cgal-discuss - Re: [cgal-discuss] 3D Triangulation / surface reconstruction
  • To:
  • Subject: Re: [cgal-discuss] 3D Triangulation / surface reconstruction
  • Date: Tue, 09 Jun 2009 11:32:23 +0200
Hi alex,
I thought about alpha shapes, but the it is not garanteed that the
spacing of vertices is such that I can "just" cut away parts and end up
with what I need. It has to be done automatically, no user interaction
is possible. I will have a look at the link you gave, I hope that will
do the trick..
Greetings,
Jens
On Sat, 2009-06-06 at 19:22 +0530, alex wrote:
> Hi
> I think you need Alpha shape that doing surface reconstruction job for
> you that will found in Alpha package. or You can try this one also but
> you have to do some code changes it is in java
> http://www.loria.fr/~pougetma/software/reconstruction/reconstruction.html
> alex
> ----- Original Message -----
> From: Bo Zhou
> To:
> Sent: Saturday, June 06, 2009 5:25 PM
> reconstruction
> Jens K. Becker wrote:
> > Hi all,
> > I am puzzling over this problem for quite some time now and just
> cant
> > find a solution... I have a set of polyhedra that share facets and
> > vertices. Obviously, each facet can only belong to two polyhedra
> while a
> > vertex might belong to much more. If I want to delete a facet (or
> a
> > vertex) or add a facet (or a vertex) to one polyhedron, I have to
> add
> > the same to other polyhedra too. The most convenient would be to
> > construct a (Delaunay) triangulation of the part of the polyhedra
> where
> > things are going to happen, do whatever has to be done and
> reconstruct
> > the polyhedra from that triangulation. But how? The problem is the
> > reconstruction because I cannot think of any way how to decide
> which
> > facet of the triangulation belongs to which polyhedron. Is there
> an easy
> > way to do this? Or a hard way?
> > The triangulation would typically consist of 20-30 vertices only,
> I can
> > store which vertex belongs to which polyhedron in the vertices
> and/or I
> > could store which facet belongs to which polyhedron (before
> > inserting/deleting things from the triangulation) but I did not
> figure
> > out a way how to reconstruct it from this information.
> > I tried to have a look at the example in CGAL3.4 that does
> remeshing of
> > a polyhedron, but did not really understand what is happening
> there (and
> > could not get it to compile neither, but that's another story).
> > If anybody has any ideas, I would be very happy. He/she will be
> invited
> > for beers (wine, water you decide...) should we ever meet!
> > Thanks for any help,
> > Jens Becker
> Hello,
> I think maybe the meshes you need to deal with are like this
> one (from SIGGRAPH 2000 Course Notes Subdivision for Modeling
> and Animation) if I have not misunderstood the situation you
> illustrated.
> To mark the facets to which mesh they belongs, maybe you can
> redefine some basic structure like the demo
> "examples/Polyhedron/polyhedron_prog_color.cpp" or in PDF
> manual page 1523, it redefined the half-edge structure to add
> a color component.
> * Bo Zhou
> * Blog : http://jedimaster.cnblogs.com
> * Mobile : +86 13451813691
Dr. J.K. Becker
University of Tuebingen - Institute for Geoscience
Sigwartst. 10 - 72076 Tuebingen (Germany)
Tel.: ++49 7071 29 73139 Fax: +49 7071 5059
Web: http://www.jkbecker.de
