- To:
- Subject: [cgal-discuss] Triangulation: point is not inserted
- Date: Mon, 29 Jun 2009 19:42:14 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=googlemail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type :content-transfer-encoding; b=Yh0Rmcx06ykoir0tQ5JcUILzQ7gb0/J1y9qNquln4wDvcKY3K2Oyzusv8oWamMjfJl aGmPg7cDtXW05xYkzEVuu0tTUak9WIy1KkR1nvRFMkiE0OeoBU/tWwnWxbYAkUOc32iD 3Rx67SL6eNN43wW69CHg6LiqniE8E+A6dtgqU=
Hi,
I'm using a Delaunay triangulation and some of the points are not
inserted: the number of vertices in the triangulation is the same
before and after the insertion. Is it done on purpose so that similar
points cannot be added twice?
Thanks,
Frank
- [cgal-discuss] Triangulation: point is not inserted, gtsml owevwr, 06/29/2009
- Re: [cgal-discuss] Triangulation: point is not inserted, Sylvain Pion, 06/29/2009
- Re: [cgal-discuss] Triangulation: point is not inserted, Damian Sheehy, 06/29/2009
- Re: [cgal-discuss] Triangulation: point is not inserted, gtsml owevwr, 06/30/2009
- Re: [cgal-discuss] Triangulation: point is not inserted, Daniel Duque, 06/30/2009
- Re: [cgal-discuss] Triangulation: point is not inserted, Andreas Fabri, 06/30/2009
- Re: [cgal-discuss] Triangulation: point is not inserted, Camille Wormser, 06/30/2009
