- To: <>
- Subject: Re: [cgal-discuss] 3D Triangulation / surface reconstruction
- Date: Sat, 6 Jun 2009 19:22:19 +0530
Hi
I think you need Alpha shape that doing surface
reconstruction job for you that will found in Alpha package. or You can try this
one also but you have to do some code changes it is in java
alex
- [cgal-discuss] 3D Triangulation / surface reconstruction, Jens K. Becker, 06/04/2009
- Re: [cgal-discuss] 3D Triangulation / surface reconstruction, Bo Zhou, 06/06/2009
- Re: [cgal-discuss] 3D Triangulation / surface reconstruction, alex, 06/06/2009
- Re: [cgal-discuss] 3D Triangulation / surface reconstruction, Jens K. Becker, 06/09/2009
- [cgal-discuss] 2D Boolean operation, alex, 06/18/2009
- Re: [cgal-discuss] 2D Boolean operation, Kim, 06/18/2009
- Re: [cgal-discuss] 2D Boolean operation, alex, 06/19/2009
- Re: [cgal-discuss] 2D Boolean operation, Kim, 06/19/2009
- Re: [cgal-discuss] 2D Boolean operation, alex, 06/20/2009
- Message not available
- Re: [cgal-discuss] 2D Boolean operation, Kim, 06/21/2009
