[cgal-discuss] Obtaining coordinates from vertex_handle in CGAL::Polyhedron_3<CGAL::Exact_predicates_exact_constructions_kernel>
- To:
- Subject: [cgal-discuss] Obtaining coordinates from vertex_handle in CGAL::Polyhedron_3<CGAL::Exact_predicates_exact_constructions_kernel>
- Date: Wed, 20 May 2009 11:57:27 +0200
Hello again!
I am trying to obtain the x,y,z coordinates of a vertex in a CGAL::Polyhedron_3<CGAL::Exact_predicates_exact_constructions_kernel>.
Therefor I do something like the following:
#include <CGAL/Exact_predicates_exact_constructions_kernel.h>
#include <CGAL/Polyhedron_3.h>
typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;
typedef CGAL::Polyhedron_3<Kernel> Polyhedron;
typedef Polyhedron::Vertex_iterator Vertex_iterator;
typedef Kernel::Point_3 Point_3;
void test()
Polyhedron p;
for ( Vertex_iterator v = p.vertices_begin(); v != p.vertices_end(); ++v)
Point_3 point = v->point();
double d0 = point.x();
The VS compiler says
"error C2440: 'initializing' : cannot convert from 'CGAL::Lazy_exact_nt<ET_>' to 'double'
with
ET_=CGAL::Gmpq
No user-defined-conversion operator available that can perform this conversion, or the operator cannot be called"
In the original code p is converted from a typedef CGAL::Nef_polyhedron_3<Kernel> Nef_polyhedron.
I guess it is a problem with the kernels, but I have no clue how to solve it.
The simple cartesian kernel does not seem to work with nef_polyhedra and with the Exact_predicates_exact_constructions_kernel I can't access the coordinates of the vertices.
Best Regards,
Matthias
- Re: [cgal-discuss] Polyhedron demo problem, (continued)
- Re: [cgal-discuss] Polyhedron demo problem, Laurent Saboret, 05/18/2009
- Re: [cgal-discuss] Polyhedron demo problem, Martial TOLA (CNRS-Liris), 05/19/2009
- Re: [cgal-discuss] Polyhedron demo problem, Laurent Rineau (GeometryFactory), 05/19/2009
- Re: [cgal-discuss] Polyhedron demo problem (bis), Laurent Rineau (GeometryFactory), 05/18/2009
- Re: [cgal-discuss] Polyhedron demo problem (bis), Martial TOLA (CNRS-Liris), 05/19/2009
- Re: [cgal-discuss] Polyhedron demo problem (bis), Laurent Rineau (GeometryFactory), 05/19/2009
- Re: [cgal-discuss] Polyhedron demo problem (bis), Martial TOLA (CNRS-Liris), 05/20/2009
- Re: [cgal-discuss] Polyhedron demo problem (bis), Laurent Rineau (GeometryFactory), 05/20/2009
- [cgal-discuss] Obtaining coordinates from vertex_handle in CGAL::Polyhedron_3<CGAL::Exact_predicates_exact_constructions_kernel>, Matthias Teich, 05/20/2009
- Re: [cgal-discuss] Obtaining coordinates from vertex_handle in CGAL::Polyhedron_3<CGAL::Exact_predicates_exact_constructions_kernel>, Laurent Rineau (GeometryFactory), 05/20/2009
