boost_MULTITHREADED}${_boost_STATIC_TAG}-${Boost_LIB_VERSION} + ${Boost_LIB_PREFIX}boost_${COMPONENT}${_boost_MULTITHREADED}-${Boost_LIB_VERSION} + ${Boost_LIB_PREFIX}boost_${COMPONENT}${_boost_MULTITHREADED}${_boost_STATIC_TAG}-${Boost_LIB_VERSION} + ${Boost_LIB_PREFIX}boost_${COMPONENT}${_boost_MULTITHREADED} + ${Boost_LIB_PREFIX}boost_${COMPONENT}${_boost_MULTITHREADED}${_boost_STATIC_TAG} + ${Boost_LIB_PREFIX}boost_${COMPONENT} + PATHS ${_boost_LIBRARIES_SEARCH_DIRS} + ) + + FIND_LIBRARY(Boost_${UPPERCOMPONENT}_LIBRARY_DEBUG + NAMES ${Boost_LIB_PREFIX}boost_${COMPONENT}${_boost_COMPILER}${_boost_MULTITHREADED}-${_boost_ABI_TAG}-${Boost_LIB_VERSION} + ${Boost_LIB_PREFIX}boost_${COMPONENT}${_boost_COMPILER}${_boost_MULTITHREADED}${_boost_STATIC_TAG}${_boost_ABI_TAG}-${Boost_LIB_VERSION} + ${Boost_LIB_PREFIX}boost_${COMPONENT}${_boost_MULTITHREADED}-${_boost_ABI_TAG}-${Boost_LIB_VERSION} + ${Boost_LIB_PREFIX}boost_${COMPONENT}${_boost_MULTITHREADED}${_boost_STATIC_TAG}${_boost_ABI_TAG}-${Boost_LIB_VERSION} + ${Boost_LIB_PREFIX}boost_${COMPONENT}${_boost_MULTITHREADED}-${_boost_ABI_TAG} + ${Boost_LIB_PREFIX}boost_${COMPONENT}${_boost_MULTITHREADED}${_boost_STATIC_TAG}${_boost_ABI_TAG} + ${Boost_LIB_PREFIX}boost_${COMPONENT}-${_boost_ABI_TAG} + PATHS ${_boost_LIBRARIES_SEARCH_DIRS} + ) + + _Boost_ADJUST_LIB_VARS(${UPPERCOMPONENT}) + IF( Boost_USE_STATIC_LIBS ) + SET(CMAKE_FIND_LIBRARY_SUFFIXES ${_boost_ORIG_CMAKE_FIND_LIBRARY_SUFFIXES}) + ENDIF( Boost_USE_STATIC_LIBS ) + ENDFOREACH(COMPONENT) + # ------------------------------------------------------------------------ + # End finding boost libraries + # ------------------------------------------------------------------------ + + SET(Boost_INCLUDE_DIRS + ${Boost_INCLUDE_DIR} + ) + + SET(Boost_FOUND FALSE) + IF(Boost_INCLUDE_DIR) + SET( Boost_FOUND TRUE ) + + # Check the version of Boost against the requested version. + if (Boost_FIND_VERSION AND NOT Boost_FIND_VERSION_MINOR) + message(SEND_ERROR "When requesting a specific version of Boost, you must provide at least the major and minor version numbers, e.g., 1.34") + endif (Boost_FIND_VERSION AND NOT Boost_FIND_VERSION_MINOR) + if(Boost_MAJOR_VERSION LESS "${Boost_FIND_VERSION_MAJOR}" ) + set( Boost_FOUND FALSE ) + set(_Boost_VERSION_AGE "old") + elseif(Boost_MAJOR_VERSION EQUAL "${Boost_FIND_VERSION_MAJOR}" ) + if(Boost_MINOR_VERSION LESS "${Boost_FIND_VERSION_MINOR}" ) + set( Boost_FOUND FALSE ) + set(_Boost_VERSION_AGE "old") + elseif(Boost_MINOR_VERSION EQUAL "${Boost_FIND_VERSION_MINOR}" ) + if( Boost_FIND_VERSION_PATCH AND Boost_SUBMINOR_VERSION LESS "${Boost_FIND_VERSION_PATCH}" ) + set( Boost_FOUND FALSE ) + set(_Boost_VERSION_AGE "old") + endif( Boost_FIND_VERSION_PATCH AND Boost_SUBMINOR_VERSION LESS "${Boost_FIND_VERSION_PATCH}" ) + endif( Boost_MINOR_VERSION LESS "${Boost_FIND_VERSION_MINOR}" ) + endif( Boost_MAJOR_VERSION LESS "${Boost_FIND_VERSION_MAJOR}" ) + + if (Boost_FOUND AND Boost_FIND_VERSION_EXACT) + # If the user requested an exact version of Boost, check + # that. We already know that the Boost version we have is >= the + # requested version. + set(_Boost_VERSION_AGE "new") + + # If the user didn't specify a patchlevel, it's 0. + if (NOT Boost_FIND_VERSION_PATCH) + set(Boost_FIND_VERSION_PATCH 0) + endif (NOT Boost_FIND_VERSION_PATCH) + + # We'll set Boost_FOUND true again if we have an exact version match. + set(Boost_FOUND FALSE) + if(Boost_MAJOR_VERSION EQUAL "${Boost_FIND_VERSION_MAJOR}" ) + if(Boost_MINOR_VERSION EQUAL "${Boost_FIND_VERSION_MINOR}" ) + if(Boost_SUBMINOR_VERSION EQUAL "${Boost_FIND_VERSION_PATCH}" ) + set( Boost_FOUND TRUE ) + endif(Boost_SUBMINOR_VERSION EQUAL "${Boost_FIND_VERSION_PATCH}" ) + endif( Boost_MINOR_VERSION EQUAL "${Boost_FIND_VERSION_MINOR}" ) + endif( Boost_MAJOR_VERSION EQUAL "${Boost_FIND_VERSION_MAJOR}" ) + endif (Boost_FOUND AND Boost_FIND_VERSION_EXACT) + + if(NOT Boost_FOUND) + # State that we found a version of Boost that is too new or too old. + set(Boost_ERROR_REASON + "${Boost_ERROR_REASON}\nDetected version of Boost is too ${_Boost_VERSION_AGE}. Requested version was ${Boost_FIND_VERSION_MAJOR}.${Boost_FIND_VERSION_MINOR}") + if (Boost_FIND_VERSION_PATCH) + set(Boost_ERROR_REASON + "${Boost_ERROR_REASON}.${Boost_FIND_VERSION_PATCH}") + endif (Boost_FIND_VERSION_PATCH) + if (NOT Boost_FIND_VERSION_EXACT) + set(Boost_ERROR_REASON "${Boost_ERROR_REASON} (or newer)") + endif (NOT Boost_FIND_VERSION_EXACT) + set(Boost_ERROR_REASON "${Boost_ERROR_REASON}.") + endif (NOT Boost_FOUND) + + if (Boost_FOUND) + set(_boost_CHECKED_COMPONENT FALSE) + set(_Boost_MISSING_COMPONENTS) + foreach(COMPONENT ${Boost_FIND_COMPONENTS}) + string(TOUPPER ${COMPONENT} COMPONENT) + set(_boost_CHECKED_COMPONENT TRUE) + if(NOT Boost_${COMPONENT}_FOUND) + string(TOLOWER ${COMPONENT} COMPONENT) + list(APPEND _Boost_MISSING_COMPONENTS ${COMPONENT}) + set( Boost_FOUND FALSE) + endif(NOT Boost_${COMPONENT}_FOUND) + endforeach(COMPONENT) + endif (Boost_FOUND) + + if(Boost_DEBUG) + message(STATUS "[ ${CMAKE_CURRENT_LIST_FILE}:${CMAKE_CURRENT_LIST_LINE} ] Boost_FOUND = ${Boost_FOUND}") + endif() + + if (_Boost_MISSING_COMPONENTS) + # We were unable to find some libraries, so generate a sensible + # error message that lists the libraries we were unable to find. + set(Boost_ERROR_REASON + "${Boost_ERROR_REASON}\nThe following Boost libraries could not be found:\n") + foreach(COMPONENT ${_Boost_MISSING_COMPONENTS}) + set(Boost_ERROR_REASON + "${Boost_ERROR_REASON} boost_${COMPONENT}\n") + endforeach(COMPONENT) + + list(LENGTH Boost_FIND_COMPONENTS Boost_NUM_COMPONENTS_WANTED) + list(LENGTH _Boost_MISSING_COMPONENTS Boost_NUM_MISSING_COMPONENTS) + if (${Boost_NUM_COMPONENTS_WANTED} EQUAL ${Boost_NUM_MISSING_COMPONENTS}) + set(Boost_ERROR_REASON + "${Boost_ERROR_REASON}No Boost libraries were found. You may need to set Boost_LIBRARYDIR to the directory containing Boost libraries or BOOST_ROOT to the location of Boost.") + else (${Boost_NUM_COMPONENTS_WANTED} EQUAL ${Boost_NUM_MISSING_COMPONENTS}) + set(Boost_ERROR_REASON + "${Boost_ERROR_REASON}Some (but not all) of the required Boost libraries were found. You may need to install these additional Boost libraries. Alternatively, set Boost_LIBRARYDIR to the directory containing Boost libraries or BOOST_ROOT to the location of Boost.") + endif (${Boost_NUM_COMPONENTS_WANTED} EQUAL ${Boost_NUM_MISSING_COMPONENTS}) + endif (_Boost_MISSING_COMPONENTS) + + IF( NOT Boost_LIBRARY_DIRS AND NOT _boost_CHECKED_COMPONENT ) + # Compatibility Code for backwards compatibility with CMake + # 2.4's FindBoost module. + + # Look for the boost library path. + # Note that the user may not have installed any libraries + # so it is quite possible the Boost_LIBRARY_PATH may not exist. + SET(_boost_LIB_DIR ${Boost_INCLUDE_DIR}) + + IF("${_boost_LIB_DIR}" MATCHES "boost-[0-9]+") + GET_FILENAME_COMPONENT(_boost_LIB_DIR ${_boost_LIB_DIR} PATH) + ENDIF ("${_boost_LIB_DIR}" MATCHES "boost-[0-9]+") + + IF("${_boost_LIB_DIR}" MATCHES "/include$") + # Strip off the trailing "/include" in the path. + GET_FILENAME_COMPONENT(_boost_LIB_DIR ${_boost_LIB_DIR} PATH) + ENDIF("${_boost_LIB_DIR}" MATCHES "/include$") + + IF(EXISTS "${_boost_LIB_DIR}/lib") + SET (_boost_LIB_DIR ${_boost_LIB_DIR}/lib) + ELSE(EXISTS "${_boost_LIB_DIR}/lib") + IF(EXISTS "${_boost_LIB_DIR}/stage/lib") + SET(_boost_LIB_DIR ${_boost_LIB_DIR}/stage/lib) + ELSE(EXISTS "${_boost_LIB_DIR}/stage/lib") + SET(_boost_LIB_DIR "") + ENDIF(EXISTS "${_boost_LIB_DIR}/stage/lib") + ENDIF(EXISTS "${_boost_LIB_DIR}/lib") + + IF(_boost_LIB_DIR AND EXISTS "${_boost_LIB_DIR}") + SET(Boost_LIBRARY_DIRS ${_boost_LIB_DIR} CACHE FILEPATH "Boost library directory") + ENDIF(_boost_LIB_DIR AND EXISTS "${_boost_LIB_DIR}") + + ENDIF( NOT Boost_LIBRARY_DIRS AND NOT _boost_CHECKED_COMPONENT ) + + ELSE(Boost_INCLUDE_DIR) + SET( Boost_FOUND FALSE) + ENDIF(Boost_INCLUDE_DIR) + + IF (Boost_FOUND) + IF (NOT Boost_FIND_QUIETLY) + MESSAGE(STATUS "Boost version: ${Boost_MAJOR_VERSION}.${Boost_MINOR_VERSION}.${Boost_SUBMINOR_VERSION}") + ENDIF(NOT Boost_FIND_QUIETLY) + IF (NOT Boost_FIND_QUIETLY) + MESSAGE(STATUS "Found the following Boost libraries:") + ENDIF(NOT Boost_FIND_QUIETLY) + FOREACH ( COMPONENT ${Boost_FIND_COMPONENTS} ) + STRING( TOUPPER ${COMPONENT} UPPERCOMPONENT ) + IF ( Boost_${UPPERCOMPONENT}_FOUND ) + IF (NOT Boost_FIND_QUIETLY) + MESSAGE (STATUS " ${COMPONENT}") + ENDIF(NOT Boost_FIND_QUIETLY) + SET(Boost_LIBRARIES ${Boost_LIBRARIES} ${Boost_${UPPERCOMPONENT}_LIBRARY}) + ENDIF ( Boost_${UPPERCOMPONENT}_FOUND ) + ENDFOREACH(COMPONENT) + ELSE (Boost_FOUND) + IF (Boost_FIND_REQUIRED) + message(SEND_ERROR "Unable to find the requested Boost libraries.\n${Boost_ERROR_REASON}") + ENDIF(Boost_FIND_REQUIRED) + ENDIF(Boost_FOUND) + + # show the Boost_INCLUDE_DIRS AND Boost_LIBRARIES variables only in the advanced view + MARK_AS_ADVANCED(Boost_INCLUDE_DIR + Boost_INCLUDE_DIRS + Boost_LIBRARY_DIRS + ) +ENDIF(_boost_IN_CACHE) + Index: cmake/modules/CGALConfig_install.cmake.source.in =================================================================== --- cmake/modules/CGALConfig_install.cmake.source.in (revision 47550) +++ cmake/modules/CGALConfig_install.cmake.source.in (working copy) @@ -122,3 +122,6 @@ check_cgal_component("_${CGAL_COMPONENT}") endforeach() +# Starting with cmake 2.6.3, CGAL_FIND_COMPONENTS is cleared out when find_package returns. +# But we need it within UseCGAL.cmake, so we save it aside into another variable +set( CGAL_REQUESTED_COMPONENTS ${CGAL_FIND_COMPONENTS} ) Index: config/support/test_BOOST_PROGRAM_OPTIONS.cpp =================================================================== --- config/support/test_BOOST_PROGRAM_OPTIONS.cpp (revision 47550) +++ config/support/test_BOOST_PROGRAM_OPTIONS.cpp (working copy) @@ -1,8 +1,5 @@ -// Copyright (c) 2006, 2007 Utrecht University (The Netherlands), -// ETH Zurich (Switzerland), Freie Universitaet Berlin (Germany), -// INRIA Sophia-Antipolis (France), Martin-Luther-University Halle-Wittenberg -// (Germany), Max-Planck-Institute Saarbruecken (Germany), RISC Linz (Austria), -// and Tel-Aviv University (Israel). All rights reserved. +// Copyright (c) 2006, 2007, 2009 Stanford University (USA), +// INRIA Sophia-Antipolis (France). All rights reserved. // // This file is part of CGAL (www.cgal.org); you can redistribute it and/or // modify it under the terms of the GNU Lesser General Public License as @@ -17,29 +14,35 @@ // // $URL$ // $Id$ -// // -// Author(s) : Daniel Russel +// Author(s) : Daniel Russel, Sylvain Pion // Tests if BOOST_PROGRAM_OPTIONS is available. #include <iostream> +#include <string> #include <boost/program_options.hpp> +namespace po = boost::program_options; + int main(int ac, char *av[]) { std::cout << "version=" << BOOST_VERSION/100000 << "." << ((BOOST_VERSION / 100) % 100) << "." << BOOST_VERSION % 100 << std::endl; - boost::program_options::options_description desc("Allowed options"); + std::string str; + + po::options_description desc("Allowed options"); desc.add_options() ("help", "produce help message") + ("input-file,f", po::value<std::string>(&str)->default_value("blabla.txt"), + "name of file") ; - boost::program_options::variables_map vm; - boost::program_options::store(boost::program_options::parse_command_line(ac, av, desc), vm); - boost::program_options::notify(vm); + po::variables_map vm; + po::store(po::parse_command_line(ac, av, desc), vm); + po::notify(vm); if (vm.count("help")) { std::cout << "Help" << "\n";
- Re: [cgal-discuss] Polyhedron demo problem, (continued)
- Re: [cgal-discuss] Polyhedron demo problem, Laurent Rineau (GeometryFactory), 05/19/2009
- Re: [cgal-discuss] Polyhedron demo problem (bis), Martial TOLA (CNRS-Liris), 05/15/2009
- Re: [cgal-discuss] Polyhedron demo problem (bis), Laurent Rineau (GeometryFactory), 05/18/2009
- Re: [cgal-discuss] Polyhedron demo problem (bis), Martial TOLA (CNRS-Liris), 05/19/2009
- Re: [cgal-discuss] Polyhedron demo problem (bis), Laurent Rineau (GeometryFactory), 05/19/2009
- Re: [cgal-discuss] Polyhedron demo problem (bis), Martial TOLA (CNRS-Liris), 05/20/2009
- Re: [cgal-discuss] Polyhedron demo problem (bis), Laurent Rineau (GeometryFactory), 05/20/2009
- [cgal-discuss] Obtaining coordinates from vertex_handle in CGAL::Polyhedron_3<CGAL::Exact_predicates_exact_constructions_kernel>, Matthias Teich, 05/20/2009
- Re: [cgal-discuss] Obtaining coordinates from vertex_handle in CGAL::Polyhedron_3<CGAL::Exact_predicates_exact_constructions_kernel>, Laurent Rineau (GeometryFactory), 05/20/2009
