- To:
- Subject: Re: [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3
- Date: Sun, 07 Jun 2009 14:54:23 +0200
- Organization: INRIA
My suggestion would be that you change all occurences of the word "hz"
to e.g. "hz_" in your own copy of CGAL.
I don't see a reasonable solution to work around this within CGAL.
Shu Ye wrote:
Hi Sylvain,
Thank you for taking a look at it. Do you have any suggestions on how to fix it?
Thanks,
-Shu
--- On *Fri, 6/5/09, Sylvain Pion
AIX 5.3
To:
Date: Friday, June 5, 2009, 8:26 PM
</mc/compose?>
wrote:
> Hi,
> Has anyone successfully installed CGAL on IBM AIX systems?
> I am trying to install CGAL 3.3.1 libraries on IBM AIX 5.3
system recently. The OS is 'powerpc_AIX-3.0, Compiler is GNU 4.1.2.
The setup has been test OK. When I built CGAL libraries, I got lots
of compiler errors. I attached two log files if you want to take a
look at the errors. Thank you in advance.
/home/shuy/EMS/CGAL-3.3.1/ibmrs1/CGAL-3.3.1/include/CGAL/Point_3.h:145:
error: '100' cannot be used as a function
Smeels like some system header is defining a macro like "hz" to 100...
-- Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
-- You are currently subscribed to cgal-discuss.
Sylvain Pion
- [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3, sye_01, 06/05/2009
- Re: [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3, Sylvain Pion, 06/05/2009
- <Possible follow-up(s)>
- Re: [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3, Shu Ye, 06/05/2009
- Re: [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3, Sylvain Pion, 06/07/2009
- Re: [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3, Shu Ye, 06/08/2009
- Re: [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3, Sylvain Pion, 06/08/2009
- Re: [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3, Joachim Reichel, 06/08/2009
- Re: [cgal-discuss] issues of installing CGAL 3.3.1 on IBM AIX 5.3, Shu Ye, 06/09/2009
